E36 (1991 - 1999)
Old 04-20-2008, 04:29 PM
sethmsk88 sethmsk88 is offline
Mein Auto: 1993 BMW 325is
Unhappy Keep blowing fuse. Please Help.
Hi,
My car keeps blowing the fuse that controls the illumination of the instrument cluster. Oddly, this fuse also controls the front right parking light and the back right tail light. So everytime I replace the fuse and I turn on the lights, it will blow immediately. This is no good for when it is dark, because I can't see how fast I'm going, and also, I could get pulled over for having a tail light out. I've tried pulling the instrument cluster out and checking to see if there was a loose connection or something, but I made no progress. I have been considering buying a replacement instrument cluster, but I would be very irritated to find out once I have bought it that it is not actually the problem.
So any help would be greatly appreciated.
Old 04-21-2008, 01:15 AM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
Check the trunk to trunk lid wiring where it bends most sharply approaching the trunk lid. The wiring inside the rubberized sheath may have split and shorted.
And stop replacing that fuse. You may replace a fuse exactly once to check if it had aged and failed. Thereafter, you find the short before some other, me$$ier thing happens. Good luck!
Old 04-21-2008, 02:58 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Originally Posted by johnf View Post
And stop replacing that fuse. You may replace a fuse exactly once to check if it has aged and failed. Thereafter, you find the short before some other, me$$ier thing happens. Good luck!
+1!!! Regardless of what is affected, where the problem may be, etc, a fuse that repeatedly blows means you have a larger problem. You may be lucky so far that the wiring has shorted out something more costly, and if you keep replacing that fuse you're allowing more and more chances to cause more damage. And if you haven't noticed yet, you will soon: BMW's are not one of the cheaper makes to replace things on!
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 04-23-2008, 06:12 PM
Ok, I will check the wiring there. Thanks for the advice. Now I can save money on fuses too.
Old 04-23-2008, 06:32 PM
doomed doomed is offline
Mein Auto: '96 320 cabio auto
I had the same problem not long ago, found out it was a wire going to my headlights
Old 04-24-2008, 03:03 PM
Hmm, I checked the wiring to the trunk lid and it looks undamaged. I will check out the headlights, but I am not having issues with the headlights, so I don't see how that could effect it.
