Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series > E21 (1975 - 1983)
E21 (1975 - 1983)
Old 04-09-2008, 04:10 PM
Unique320i Unique320i is offline
Mein Auto: 1979 Modified 320i
Rear Disc Conversion
Hey everybody. I have some rotors and 4 big beefy calipers sitting around at storage. i am planning on putting the larger calipers on the front. so my question is what do i have to do to first, change the front calipers, and second, switch over to discs in the rear? thanks.
In the event of brake failure or loss of control, consult with you nearest wall.
Old 07-29-2008, 09:34 AM
dictator dictator is offline
Send a message via AIM to dictator Send a message via Yahoo to dictator
Mein Auto: 1982 BMW 320iS
I too have considered installing disc brakes in the back. But it would require, according to my BMW mechanic adding brake lines, new distributor quite alot. He said that if I have to ask... well you know.
Old 09-26-2008, 03:12 PM
dhlthr dhlthr is offline
Mein Auto: 1979 320/6 Baur
If you can find 323i rear trailing arms they have rear disc and the arms are a direct bolt on. I switched mine with the trailing arms and then modified e30 caliper to fit rear. I also have the famous volvo girling calipers on front.
Old 11-03-2008, 02:57 PM
Could you use the equipment off a 5-series for that era?
