E36 (1991 - 1999)
Old 04-20-2008, 07:44 AM
328ioc's Avatar
328ioc 328ioc is offline
Mein Auto: E36, Imola ZHP
100 Watt fogs
hey guys im just wondering if any one has put 100 watt bulbs in your fogs. i would like to do this but i dont see the point if im gonna start blowing a fuse every time i use them so if any one has had any success please let me know. thanks!
SYNracing Inc.
Old 04-20-2008, 07:47 AM
Boile Boile is offline
Mein Auto: .
Why don't you change to a bigger fuse then?
Stop the madness: U.S. National Debt Clock
‹(•Ώ•)›
This post is brilliant. Completely spot on and chock full of useful information. Pure genius and original.
- Frank Rizzo
Old 04-20-2008, 09:22 AM
oakley's Avatar
oakley oakley is offline
The Dakar Dream
Mein Auto: bmw compact 2000 e36
And the replace the wiring through out as its not built to carry that much and will catch fire!!
18" MV Alloys. AC Schnitzer exhaust. CCFL Angel eyes. 6500K HID's. Rogue Engineering RSM's. EBC Turbo discs and Greenstuff Pads. Retro fit dimming mirror. M style indicator wing mirrors. Carbon Fibre GT splitter. Carbon kidneys grills. Alpine IDA-X001 Ipod headunit. M3 leather gaitors. M pedals. Illuminated M gearshift. Reiger rear spoiler. Shark fin.
www.forum.edirty6.com
Old 04-20-2008, 10:17 AM
Mein Auto: .
So the point against using a 100W bulb is that the wiring won't support it, not that the fuse won't (that's as simple to fix as it comes).
‹(•Ώ•)›
- Frank Rizzo
Old 04-20-2008, 10:50 AM
328ioc's Avatar
ok so your saying i cant and shouldnt put a 100 watt bulb in? correct?
SYNracing Inc.
Old 04-20-2008, 11:08 AM
Mein Auto: .
Correction.
You can, but probably shouldn't.
‹(•Ώ•)›
- Frank Rizzo
Old 04-20-2008, 01:54 PM
oakley's Avatar
The Dakar Dream
Originally Posted by Boile View Post
Correction.
Couldn't have worded it better if I tried!!
Old 04-20-2008, 02:50 PM
328ioc's Avatar
ok thanks guys!!
SYNracing Inc.
Old 04-20-2008, 04:32 PM
olskoolm3 olskoolm3 is offline
Mein Auto: 95 325is
he's gonna try it
Old 04-20-2008, 04:38 PM
Mein Auto: .
ok thanks guys!!
Hope is not all lost.
Since you played nice, here's a tip for ya.
I can recommend these. They do work as advertised, but don't expect them to be as bright as a 100W bulb.
http://cgi.ebay.com/ebaymotors/TOSHI...QQcmdZViewItem
‹(•Ώ•)›
- Frank Rizzo
Old 04-21-2008, 05:43 AM
Chris S Chris S is offline
Mein Auto: 1997 323i
get one of those bulbs which is rated normal but gives a boosted output ie for my headlights i have 55w-->110w
Old 04-21-2008, 06:10 AM
Mein Auto: .
You're wasting your money.
Think about it... where does the boost in power come from, if not from the wires? Bulbs don't create energy in itself.
‹(•Ώ•)›
- Frank Rizzo
Old 04-21-2008, 06:13 AM
thought they worked like those energy saver bulbs which boost the power from like 20w to 100 in the household
Old 04-21-2008, 01:27 PM
328ioc's Avatar
yep im an idiot guys i totally forgot to include a semi large piece of info. i have aftermarket fog so they use a H3 bulb so thanks anyway Boile but that ebay find wont help. ill just stick with the 55 watt bulbs its no biggie i was just wondering if it could be done with out having to do anything more than changing the bulbs. thanks again guys!!
SYNracing Inc.
Old 04-21-2008, 01:35 PM
Mein Auto: .
Compact fluorescent and incandescent filament bulbs are two very different technologies.
HID uses only 35W but put out more light than 65W halogens incandescents. But they're not interchangeable.
55W = 110W using the same technology is just pure marketing
‹(•Ώ•)›
- Frank Rizzo
Old 04-21-2008, 04:01 PM
ok thanks man
Old 04-22-2008, 07:28 AM
jason_recliner's Avatar
jason_recliner jason_recliner is offline
Don't ask me, I'm a sofa.
Mein Auto: Bostongrόn 1995 320i
+1
These lamps still appear to use a tungsten halogen filament. They will almost certainly put out the same light flux.
This coating (a titania/silica, zinc oxide/silica, zirconia/silica, silicon nitride/silica, and titania/magnesium fluoride tantalam/silica multi-layer dielectric, according to the patent) reflects a portion of the infrared energy emitted by the filament back onto the filament, causing it to glow brighter and emit more light from the uncoated forward portion of the bulb. Although the filament gets hotter, the glass does not.
Sounds dodgey to me. And way to much "personal testimonial" to be believable.
"The Wheelie Bin" - 1995 320i Boston Green
A word on our sponsors: Iridium sparks thanks to NGK. #42 wheels are lovingly dressed by Yokohama C-Drive. The dark road ahead is turned into daylight by Eagle-Eye 6000K HID, supplemented by 7000K CCFL Angel eyes. HB/Fog have selected to go with Philips 4000K BlueVision. Engine parts choose to slip and slide with Castrol's finest 20-50 GTX genuine dinosaur slime, renewed every 10,000km.
Old 04-22-2008, 10:40 AM
Mein Auto: .
Originally Posted by jason_recliner View Post
+1
You're referring to the HIRs that I mentioned above.
You seem not to understand the technical advantage that's described in what you quoted. Some energy is lost in the form of heat. HIRs capture that heat and put it back into the filament. There's no hocus pocus magic 55W=110W. Just capturing wasted energy and turning it back into light.
I have them installed in my car. I replaced one side with HIR and left the other OEM. I can certainly tell you that they are brighter than the factory halogens. I am in no way associated with the manufacturer nor the seller.
I read about them in an issue of Roundel magazine. There was certainly no personal testimonial there. The author of that article did a comprehensive and scientific test of several bulbs available in the market at the time, including the PIAA 55W=110W and others. His test methodology seemed good enough for me. His recommendations was HIR as the only one that worked. All the others were a waste of money.
This topic has been discussed here plenty. Search the forum with keyword HIR. You may even find some posts by that author of the Roundel magazine.
‹(•Ώ•)›
- Frank Rizzo
Old 04-22-2008, 11:39 AM
B/\/\W's Avatar
B/\/\W B/\/\W is offline
Monacoblau mit beige
Mein Auto: E92 330i Manual
Surely it will just create a positive feedback loop and blow itself out? IR is reflected back into the filament which heats it up and it glows brighter, bulb emits more IR, reflected back, bulb gets even hotter and goes 'nuclear'.
It should be noted I haven't read up on HIRs yet.
What is the point of having brighter than normal bulbs anyway? Oh to blind oncoming traffic, ok I understand now.
330i SE coupι
Manual - N52K 262hp, 232ft-lb
Old 04-23-2008, 01:42 AM
think thats the type i was talking about
