Old 04-04-2008, 08:27 AM
ill_kuma's Avatar
ill_kuma ill_kuma is offline
Mein Auto: 2001 530i
Replacing Brake Light Bulb
Hey Guys,
My right side brake light bulb just went out this morning and needs to be replace. Do you guys know which bulb type is it and if theres a instructions to get to it in order to change it? I have a Pepboys close by and can swing by there during lunch to get the bulb. Just need to know which one to get.
Old 04-04-2008, 08:36 AM
dboy11 dboy11 is offline
Mein Auto: 99...540i
Originally Posted by ill_kuma View Post
Hey Guys,
They will have a manual for all the manufactures of the bulbs they carry, telling you which one it is...I suggest that you look at the rest of the bulbs I replaced all of mine at once
Its Going To Cost How Much???????
Old 04-04-2008, 09:11 AM
Fudman's Avatar
Fudman Fudman is offline
Use a 12V21W
Old 04-04-2008, 09:17 AM
ill_kuma's Avatar
thanks guys...
Old 04-04-2008, 10:29 AM
jieg jieg is offline
Ivan
Mein Auto: 525i 2003
take the burnt bulb to any autozone or similar car part store, I did the same 5 days ago.
you will find various options as to the amps, i selected the highest but as a wild guess
changing it is a pic nic
regards
ivan
---------------Ivan
Old 04-04-2008, 10:35 AM
ill_kuma's Avatar
I found a 12v32cp bulb at work...no idea what is 32cp mean. I replaced it with this bulb and now its working. But should I be worry that its not 12V21W?
Old 04-04-2008, 11:08 AM
Ivan
regards
ivan
---------------Ivan
Old 04-04-2008, 11:11 AM
Ivan
12V is the output from the powerlines
21W is the output power
should at least be 12V
take the good bulb out of the other encasing, and check the wattage. It is best to have them both the samw number W, so the ilumination is even from both sides of the brake lights
they cost like 3 bucks a pair, so best to replace them both in case of doubt
---------------Ivan
Old 04-04-2008, 04:13 PM
Steve530 Steve530 is offline
32 cp means 32 candlepower. That may be a 1156 bulb.
I think the 7056 (P21W) bulbs are more like 37 cp.
Old 04-04-2008, 05:29 PM
ill_kuma's Avatar
You are correct...that is a 1156 bulb...which I can use it as a replacement for a 7056. Thanks everyone...
Old 04-04-2008, 05:37 PM
Make sure the 1156 has a nickel base. A brass base will set up a dielectric current and cause corrosion.
Old 04-04-2008, 05:41 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
The correct size bulb is a 7506, which is 21 watt. It must have a nickle plated base, or the MID display will keep warning of a bulb burned out. The plain brass based bulbs have too much resistance and fool the bulb out sensor.
Other size bulbs may fit, but the 7506 is the correct size and specification.
Old 04-04-2008, 05:51 PM
+1, I did the same thing. My high mounted third brake light went out first, but when I inspected the other two bulbs, they were dark, and the filiment looked very worn. I just went ahead and bought two packages (two per pack) of bulbs, replaced all three, and had a spare to keep in the trunk.
Old 04-04-2008, 07:15 PM
I did a bit more checking, the 1156 is a 27 watt bulb. It may physically fit, but is higher wattage than specified. This may cause problems with overheating of the socket, or melting of the lens. I would be more concerned if it causes errors in the "bulb out" sensor.
Old 01-06-2010, 12:59 PM
shaynesharma shaynesharma is offline
Mein Auto: 2005 BMW X5 4.4L
Hey Guys,
Is it difficult to change the brake lights??
Old 01-06-2010, 03:57 PM
Originally Posted by shaynesharma View Post
Hey Guys,
No just pop off the back of the light assembly inside the trunk and the bulbs pop right off
Old 01-07-2010, 06:14 AM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
Just replaced mine with an Autozone one, $7 for two, and they threw in the anti-corrosion goop to put on the base...
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 01-17-2012, 11:15 AM
Markkos23 Markkos23 is offline
Mein Auto: Red 2001 bmw 525i
And if the socket burns out do i need to replace that?
Old 01-17-2012, 11:22 AM
replacing brake light bulb
hey guys, my right side brake light just went out and i bought replacement bulbs but they dont work. they are 1156 bulbs. is that too much watts?
Old 02-14-2012, 08:52 AM
MAussie MAussie is offline
Mein Auto: 5 Series
Xenon or Hallogen?
Sorry guys, this is the first forum I've come across in 15 years of surfing where you're encouraged to post new messages, but the means for doing so are not provided. Show me the sense! So I have to post here, apologies in advance if this offends anyone.
Anyway, I have a 2006 5 Series, and cannot remove the lite bulb from it's cannister. See following image.
Is that $200 xenon, or a $200 halogen? And how, if possible, do I remove it so I can start hunting around for a replacement?
On a side note, I replaced a headlite bulb on my Peugeot 407, 2006 model in less than 2 minutes for less than $1..... and you wouldn't believe, but when it was dark, it lit up the road. I could see. For a dollar. I was so happy, I bought two.
Old 02-14-2012, 11:45 AM
QSilver7's Avatar
QSilver7 QSilver7 is online now
Originally Posted by MAussie View Post
Sorry guys, this is the first forum I've come across in 15 years of surfing where you're encouraged to post new messages, but the means for doing so are not provided. Show me the sense! So I have to post here, apologies in advance if this offends anyone.....
The "means" for starting a NEW THREAD is provided on the e39's home page. Click the following link (which takes you back to the e39 forum's home page)...and at the very top LEFT of the page is a "tab/button" that says "NEW THREAD" (there's also a "tab/button" on the bottom left of the home page for starting a NEW THREAD) . Click on that tab and a new message box opens that allows you to ask a question and name the subject of your new thread.
Simple & easy : http://www.bimmerfest.com/forums/forumdisplay.php?f=103
Q {BMW CCA Member #191509}
(SOLD)
Old 02-14-2012, 12:08 PM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Entwicklung 39
Mein Auto: 2003 530i/5
It's a $20 halogen and you simply pry the base (gently and using even pressure) from the socket
Old 02-14-2012, 07:41 PM
Mein Auto: 5 Series
That "New Thread" button wasn't there yesterday. It may have been activated by me posting a reply and the scripts detecting some activity, or by a moderator realizing how unpractical the kill button policy is.
Old 02-14-2012, 07:47 PM
Mein Auto: 5 Series
Thanks Geezer, it must be stuck or something, coz I've tried to pry it out on two different occasions for at least 5 minutes each time. I guess I'll give it another shot. It must come out.
Old 02-16-2012, 05:37 AM
Mein Auto: 5 Series
Got it, found the H7 Osram 55 Watt for about $6. Not as cheap as the Peugeout, but not bad.
