E34 (1989 - 1995)
Old 04-11-2008, 02:49 PM
shellback85 shellback85 is offline
Mein Auto: 92 BMW 525i
What's the correct oil capacity of a 1992 525i?
Does anyone know the oil capacity of a 1992 525i? I'm changing the oil myself, and want to be sure that I am replacing it with the right amount. Also, what type of oil is best for this type of Bimmer?
Old 04-14-2008, 05:57 AM
bimmer dot info bimmer dot info is offline
The Biggest P0st Whore!!
Mein Auto: 2008 MS3
You should be able to get close to 1.5 gal (6Qt) but you should check as you are filling incase you have sludge buildup or anything else that might cause the level to end up higher.
15W40
Old 04-14-2008, 06:01 AM
Bluebimma Bluebimma is offline
Mein Auto: 325ti
The filling capacity is 6.7qts, but you cant get every drop of oil out of engine before refilling, so buy 7qts of oil.
BimmerDotInfo - Any reason to use 15w40? I use 0w30 in my m50.
OBDII to OBDI, M50B25NV, 3.25LSD Rear, AKG Poly-diff mount, ///M3 Brakes + LCAB's, 17x8 MM-2, ACS Strut Bar, ///M3 H&R + Intrax Springs, P/S+A/C+ASC+EWS Delete, OBDII Headers, OBDI Mids, 2.25" Dual Exhaust, Shadow Kidneys, Mtech Front Bumper Assembly, Mtech Side Mouldings, DEPO Headlights, Prolumen 6000k, Nightshade Exterior Lighting, 20% Tint, JVC Headunit, Rockford Fosgate, UUC shift knob
Old 04-14-2008, 06:44 AM
Mein Auto: 2008 MS3
15W40 is what the manual recomends. It has never given me any problems. I do not see any big problem with running 0W30 but if i was going to switch to a 0Wxx type oil I would use 0W40.
Thanks for posting the exact capacity. I couldnt remember what it was off hand.
Old 04-14-2008, 06:52 AM
Mein Auto: 325ti
Ah, i see. I ran 0w30 because that was what was used in my old m44 by the previous owners so i decided to use it in my m50. So far, so good.
Old 04-14-2008, 10:59 AM
johntheboy johntheboy is offline
Mein Auto: 5 Series
Specs according to the Haynes manual
Lubricants and fluids
Component or system Lubricant type/specification
Engine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Multigrade engine oil, viscositySAE 10W/40 to 20W/50, to API SG
Cooling system . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Ethylene glycol-based antifreeze with corrosion inhibitors
Manual transmission* . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Gear oil, viscosity SAE 80 to API-GL4, or single-grade mineral-based
engine oil, viscosity SAE 20, 30 or 40 to API-SG
Automatic transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Dexron ll type ATF
Final drive . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . BMW-approved hypoid gear oil, viscosity SAE 90**
Brake and clutch hydraulic systems . . . . . . . . . . . . . . . . . . . . . . . . . . Hydraulic brake fluid to SAE J 1703 or DOT 4
Power steering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Dexron ll type ATF
* E34 520i & 525i with air conditioning, E34 530i & 535i - Dexron II type ATF)
** Only available in bulk; refer to your BMW dealer
Capacities*
1•3
1
Engine oil
M10 engines . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.0 litres
M20 engines . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.3 litres
M30 engines . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.8 litres
M40 engines . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.0 litres
Cooling system
M10 engines . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.0 litres
M20 engines . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.5 litres
M30 engines . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.0 litres
M40 engines . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.0 litres
Fuel tank
3-Series, E30
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 55 litres (early),
64 litres (later)
Estate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 63 litres (early),
70 litres (later)
5-Series
E28 (“old-shape”) . . . . . . . . . . . . . . . . . . . . . . . . 70 litres
E34 (“new-shape”) . . . . . . . . . . . . . . . . . . . . . . . 81 litres
Manual transmission
ZF . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.2 litres
Getrag . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.0 to 1.5 litres
Automatic transmission (refill)
3-speed . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.0 litres
4-speed . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.0 litres
Final drive capacity (drain and refill)
3-Series, E30 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.9 litres
5-Series, E28 (“old-shape”) . . . . . . . . . . . . . . . . . . 0.9 litres
5-Series, E34 (“new-shape”) . . . . . . . . . . . . . . . . . 1.7 litres
Old 04-14-2008, 11:40 AM
KrankE34 KrankE34 is offline
Send a message via MSN to KrankE34
Mein Auto: E34 M5, 1995 E36 325is
changing the oil
so i am also geting ready to change my oil my self me question is, i had to get a new motor put in my 1990 525I (well new to me) all the seals and such were done but should i put a syn oil in or maybe a 10W30 or still the 15W40 ? or is there anything i can do to condition the motor, to keep it happy and running smoth
Old 04-15-2008, 05:06 AM
attack eagle attack eagle is offline
No more e34!
Mein Auto: Nikes + Mongoose
6 quarts of oil.
Depending on your temps you can use 15w40 or 20w 50. It has been too warm here for 10w40 for a month now.
Still cruising after all of these years...
now on iOS 9 (saves gas)
Mutual Admiration Society
Member #5
Old 04-16-2008, 03:31 PM
Thanks for your help guys!
Thanks for the help with my oil question. I really count on this site to get some some really good non-bull**** feedback, and you guys have really been a good reference.
