My rear subframe is out for other work (RTAB replacement). I am also hunting for the source of a clunk from the rear, and suspected my swaybar endlinks (they're solid type, won't last forever). Looks like it's actually my fuel tank. Common problem, many of my fuel tank strap cushions were out of place.
Here's a picture of the driver side strap as removed from the car. One cushion almost gone completely from the car, a second one out of place. This was a source of one clunk.
I removed the old cushions, cleaned up the strap and touched it up with spraypaint. Then applied McMaster-Carr 93275K36 foam.
And then some McMaster-Carr 7132K79 heatshrink to help keep it in place.
I'm doing the same for the carbon canister strap, and the passenger side fuel tank strap (which has two cushions in worse positions than what I found on the driver side). We'll see how long it holds up, but the source of clunking is fixed.
