E46 (1999 - 2006)
Old 04-07-2008, 06:22 AM
tony325ci_51 tony325ci_51 is offline
Mein Auto: BMW 325Ci
E46 Coupe window not closing properly
Recently my driver's side window (frameless on the coupe) will often not close properly. It goes high enough, but at the wrong angle, leaving a small gap, with the top of the window hitting the trim strip instead of tucking in behind it tightly to the seal.
It's ok if I shut the door and push the window in at the same time, it's often ok when driving at low speed, but will almost never close properly at higher speeds, due to wind I guess.
There appears to be a little play at the top when rocking the window in and out. Obviously this wouldn't happen if the window had a frame / guide, as in the saloon / sedan.
Anyone have experience of this problem, or can offer any advice on what part may need tightening or replacing to cure it, before I take the door panel off and look around ?
Old 04-07-2008, 07:29 AM
sunstorm's Avatar
sunstorm sunstorm is offline
Be My Wife.
Send a message via MSN to sunstorm
Mein Auto: BMW, only BMW.
try to close rear window 1st, then close the front window. otherwse, you may need see garage.
E38 X2 had. E39 X5 had. E46 X1 had. E65 X2 had. E71 X1 now. E84 X1 now. E90 LCI now. VW JETTA X2 had.
LOTUS ELISE SPORT X1 had. NISSAN BLUEBIRD U12 X1 had.
LEXUS SOARER 2.5T/T X1 had. CADI SRX X1 had.
Old 04-07-2008, 09:28 AM
Oizo Oizo is offline
Mein Auto: 01 325Ci
had something similar, my window would close all the way to the top when i close it with the door opened and when i close the door it would stick out. solution was to close the window while the door is still closed...no idea why this is happening...sorry couldnt help u here buddy
Old 04-07-2008, 09:31 AM
obmd1's Avatar
obmd1 obmd1 is offline
only one screen name
Send a message via AIM to obmd1
Mein Auto: '15 F80 M3
I had the same issue. Not so much that I could see, but it leaked like a seive through a car wash, and was quite noisy at highway speed. Its the door. Go to the ealer, and they'll tweak the hinges to help fitment.
Hope this helps, let us know.
OB
Old 04-07-2008, 09:39 AM
OB
Door alignment, there's something I'll think about. Will check the obvious things like loose mounting screws inside door 1st though I think.
Old 04-07-2008, 09:55 AM
obmd1's Avatar
True. My car was delivered new like that, so yours may be the result of wear and tear... but still.
Old 04-23-2008, 09:56 AM
Found the reason why:
http://forum.e46fanatics.com/showpos...97&postcount=8
Old 04-18-2009, 08:06 AM
jadyejr's Avatar
jadyejr jadyejr is offline
John
Mein Auto: 2008 535xi
I'm having the same problem with mine...... It is annoying...
2008 BMW 535xi
Old 01-04-2013, 12:56 PM
toakenspy toakenspy is offline
Mein Auto: BMW 318ci Coupe
Just beware. I was driving home one night from work, noticed my door window hadn't closed properly at the top corner, I pulled over, got out and gave it a very light wiggle and the whole thing shattered and came off in my hand. I had to wait 3 days for Autoglass to order and fit a new one costing my glass excess of 75. Best to lower the window a little, open the door, put the window back up and close the door again.
Old 01-04-2013, 01:06 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Aye....still drunk from New Year`s, are ya ???
(You`re responding to a thread *from five years ago*)
The road goes ever onward....
(R.I.P. Jever)
Old 01-04-2013, 02:47 PM
If only that were the reason, lol.
