E36 (1991 - 1999)
Old 04-26-2008, 08:21 AM
bimmerking bimmerking is offline
Mein Auto: BMW E36 316 Coupe
E36 316 Oxygen Sensor
Hi guys hope you're all doing great. Just have a quick question, I've been told that maybe my O2 sensor's got a problem, but I can't seem to locate it AT ALL. I've tried searching online but not any luck as you can tell. Can someone PLEASE tell me where its likely to be located on a 316i? I know some of you dude's in the US didnt get that model but in Europe, there are loads i think. it'll be a massive help. thanks.
and also...
a few months ago, i read somewhere that you can't do any drifts with the 316i due to it being so heavy and small powered.. but just did a search on youtube n there are LOADS and even some 316i's with TURBO. Now while a lot of you may know this, its totally news to me, so i'm gnan keep hold of this for sure!
Old 04-26-2008, 12:12 PM
Someone PLEASE HELP! this oxygen sensor's driving me nuts. had another look under the hood, i've seen piks on google as to how it should look but can't locate it ANYWHERE under my hood!!!!!
Old 04-26-2008, 12:36 PM
joie_d_v joie_d_v is offline
Mein Auto: bmw325i cab
try ultimate-BMW.com
Ours is on the exhaust system
1995 325ic calypso rot
1999 Ford 150 xcab
2003 Ford Focus (dd)
Old 04-26-2008, 01:12 PM
Thanks Joie, am gnna give it a try right now, cheers mate!
Old 04-26-2008, 01:49 PM
Haelo Haelo is offline
Send a message via AIM to Haelo
Mein Auto: 94 325is
Oxygen sensors are always on the exhaust.
Old 04-26-2008, 04:29 PM
Thanks haelo, but am pretty much of a noob n this being my first proper car n all, am learning a lot still. when u say on the exhaust, do u mean the exhaust manifold? sorry if i'm confusing you but i have very basic understanding of the engine bay at the moment, so just trying to get to the point i suppose.
Old 04-26-2008, 04:52 PM
B/\/\W's Avatar
B/\/\W B/\/\W is offline
Monacoblau mit beige
Mein Auto: E92 330i Manual
Part numbers and diagram for 316i manufactured up to 01/1996 http://www.realoem.com/bmw/showparts...27&hg=18&fg=10
Part numbers and diagram from 01/1996 onwards http://www.realoem.com/bmw/showparts...27&hg=18&fg=10
Get the relevant part number for the O2 sensor, order it from the dealer or pick one up from a breaker's yard, fit it, or get someone to do it. It essentially slots into a hole in the exhaust before the muffler, although this diagram doesn't make it obvious how.
330i SE coupé
Manual - N52K 262hp, 232ft-lb
Old 04-26-2008, 05:09 PM
Mein Auto: 94 325is
When I say 'exhaust' in this sense I mean the exhaust system. Some cars have O2 sensors on the manifold, some on the pipe before and/or after the catalytic converter(s)
The O2 sensor is there to tell the engine computer how much oxygen is in the exhaust gasses so the computer can judge whether or not it's fueling correctly.
Old 04-26-2008, 05:15 PM
ah ACE!!! thanks a lot for the info BMW n Haelo, hopefully it'll be running perfect again in no time! much appreciated guys
