E36 (1991 - 1999)
Old 04-21-2008, 09:50 AM
James Hawk James Hawk is offline
Mein Auto: 1993 325I
New BMW owner 325I
Hello everyone,
My name is James I just pick up a 1993 325I with 125,000 miles on for $700 bucks. It was a car that was repossess from Texas. It has no rust thatís and that a good thing since I live in Ohio. The body has some dents on it and the hood is bent up a little bit right in front on the emblem someone was probably trying to still the BMW emblem.
I never owned a BMW before. I had always owned fords and I still have a full size ford bronco. The problem with the bronco it get about 12 MPG thatís not good.
The 325 was not running when I got it she wouldnít event turn over. After searching on Bimmerfest I figured how to jump it and I got it started I than replaced the battery. She would not idle at all I to keep giving her gas to stay started. So the next day I did a tune up replaced spark plugs changed gas filter along with the air filter. The air filter was in bad shape you couldnít even see through it. I cleaned the MAF sensor. Couldnít fine the IAC sensor so if some one could tell me where to look for it that would be great.
After doing the tune up and changing the oil which it look like it hasnít been changed in a long time. The car runs great no more rough idle I got all my info I need to do the tune up by searching on Bimmerfest web site. I took it on a trip to Cleveland and the onboard computer was saying I was getting 26.7 MPG wow thatís great.
The sunroof doesnít want to work. On side is setting below the roof line in think thatís why it wonít working. I did some searching and found a couple articles about sunroofs not working and tired some ideas but not thing has worked yet I tried holding the button closed to 15 to 20 seconds and nothing I can hear the motor running.
Iíll keep searching. I will be picking up a Bentley auto repair manual. So I can do most of the work myself I enjoy working on my own vehicles
James
ID:	144420   Click image for larger version
ID:	144421   Click image for larger version
Old 04-21-2008, 10:19 AM
Roman-O Roman-O is offline
Mein Auto: e36 328i & e30 325i
Post some pics of bimmer.
Old 04-21-2008, 11:07 AM
here is some more pics i'll do more later its a nasty day here plus i need to clean her up a bit.
ID:	144435   Click image for larger version
ID:	144436   Click image for larger version
ID:	144437   Click image for larger version
ID:	144438   Click image for larger version
Old 04-21-2008, 11:17 AM
ColumbusBMW ColumbusBMW is offline
Always protect your nuts!
Mein Auto: '94 325is
James,
Welcome to the fest. Also, check out ohiobimmers.com. There are a lot of us local. You have a great resource for used parts in Dover. It is called All Quality. It is over behind the fairgrounds.
The sunroof problem is most likely due to broken or worn lift blocks. There are many DIY's for this.
Old 04-21-2008, 11:34 AM
E36youngster's Avatar
E36youngster E36youngster is offline
blank
Mein Auto: 07 e92 335i
Originally Posted by James Hawk View Post
Hello everyone,
I had a 95 Eddie Bauer edition before i bought the bimmer. 3inch lift, 351 crate engine, 36s....i know where you're coming from about gas mileage haha.
As long as there's nothing really major wrong with your new purchase, i say you have gotten a sweet deal man!
Welcome to the Fest
Old 04-23-2008, 03:05 AM
still no luck on the sunfoor she does not want to move. does any one have any suggestions. plus i still cant fine the idle air control valve.
James
