Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series / 2 Series > E82 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by either an inline 6 in the 128 or the twin turbo rocket sled 135.
Old 04-03-2008, 06:47 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
Stainless Steel Pedal Kit Installation
I prefer the looks of the BMW Stainless Steel Pedal Kit to the stock pedals and prefer the subtle look as opposed to the aluminum pedal kit.
The Stainless pedal kit is more expensive as it includes a new, full accelerator pedal assembly. You do not need to drill holes either (making lining up the pedals more difficult).
Tools required: T-30 Torx Driver, flat blade screwdriver
What is included (manual):
Accelerator Pedal
At the base of the accelerator, you will see a small round cap. Remove the cap with a small flat blade screwdriver.
With the cap removed, remove the T-30 Bolt and set it and the cap to the side. The next step is to remove the accelerator pedal. Slide the pedal assembly up, there is a clip that the pedal must slide off of. It has a wire harness on the side to the center console so do not pull too far up, just enough to free the pedal assembly. With the pedal removed, undock the wire harness and remove the pedal.
To install the new pedal, it is the inverse of the removal. Connect the wire harness and make sure it locks. Then slide the pedal down over the clip (as seen in the above picture just behind the wire harness). With the pedal assembly in place, install the T-30 Bolt and replace the cover.
Brake and Clutch Pedal
To install the brake and clutch pedal pads, remove the stock ones. The rubber is "hooked" onto the pedal so you simply peel it off. The installation of the new pads is the same as the removal. While it seems easy, this can be a bit difficult. If you look at the back of the new pads, you will see a lip that goes around the pad. This lip needs to wrap over the edge of the pedals.
I found that is best to start with the clutch pedal. The clutch is plastic and is a bit thinner than the brake pedal (which is metal and has 'waves' that make it a bit tougher). Slide the pad over the pedal and get side of the lip over the pedal. One side should not be too difficult to get. Begin working your way around the back side of the pedal, gently pulling the lip over the pedal with your finger. Just work your way around and it will go. The trick here is that you do not pull the rubber too much. If you do, you can dislodge the stainless steel from the rubber.
Finished Install:
Follow us on Facebook for news and current promotions
08 E82 135i | 02 Z3 Coupe | 01 R1100S
Old 04-03-2008, 07:07 AM
kwyjibo kwyjibo is offline
Regular User
Mein Auto: Z4 Coupe 3.0si, 2004 R32
thanks for the nice photo documentation! i got my pedals over the wiinter and should be installing them soon. one question: there was a similar thread (I think on the z4 forum) that said that you need to disconnect the battery or there was a chance of the airbags deploying, is this right?
thanks
1972 3.0 CS Coupe
2004 Golf R32
2006 Z4 Coupe 3.0si
Old 04-03-2008, 07:11 AM
AndyM's Avatar
Suede Master
thanks
When working with electrical stuff, it never hurts to do that. Leave the key out of the ignition and you should be fine.
Old 04-03-2008, 04:08 PM
Regular User
AndyM- Thanks for the reply.
1972 3.0 CS Coupe
2004 Golf R32
2006 Z4 Coupe 3.0si
Old 06-28-2009, 04:02 PM
drhever drhever is offline
Mein Auto: 2006 Z4 3.0si
Cool New Z4 Aluminum Pedals M type
I installed the M Aluminum pedals on my Z4, required drilling 4 holes in all three pedals. Clutch and gas pedals are easy, they are plastic and easy to drill into. By the way, I did not have to remove any pedals during the installation, Just have to remove the rubber pads on the clutch and brake, nothing to remove for the gas pedal. The brake pedal is steel, and quite difficult to drill holes in, but with alittle elbow grease and patience, I was able to drill the holes. Check out the picture, I think it looks pretty cool.
Name:	Z4 pedals 002.jpg
Old 06-29-2009, 06:53 AM
JimD1 JimD1 is offline
Mein Auto: 128i convertible
It looks like the surface of the stainless pedals is mostly rubber. That seems like a good thing from the standpoint of being slippery when wet. Some users of the aluminum pedals have commented theirs might be slightly more slippery. Any comments from stainless users on this point (or alumnium)?
Jim
Old 06-29-2009, 08:20 AM
Wink Aluminum pedals not slippery!
I have not noticed the pedals to be slippery at all, but I live in Los Angeles, and it really does not rain here all that much, so I might not be the greatest judge, but if you wear regular rubber soled shoes, i noticed that these aluminum pedals actually grip better than the stock rubber ones, which I had more slip issues with...hope that helps!
