#76
For the record, 540imsport wrote up a concise summary today over here:
- E39 (1997 - 2003) > creaking drivers seat/replacing seat trim Quote:
#77
Today, for the record, another person had the seat control module problem:
- E39 (1997 - 2003) > Help! Driver's Seat/Steering Adjustments Not Working For the record, here's what's in the bestlinks at the moment: - What to do when both your automatic steering wheel tilt and manual & automatic driver seat control fails (0) (1) (2) (3) (4) (5) (6) (7) (8) & related automatic steering wheel tilt details (1) (2) (3) |
#78
Sorry to bring out the old topic. I plan to replace my seat outer cover. How to remove the last screw to get the old cover out without removing the seat back? Any idea?
Live the e39..!!
#79
Hi, bluebee i have a 02 525 i with passenger seat issues and i am trying to find out what the fuse amperage is
#80
can you please help the fuse keeps burning out
#81
My car is a 99 528i so somewhat different but fuse 13 is a 30-amp green fuse. |
#82
If the plastic clip, here's what I do. The hole in the seat back that it fits into is hidden under the lower-left corner of the seat back cover, but that hole can be felt by hand, and if you wedge both hands (fingers) underneath the side cover at that spot and around that pin clip and squeeze-pull straight out and evenly with four fingers underneath and thumb outside, it will pop out. Install is easier, just position the pin over the hole and press in with thumb. It's harder to explain than actually doing it but it's key to apply force evenly and in a way that doesn't crack the flimsy cover plastic. I use no tools, just my fingers, but the trim tools that others have mentioned should also work, just that the leverage is different. When using my own fingers, it's easier for me to tell if I'm applying too much pressure or too unevenly, risking breakage. |
#83
I already took out the plactic clip and replaced the passenger side. Now facing another problem to take out the seat tilt adjustment level in drivel side.
Live the e39..!!
#84
- Where to find all E39 fuses and their values (1) (2) (WDS) (WDS.ru) & how to find the hidden front passenger seat undercarpet fuse panel (1) For the record, today the Bentleys failed another user who was trying to figure out how the front-most switch connects to the seat cover panel. QSilver7's response, as always, was so enlightening that I feel I must include it below for completeness. - E39 (1997 - 2003) > Driver seat depth thigh adjustment lumbar contour switch Quote:
#85
For the cross linked record, this information today may help someone in the future:
- E39 (1997 - 2003) > Driver's Seat Control Quote:
#86
I know this is an old thread but I had occasion to replace this trim panel today and found a method to deal with the plastic rivets. I checked the entire thread and didn't see the answer to this problem.
And I found it is not necessary to remove the seat back trim to release the rearmost rivet. There is no doubt that these rivets are TIGHT! I tried prying under the rivet heads with no luck at all. Visibility was minimal, space was tight and the force required was high. I kept slipping off the rivet. Quote:
Finally I did this. 1) removed the two torx head screws 2) raised the seat as high as it would go and as far forward. Then put the seat back as upright as it would go. It gave just enough visibility to see the locations of the 2 rear rivets from the rear seat footwell, especially with the new panel for reference. 3) inserted a tack puller (trim tool or screwdriver would work too) between the tab of the trim panel and the seat frame, not between the rivet head and tab. The rivets then popped out easily. 4) with the seat back upright, there was enough space to release the rearmost rivet and work the rivet and tab out of the pocket 5) moved the seat rearward ward and released the front rivet the same way The rivets can be removed from the old panel for reuse by sqeezing the barb end close to the head with a pair of pliers and pushing them through. It needs a tight sqeeze and a firm push. This is what was so tight; why I couldn't pry the rivet out in situ. For assembly, 1) insert all three rivets into the holes of the trim panel tabs, just as shown in Bluebee's picture. There is room to position the panel with the rivets in the tabs 2) position the panel on the seat and start the two torx screws. Just a few turns so they are locating the panel & won't fall out and get lost but will allow the panel to move easily 3) wiggle the tabs/rivets around until they enter into the holes of the frame; they will almost fall into place on their own, since the panel is positioned by the screws. Push each one home as it locates in the frame - they will seat quite easily. Front one from the front of course, the two rear ones from the rear seat area. Move the seat as convenient 4) tighten the two torx screws BTW, I found I didn't need to disconnect the seat control switch block from the harness connector/plug. After releasing the trim panel, there was lots of harness length for access to release it from the old panel and snap into the new one. Once I'd figured this out, it became a 10 to 15 minute job total. It just took me 45 minutes of frustration to work it out
Regards RDL |
#87
This is wonderful information!
Mine is broken again! I have the parts, but I didn't put them on yet. It's in the queue. When I find that round tuit, I'm going to follow your instructions & let you know how it goes (after I fix my driver side door window again, and my windshield washer, etc.). I'm hoping your hint above will be a wondrous blessing - because I never did figure out completely how to get it all back together properly!
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
#88
I came here after a long time away to find the bolt sizes for my seat cover since both my bolts and all four Christmas tree clips appear to be missing.
I wonder if we can just find a metric Phillips head bolt to replace the two T30 bolts? Quote:
I mean, I know it's 4mm in diameter and 10mm long - but how does 'that' tell us what threads it uses? 2002 525i => Seats => Front seat => SEAT FRAME W.ACTUATORS - Parts diagram line #11 Fillister-head screw M4X10, #07146977086, $0.48 - Parts diagram line #10 Clip, #52101873544 $0.20 EDIT: I just called the local San Jose BMW dealership who has the clips in stock for $1.94 each but not the bolts which are $2.20 each. (BTW, I've never found the local BMW dealership here in Silicon Valley NOT to be the most expensive for anything - even trivial parts like these.) Note: Googling, I find there is M4x10x0.7 (which is a course thread) and M4x10x0.5 (which is a fine thread). I just realized I can remove the bolt on the passenger seat and just match 'that' at Home Depot.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 11-20-2012 at 09:26 PM. |
#89
Doing a search for what other part numbers will fit, I found there is a really good (ancient) E39 seat-switch repair DIY over here:
> E39 (1997 - 2003) > Repairing Power Seat Switch-DIY Where users attempt to glue & reinforce & second source the seat switch control box components themselves.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 11-20-2012 at 08:08 AM. |
#90
It's actually a 4mm sheet metal screw that goes into a "U" clip. A good substitute is a #8 x 3/8". That would actually be 4.2mm x 9mm.
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 |
#91
Wow. I didn't know you can substitute a metric M4x10 with an SAE bolt.
#92
The screw that holds the seat covering to the frame actually goes into a U clip, not a threaded hole. So there's some tolerance in the fit. The major diameter of a #8 sheet metal screw is about 4.2mm. That's close enough to 4mm for the U clip on the seat frame. BTW, I noticed that the rectangular socket on the seat switch assembly in you photo is broken just like mine and the clip that holds the connector in is missing. Do you have problems with the connector coming out? I'm going to disassemble it all again and try to use a zip tie to hold the connector in the assembly.
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 Last edited by Steve530; 11-20-2012 at 07:36 PM. |
#93
I loved your example. Thanks for explaining 'cuz it didn't make sense otherwise.
Yes. I'd be interested in your fix.
#94
Hi all,
Thanks to all for your illustrations and help here. My sister's 2001 E39 seat cover broke the other week and I bought the covers and associated stuff from Pelican Parts but the trim removal tools from my local Snap On Tools supplier. Thanks to what you have here, I followed the instructions and it took me 30 minutes to remove and install the new one without any dramas. The only tricky bit was tring to locate the torn screw on the top of the seat towards the rear. Otherwise all good and it looks great. Thanks again all. Kind regards Michael |
#95
Torx screw not torn screw! It's the auto spell checker on the. iPad!
#96
The correct part # for the small black plastic rivets that the excellent post # 6 of PJB #6 is 52-10-1-873-544 per BMW dealer ( saw an other post where incorerctly it was posted to be 52-10-8-150-020 which is actually a metal screw and not related to seat side cover)
#97
One question : the bottom middle plastic "tongue" of the plastic side cover (Unforntunately was not able to see it ) : does it go into a socket before putting back the rivet, or simply seats on a metal piece on bottom of seat and is only held in place by the plastic rivet?
#98
Would the PVC primer and cement be the strongest glue to hold a small metal piece to the partialy broken plastic seat side cover ( meaning after gluing a small piece of metal to the damaged plastic use torx screw with the newly repaired piece to the metal part of the seat bottom.
#99
I saw a thread where the person used a metal channel piece to reinforce an unbroken cover. That part of the seat cover is 0.733 inches across,
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 Last edited by Steve530; 12-13-2012 at 02:54 PM. |
#100
Also, had trouble starting the screw on the front of the seat. I found I could use a small set of needle nose pliers to guide the screw into the U clip by reaching through the front inner side of the seat cover.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
