X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
2004 X3 3.0 Radiator Fluid & Transmission Leak Questions [Update]
Hello all,
I recently purchased a 2004 BMW X3 3.0 with 98k miles and an auto transmission. I have searched tremendously before posting my question as I hate to be one of those users that posts before reading so I wanted to confirm and then ask some questions about pricing. The car BTW does not seem to have a lot of the maintenance done, not from what I can tell from the Carfax anyways. I am pretty sure that my coolant expansion tank needs replacement. 1) Is Turner Motorsport what most of you would recommend to get the replacement part from? I could not find a specific DIY to replace this part, is there an old one someone with pictures that could link? 2) I have heard that replacing the thermostat is also wise, is that recommended? Car heats fine as far as I know. Now to a more serious question: when I topped off my coolant earlier (due to the leak) I noticed small brown spots... in my experience, that's usually transmission fluid leaking onto the radiator system.. but upon further inspection it seems that the oil heat exchange is actually located outside the radiator unit... 1) I am not sure how to proceed now, I mean, I can replace the coolant expansion tank but what in the world can I do about the tranmission leak? Is there a way to confirm it... 2) Is this a common occurrence or is this something else? Thank you, I look forward to contribute to this community. AWDREV Last edited by awdrev; 12-06-2012 at 02:40 PM. |
Here is a DIY for the expansion tank replacement.
http://www.bimmerfest.com/forums/sho...d.php?t=415259 One for the thermostat http://www.bmw330ci.net/maintenance/thermostat.php Here is the complete cooling system overhaul. It's probably time to do this if it's never been done. http://www.bmw330ci.net/maintenance/completecoolant.php I've never heard of a transmission leak in the X3's. It doesn't seem to be a common problem.
Thank you. So the good news is that apparently there is no way that transmission fluid can get into the cooling system because they are totally independent. This is a great relieve because I had an old Ford (yea i know) that had a radiator that was used for both oil and water... of course they were separate systems but all within the same radiator... and what ended up happening is the inside system for the transmission started to leak badly and the transmission ended up being destroyed because of insufficient cooling.
Now that I have a better picture or what needs to be done, I will be replacing the coolant tank. Fortunately, I did confirm that it is what's leaking, which again is good news because it seems quite simple. And after consideration, I will be getting the BMW OEM part from the dealer which actually is almost double the price but I can't risk any damage to the engine. As far as the water pump, I'm intrigued as well. I'd like to replace it with a new one, and also to replace the hoses, etc but I need to do a little more research. I think taking the mechanical fan will be a pain, a minor one I reckon but I'll definitely want to get an idea of taking that part off. Fortunately, it seems that after the mechanical fan is off, it's an easy process. Now, as I said I just got the car and thought about the transmission but I keep reading that it's "lifetime tested" and there is no need to do anything to it.... of course, that's really unpersuasive, cars need maintenance, simple as that. But when I called the BMW dealer, they refused to do it and said tranny would break. I'll prob leave that as is for now, tranny works fine even at 100K and I'll really hate to get the fluid switch and have it slip, etc. |
Brown spots in coolant be from someone in the past topping off with green coolant. Just a guess, but doing a good flush and fill should be the first priority after replacing the expansion tank and its A/T thermostat. Personally, I wouldn't stress over the A/T lifetime fluid if it has never been changed. Water pumps and thermostats appear to last longer in the E83 than they do in the E46, so not too much risk in delaying that if no symptoms. Hoses are definitely worth replacing if any signs of degradation after 9 years and 100K miles. If the vehicle has not had the best of care under the previous owner(s) may be best to err on the side of caution though. The first thing I would do is a transfer case fluid replacement, even before the coolant repair. |
Thank you for the reply.
I'll replace the coolant tank and I will do a flush or have the dealership do it. I will prob change the water pump in the summer though... and maybe replace everything including the radiator. If it's only an electric fan, it'll be really easy to pull out but do we have a mechanical one? hmm, I'll have to double check... if not, then even easier to replace water pump. I'm leaving the A/T fluid as is.... but talk to me more about the transfer case fluid replacement what's the deal with that, as I said, tranny feels strong and I have checked out all the features such as the DSC, etc and they seem to work. 1) Are there major issues with the transfer cases? 2) I'll look for a DYI but if you have one, feel free to please post it along.. EDIT: FOUND A DYI so will probably do that too... but do tell me how the transfer cases are in these vehicles... etc Last edited by awdrev; 12-05-2012 at 09:31 AM. |
BMW engineers like to avoid accessories that are a drag on engine power, so electric cooling fans area no-brainer.
For the 2007+ model they moved to an electric water pump. Not sure where they are with electric power steering across the current model range. Transfer cases are thought to be a weak point with the X3 based on discussion in this forum. Mostly it's the separate actuator that wears out, but some owners have had bigger problems either as a consequence of that, or lubrication issues. For part of the 2004 model year X3 transfer cases were filled with A/T fluid as the newly-developed xDrive fluid was not available then. Dealers did not replace the fluid unless a wear value code was thrown based on monitoring of resistance in clutch plate operation. Fluid costs about $50 so any cautious owner should have had it done regardless. |
But I also have read that if mine used A/T fluid, it would be best if I started using xDrive fluid... The switch of liquid concerns me, is there a way to know which one is it? Maybe through the VIN or through a label...
When you drain it, you should be able to tell from the reddish color. The xDrive fluid is a very light color. It's not like other instances where there is a concern that some of the old fluid remains in passages and may be incompatible with the new fluid. Opinions vary, but changing it about every 50K miles seems right. The other concern is, for any model year, the factory fill for both the transfer case and the 2 diffs. (synthetic 75W90 gear oil) has been observed to be on the low side. This may or may not have been a factor in the few cases of early transfer case and diff. problems (clunking, outright failure). More likely just variances in how well the supplier assembled the gears at their plant. |
So even if the factory used DIII fluid, I should just go ahead and put xDrive fluid?
I will keep the factor that you mentioned about the differentials... unfortunately, I prob won't be getting to that anytime soon. I'll do the coolant expansion tank, and then the transfer fluid change soon and we'll see how it goes from there. Assuming the car gives me no problems, I will start saving up to do a full cooling system upgrade by the summer which is right where I should be hitting 100K and I'll also try to take care of other fluids... but I am death scared to touch the tranny, especially if it's working fine. |
BMW changed its tune on the tranny's in 07 and now recommend 100,000 mile fluid change. Keep in mind while the GM transmission is different for post lci refresh its the same fluid dexron iv...some food for thought...
I change mine every 30k...but auto are like a box of chocolate...you never know what your going to get. As for the electric fan, it comes out super easy once the air snorkel is removed. It's only like two clips that hold it in place. For the cooling system for the m54 motor it is recommended to change water pump and thermostat at the same time as expansion tank. They are known problem areas. Some also like to replace radiator too so it's a 1 and done solution. I know with the e39 it was like clock work every 76k miles the cooling system would fail. |
I'd love to change the water pump and thermostat now but I won't get the chance... I'll just replace the expansion tank and hope that it holds up! And talking about the water pump, is the BMW OEM part still using the plastic part? I know some aftermarket water pumps upgrade it to METAL but I'd like to stick as OEM as possible if I can... and all I have to say is who in the world thinks plastic will hold up to extreme conditions? would it cost that much more to make the little part out of metal? Gee |
ATF has always been used in transfer case applications for any vehicle maker, but if BMW felt that all the interventions of xDrive demanded a more complex fluid formula, that's perfectly believable. Quote:
Might not seem much in isolation, but it all adds up. Cost to the car maker certainly comes into it, but I think they would argue that's not their primary reason for using plastic impellers, plastic expansion tanks, etc. Not sure which is preferable for the average owner, a metal impeller that corrodes down to nothing because the coolant didn't get changed often enough, or a plastic one that fails through old age. |
Okay, I'll ask for some of that good xDrive liquid tomorrow and replace it too.
So I get your argument about weight reduction but when it comes to critical parts that directly affect the reliability and resilience of the car, that thought is just unpersuasive coming from BMW's part. Yes, weight has a direct effect on a variety of factors such as MPG, etc but a metal propeller and a metal gear for the actuator would have been more beneficial than detrimental... I suppose you are right about whether is it preferable for the average owner to have a metal impeller that corrodes down to nothing because the coolant didn't get changed often enough, or a plastic one that fails through old age. But I think getting a coolant change is far easier and cheaper than getting the whole water pump replaced. Anyways, you've been great mate and I thank you for your time. I will be getting the parts and doing the swap hopefully soon... I got to finish these finals first. |
They also did the same thing with spark plugs between 2009 and 2010 (same part number though). The service interval went from 100k miles to 60k. For transfer case go get the BMW fluid and do ASAP! It easy to do just remember to get two new copper washers. |
I have reused mine in the past when i forgot to buy them so you can do it. I personally just like to get new ones.
Ditto.
Thanks Brian, you and SuperCourse have been great at answering my concerns. I'll be sure to keep this thread updated! |
One other thing, a good fluid transfer pump makes life a lot easier when refilling the transfer case. It is a very tight fit between a cross member and the full plug. I have found filling it much easier to shove a 1/4 clear tube in there attached to a pump.
It's funny you mention that because I was just looking for an old pump but I can't find it! UGH this is annoying.... what other way are there? I think I remember hearing that there was enough clearance to just fill it up using the bottle but I could be wrong...
Here's an ancillary question: I notice a little bit of jerking before the car comes to a stop... this seems to be a software issue from what I've researched. How true is that? and what's the overall range to fix something like that at the dealer... I feel this should be complementary because it's software, I mean, who charges for firmware upgrades..
Anyways, I will be doing the coolant tank and transfer case thing tomorrow morning, I gotta get it done early! |
Might be difficult to get the last of it in. A new fluid transfer pump might be best to ensure no residue contamination of that expensive fluid. |
And as far as how much to put, it's just to the top until it tops off right? According to what I've read it's just fill until it starts coming out, etc. |
You are spot on. It's full when it hits the top and starts spilling out. It takes almost the whole bottle.
Plus one on supers comments. Get a new pump. It is very very tight. |
If that doesn't help, at 98k miles I would then drop the pan and change fluid and filter. Another possible culprit could be your drive shaft. |
#25
UGH this is turning out to be a little too much but I gotta start somewhere... I'll try the tranny reset and see if that fixes the issue. I am trying to tackle one issue at a time and right now the transfer case fluid DEFINITELY has priority. Bought the coolant tank and will try to do that soon too... this might be a stupid question but to remove the tank, must I raise the car? or is an X3 high enough... I'm a thin guy so I think I can squeeze in unless there's major maneuvering around... |
