Old 04-21-2008, 06:29 PM
Sonoman707 Sonoman707 is offline
Mein Auto: 2008 X3 3.0si
Results of Inspection II / 62, 350 Miles
Took the X3 in for it's Inspection II. I had purchased the extended maintenance back when I was around 48K with the intention of driving/keeping the X3 for at least 100K. By my calcs on known maintenance items likely to need service & their costs - I would come out about $400 - $500 ahead by going with the extended maintenance program.
All of the standard inspection items performed plus new wiper blades front & rear. The diagnostic system is checked for any fault codes, etc. as a part of that.
At some point - a fault code was thrown indicating degraded transfer case oil. So - the transfer case was serviced with new oil as well.
Not sure what that item would have cost out of pocket, but it's one step closer to making the extended maintenance a good investment (for me).
I checked the manual... I'm not seeing a spec for the life of the transfer case oil, etc. Anyone know? I also wasn't aware that would throw a fault code when it needed service. I guess some parts of the "brain" do function well after all.
Old 04-21-2008, 06:50 PM
Also - they had just received two new X6s today.
Not sure about it yet... looks ultra-beefy from the back. The front, from the bottom of the windshield down looks just like the X5. Actually... except for some minor design pieces... it looks just like the X5 from the door handles down - front, side & back.
One was $54K... the other was $65K (beefier tires / rims the visual difference).
Pretty cool... but the rounded/sloped roofline looks a bit out of place with the angular design incorporated into the rest of the body design. Also - the tiny back window makes the rear view very tight.
Inside - pretty much an X5 as well. I'm sure it drives like a dream though.
Old 04-22-2008, 03:24 PM
bmwadam bmwadam is offline
Long LIVE ZFHP22!
Mein Auto: 2006 330i 6MT Sport
Perhaps your transfer case was leaking??? I though BMW used its "lifetime" fluid in the transfer case. I know they do for rear difs. My 04 3.0 only has 34k on it right now but I was planning on changing all the driveline fluids at 40 k anyway... If your transfer case was leaking, then I could see how it would trip a fault code.
The DIYer BMW rant:
Cursed plastic impailor waterpumps, plastic bleeder screws, m20 timing belts, anti rattle clips, window regulators, CDV valves, digital odometer displays, evaporative emissions circuit, aux cooling fan, sunroof drains, heator cores, door seals, control modules, M62 cam covers and of course GM autos.... (more to come)
Old 04-22-2008, 03:58 PM
Vodka G Vodka G is offline
Mein Auto: ??
interesting,.....while we are on that issue, what type of fluid would you use for the rear diff, transfer case, and tranny for a 04 x3 3.0 auto??....is there anything else that's on the drivetrain that i should replace (in terms of fluid)??
i've got 57k miles on it and planning to do eveyrthing at 60k miles
Now -'12 VW Golf MK-VI 2.5 & 09' BMW M6
SUVs-'08 Acura RDX Tech -'04 BMW X3 3.0
2 doors -'01 Audi TT QC 6 spd -'01 Toyota MR-S - '06 BMW M Roadster
4 doors -'01 BMW 325i E46 -'96 MBZ C280 Sport
no doors- 00' Suki GS500
Old 04-22-2008, 04:18 PM
AzNMpower32's Avatar
Tar Heel Faithful
Send a message via AIM to AzNMpower32
Mein Auto: X3
Interesting. Bavarian Auto also recommends replacing the transfer case fluid at 60k (which I intend to request, along with an ATF flush).
Old 04-22-2008, 06:18 PM
Andrew*Debbie's Avatar
Andrew*Debbie Andrew*Debbie is offline
resU deretsigeR
Mein Auto: Z4 sDrive20i
The transfer case fluid is "lifetime". Changing it isn't on the schedule.
You can get the fluid from a dealer parts counter or mail order. It is about $30 for 1L bottle
BMW part number is 83 22 0 397 244
I don't know if there are alternatives to the factory stuff.
Renault Zoe reservation #313
The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change.
Old 04-22-2008, 07:47 PM
Nope - no leaks. Garage floor is as clean as my kitchen floor... and the bottom of the X3 is dry front to back. (Yup - I look under there on occassion.)
Old 04-22-2008, 07:56 PM
From the work order/invoice:
E** AS PER ATTACHED DME PRINTOUT - REPLACE TRANSFER CASE OIL
CAUSE: MAINTENANCE
24 REPLACED TRANS CASE OIL
315 WXMP
1 83-22-0-397-244 DISTRIBUTOR FOR TRANS. FLUID: 832251040
62631 REPLACED TRANSFER CASE OIL
