BMW Service bulletin on High Pressure fuel pump - Bimmerfest - BMW Forums
Old 04-21-2008, 02:38 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
PERFORM THE PROCEDURE OUTLINED IN THIS SERVICE INFORMATION ON ALL AFFECTED VEHICLES THE NEXT TIME THEY ARE IN THE SHOP FOR MAINTENANCE OR REPAIRS.
SUBJECT
Service Action: Replace the High-Pressure Pump
MODEL
E90, E92, and E93 with the N54 engine produced from 06/01/2006 through 10/28/2006
SITUATION
An internal component in the high-pressure pump (HDP) may fail, causing drivability symptoms such as longer starting times or erratic engine operation. It may also lead to a premature failure of the HDP on vehicles at higher mileages.Should this situation occur, the HDP emergency operation is activated and the Service Engine Soon lamp (MIL) is illuminated.Note:In this situation, the vehicle can continue to be driven, even for long distances, without any risk of breakdown.
AFFECTED VEHICLES
This Service Action involves E90, E92 and E93 vehicles with N54 engines which were produced from 06/01/2006 through 10/28/2006.In order to determine whether a specific vehicle is affected by this Service Action, it will be necessary to utilize the "Service Menu" of DCSnet (Dealer Communication System) or the Key Reader. Based on the response of the system, either proceed with the corrective action or take no further action.The chassis number ranges listed below are only for informational purposes and are not to be considered as the only deciding factor.*******>********> *******>********>*******> ********>
Model
Chassis Number Range
E90
FV75004 – FV75116
E90
KY60007 – KY60964
E90
PA65001 – PA87847
E92
P021102 – P032114
E92
PV80038 – PV83999
E93
PX45010 – PX45013
CORRECTION
Replace the high-pressure pump.
PROCEDURE
Please refer to TIS Repair Instruction RA 13 51 017, Removing and installing, or replacing high-pressure fuel pump (N54, N53).
PARTS INFORMATION
Part Number
Description
Quantity
13 51 7 585 655
High-pressure pump
1
11 61 7 547 242
Profile seal set
1
13 53 7 582 770
ASA bolt M8X17.5 - AL
1
LABEL INSTRUCTIONS
This Service Action has been assigned code number 518. After the vehicle has been checked and/or corrected, obtain a label (SD 92-335) and:
  1. Emboss your BMW center warranty number in the middle of the label (1);
  2. Punch out code number 518 (2), printed on the label; and
  3. Affix the label to the B-pillar as shown.
If the vehicle already has a label from a previous Service Action/Recall Campaign, affix the new label next to the old one. Do not affix one label on top of another one, because a number from an underlying label could appear in the punched-out hole of the new label.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.*******>********>*******>********>*******>********>
Defect Code:
00 13 77 01 00
Labor Operation:
Labor Allowance:
Description:
00 57 904
E90, E92
17 FRU
00 57 904
E93
19 FRU
http://www.bmwtis.com/tsb/bulletins/...p/B130308g.htm
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 04-21-2008, 02:39 PM
interestingly, this bulletin covers cars only produced in munich and regensberg.
Old 04-21-2008, 03:56 PM
Erregend's Avatar
Erregend Erregend is offline
535i M-Sport ED May 2011
Mein Auto: '11 M-Spt 535i & '04 SLK
Try this one: http://www.bmwtis.com/tsb/bulletins/...p/B130208g.htm
Old 04-21-2008, 04:17 PM
argh, and here are the rest of them... my vin falls into the range
SI B13 02 08
Fuel Systems
February 2008
Technical Service
SUBJECT
Service Action: Replace the High Pressure Pump
MODEL
E90, E92, and E93 with the N54 engine, produced from 01/17/2007 through 01/25/07
SITUATION
An internal component in the high-pressure pump (HDP) may fail, causing driveability symptoms such as longer starting times or erratic engine operation. It may also lead to a premature failure of the HDP on vehicles at higher mileages.Should this situation occur, the HDP emergency operation is activated and the Service Engine Soon lamp (MIL) is illuminated.Note:In this situation, the vehicle can continue to be driven, even for long distances, without any risk of breakdown.
AFFECTED VEHICLES
This Service Action involves E90, E92 and E93 vehicles with N54 engines which were produced from 01/17/2007 through 01/25/2007.In order to determine if a specific vehicle is affected by this Service Action, it will be necessary to utilize the "Service Menu" of DCSnet (Dealer Communication System) or the Key Reader. Based on the response of the system, either proceed with the corrective action or take no further action.The Chassis Number Ranges listed below are only for informational purposes and are not to be considered as the only deciding factor.*******>********> *******> ********>
Model
E90
P100339 – P100668
E90
PA65965 – PA66015
E90
VF49706 – VF52378
E92
P022744 – P033837
E93
PX45170 – PX45288
CORRECTION
PROCEDURE
Please refer to TIS Repair Instruction RA 13 51 017: Removing and installing, or replacing high-pressure fuel pump (N54, N53).
PARTS INFORMATION
Part Number
Description
Quantity
13 51 7 585 655
High-pressure pump
1
11 61 7 547 242
Profile seal set
1
13 53 7 582 770
1
LABEL INSTRUCTIONS
This Service Action has been assigned code number 514. After the vehicle has been checked and/or corrected, obtain a label (SD 92-335) and:
  2. Punch out code number 514 (2), printed on the label; and
  3. Affix the label to the B pillar as shown.
If the vehicle already has a label from a previous Service Action/Recall Campaign, affix the new label next to the old one. Do not affix one label on top of another one because a number from an underlying label could appear in the punched-out hole of the new label.
Covered under the terms of the BMW New Vehicle Limited Warranty.*******>********> *******> ********>
Defect Code:
00 13 76 01 00
Labor Operation:
Labor Allowance:
Description:
00 57 894
E90, E92
17 FRU
00 57 894
E93
19 FRU
[ Copyright © 2008 BMW of North America, LLC ]
Old 04-21-2008, 04:35 PM
Kamdog's Avatar
Kamdog Kamdog is offline
<- Bailey
Mein Auto: 2008 535i
E60, yay!
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 04-21-2008, 04:42 PM
djfitter's Avatar
djfitter djfitter is offline
Mein Auto: BMW '08 535i
Originally Posted by Kamdog View Post
E60, yay!
+1 Me too, Yay.
dj
'08 535i
Deep Sea Blue
Cream Beige
Dark Poplar
6 Sp Manual
Sport
Premium
Rear Shades
BMW CCA #392316
Old 04-21-2008, 06:59 PM
c.dude c.dude is offline
Mein Auto: BMW 335i
now where can i find the chasis number ?
Old 04-21-2008, 07:47 PM
raleedy's Avatar
raleedy raleedy is offline
Mein Auto: 2016 228i 6-speed
If you remove the exhaust system, you should find it stamped on a cross member behind the fuel tank. Be sure to empty the fuel tank before you remove it.
j/k
check your dashboard by the lower left corner of the windshield, or the driver's door jamb. What they mean by the chassis number is the VIN (in this case, the last seven digits of it).
Old 04-22-2008, 06:47 AM
mrbelk mrbelk is offline
Send a message via MSN to mrbelk
Mein Auto: 07 335i/6sp
Interestingly enough, my chassis number matches the VFxxxx range in the SIB130208 bulletin, but my vehicle was produced in April of '07 and not during that one week timespan specified. I guess it's not so much the production week of the vehicle as it is the production week of the engine, that was then installed in vehicles having the aforementioned production week. It's interesting that my motor sat for over 2 months before being installed in my car.
I have almost 10k miles and not one hint of a HPFP problem, so I am very leery of having any work done, although I will have to take the car in to have the 6FL ipod scrolling and FM autoswitching issues fixed, so I guess they will perform this action, too.
-MrB
(ED 5/11/13) '13 328i M-Sport Estoril Blue II/Black, Trip Journal
(ED 5/25/10) '11 335i M-Sport Le Mans Blue/Oyster, Trip Journal
(ED 5/19/08) '08 X3 3.0si Alpine/Tobacco, Trip Journal
(ED 5/7/07) '07 335i/6sp TiAg/Lemon, Trip Journal
(ED 4/18/05) '05 X3 3.0 Blue Water/Black, Trip Journal
(ED 4/28/04) '04 545i Silver Gray/Beige
Old 04-22-2008, 07:42 AM
SonomaDriver's Avatar
SonomaDriver SonomaDriver is offline
BigTime Defender
Mein Auto: 2015 428i Convertible
Pats his 1/08 production date 335i.
Current Ride:
Estoril Blue, Black Dakota w/Blue, Premium, HK Sound, M Sport
Pkg, Heated Seats
Former BMWs
2011 X5 35d
Sapphire w/Beige Leather
Premium, Cold Weather, Technology, Premium Sound, and Sport
Packages. 19" wheels, LUX H8 v3 DRL Upgrade
2008 335i Coupe
ZPP,ZSP, 6FL, 4AS, 2XA, Sirius, Nav, Heated Seats
-Space Grey Metallic w/Grey Dakota Leather
Old 04-22-2008, 07:55 AM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is offline
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
Old 04-22-2008, 10:10 AM
does anyone know if the HPFP replacement requires removal of the front bumper for access?
Old 04-22-2008, 01:38 PM
x986 x986 is offline
Mein Auto: 340i
And what do you have hidden there?
Old 04-22-2008, 01:39 PM
jfulcher's Avatar
jfulcher jfulcher is offline
Mein Auto: 07 E92
-MrB
It's not when your car was produced it's when the engine was produced.
335i E92 / Monaco / Cream / Burl Walnut / ZPP / ZSP / CA / Nav / Heated Seats / PDC / SAT / Ipod/USB / HD
ED Pickup: 04/11/2007
Back in my posession: 5/29/07
Old 04-22-2008, 02:15 PM
Yeah, I came to that realization during my stream of consciousness post.
FWIW, I went over to United BMW of Roswell at lunch to try to pick up some coupons for the AJC car show (they didn't have any) and went ahead and made an appt. to get my 6FL FM switching issues corrected and the key reader didn't report any active campaigns for my vehicle.
Even though my VIN matches the range in the SIB, I guess that the list is not totally inclusive, in that there could be unaffected 335i's in those VIN ranges and mine must be one of them.
-MrB
Old 04-22-2008, 02:17 PM
PhilipWOT's Avatar
Turn Burglar
-MrB
Bulletins are not recalls. Bulletins only come into affect if/when your car runs into that problem.
Old 04-22-2008, 03:15 PM
NOS IC spray, and my flux capacitor.
i have the ballasts for my HID fogs (i use them as driving lights to illuminate the road right in front of the car, very helpful in dodging NYC potholes) VHB taped to the bumper, but the bulb failure eliminators attached to the brake ducts. if they need to pul the bumper, i'll attach the eliminators to the inside of the bumper so it'll be an easy remove for them. what i dont want is for them to pull the bumper and get surprised when the brake ducts get yanked out with it.
from what i'm guessing, the HPFP is on the bottom front of the engine block, so they just need to remove the underbelly panel to get to it.
Old 04-22-2008, 04:19 PM
johnc_22's Avatar
johnc_22 johnc_22 is offline
Squeal like a BMW
Mein Auto: 2013 Audi A4
E90 VF49706 – VF52378
Uh oh . . .
2013 Audi A4 - Premium+/Sport/MMI/B+O Audio
2007 BMW E90 335i (retired)
Old 04-23-2008, 02:05 PM
Stinger44's Avatar
Stinger44 Stinger44 is offline
No HPFP problems yet!
Mein Auto: 2008 Black 335i MT Coupe
This doesn't explain the 08 builds right? Some of those are experiencing this problem.
2008 Black 335i coupe MT
2010 Black Legacy 3.6R
Old 04-23-2008, 02:39 PM
johnc_22's Avatar
Squeal like a BMW
I wouldn't be surprised if they are hitting the VIN ranges where failure is most likely to occur first, and I would guess that while there have been some 2008 failures, it's nothing like the first batch of cars in MY2006-2007. I remember after I'd ordered my car for ED back in early 2007 there were daily posts of people limping to the dealer and waiting a very long time for a replacement pump.
I'm just glad to see official acknowledgement of the problem by BMW.
Old 04-23-2008, 03:21 PM
rwg rwg is offline
Mein Auto: '14 A4
My '08 vin number appears to fall into the numbers listed for the '06 builds. I wonder what that means. It's either a conspiracy or an indication that I don't really understand where that number is coming from. I am betting conspiracy.
Old 04-23-2008, 04:29 PM
invariant's Avatar
invariant invariant is offline
Mein Auto: 2008 335i
VIN contains more than those last 5 digits, so the model year comes in the previous part. The last 5 digits are just a production counter, IMHO. My '08 also falls into the range of VF49706–VF52378.
2008 E90 335i 6MT + SSK + CDV-delete / ZSP / aluminum / black leather / Conti DW + compact spare / integrated portable nav plus
2005 E83 X3 Auto
Old 04-23-2008, 04:43 PM
Correct
the 10th digit of the VIN is the model year
the 11th digit is the assembly plant
digits 12-17 are the chassis serial number
so a MY 2007 car, produced in leipzig, with a serial number of F02103 would have a vin that looks like:
7VF02103
Old 04-23-2008, 04:48 PM
rwg rwg is offline
Mein Auto: '14 A4
So it IS a conspiracy!
Old 05-09-2008, 07:34 PM
rgage2u rgage2u is offline
Whoa this car is fun
Mein Auto: 2007 E90 335i
I had my 335 in today to replace the front windshield (rock cracked it). They said mine was impacted and replaced it. No problems and good service (Kuni, Portland, Oregon).
Taba and Tom rock Germany
