Old 05-03-2008, 06:50 PM
edrice edrice is offline
Mein Auto: 2006 325i
trunk locked
I'm on a trip with 4 people and luggage and the trunk will not open.
Could be a blown fuse since it doesn't make the solenoid noise when you
press the trunk unlock button on the key fob. But the key will not open it either.
Anyone have a guess? It will be a long trip back home tomorrow with suit cases
on our laps.
Old 05-03-2008, 07:08 PM
TGray5's Avatar
TGray5 TGray5 is offline
Ultimate Driving Machine
Mein Auto: '13 F10 550i; '13 R1200GS
on our laps.
Wow, that sucks. Yes, I'd check the fuse. If you have fold down seats with the ski bag, you can reach thru and release the seat backs and once inside the trunk you can pull the emergency release to get it open. It sounds like the key does not release a cable but is electrically controlled.
Are you sure no one has pressed the trunk lock over ride button inside the glovebox?
Old 05-03-2008, 07:23 PM
x986 x986 is offline
Mein Auto: 340i
My money is on you. Or behind door number two - Did OP mean the key button, or the real old fasioned metal key we all carry and forget we have?
Old 05-03-2008, 08:39 PM
Feel pretty dumb, yes it was the trunk over ride switch in the glove box. I didn't know it existed. My wife must have bumped it when putting something in the glove box.
Thanks Tgray5
Old 05-03-2008, 09:37 PM
Fredric Fredric is offline
Mein Auto: '07 328xiT
Thanks Tgray5
Yah sure, it's always THE WIFE's fault.
Have a safe trip home.
Old 05-03-2008, 10:16 PM
TGray5's Avatar
Thanks Tgray5
No Problem, glad nothing was broken.
Old 05-04-2008, 02:26 AM
jwac's Avatar
jwac jwac is offline
Mein Auto: '14 335i 6MT
Even with the glove box switch in the lock position, shouldn't the key in the trunk's exterior lock have opened it? That method doesn't use the solenoid and should always unlock the trunk. After all, it's the same key that unlocks the glove box to get to the lock switch anyway.
2014 335i Sedan 6MT
Estoril Blue | Black leather | Dark Burl Walnut
M Sport | Premium | Driver Assistance Plus | Technology | Dynamic Handling | Cold Weather | 19" 403M Wheels | M Sport Brakes | Harman Kardon | Rear Window Shades | Auto High Beams
09.16.13 European Delivery
Past:
2011 335i Coupe 6MT (ED)
2010 135i Vert 6MT (ED)
2007 335i Coupe 6MT (ED)
2006 325i Sedan 6MT
Old 05-10-2009, 07:54 PM
jonathansbmw jonathansbmw is offline
Mein Auto: 3 series
I can't even get the key to turn in the trunk. I've flipped the glove box trunk switch to both # 1 and # 2 positions and with the key in the trunk, it will turn a bit but then there's a stopping point where it makes me feel like the key will break in the lock if I turn more.
Anyone else can't open their e92 trunk with the physical key? And what was the solution?
Old 05-10-2009, 07:57 PM
djfitter's Avatar
djfitter djfitter is offline
Mein Auto: BMW '08 535i
The standard answer is to turn HARDER. It will open.
dj
'08 535i
Deep Sea Blue
Cream Beige
Dark Poplar
6 Sp Manual
Sport
Premium
Rear Shades
BMW CCA #392316
Old 05-10-2009, 08:25 PM
dean2c's Avatar
dean2c dean2c is offline
Mein Auto: 08 E92 335i
it makes me feel like the key will break in the lock if I turn more. Anyone else can't open their e92 trunk with the physical key? And what was the solution?
FYI, you have to turn the key counterclockwise to open the lock. Turning it clockwise would make it seem especially difficult.
Even when you're turning it the correct direction, it's easier to open with a keyring on the metal key -- it gives you a larger "handle" to generate turning force.
08 E92 335i, 6MT, Space/Saddle/Gray Poplar, ZPP, ZSP, PDC, CA, 6FL, nav, heated seats
ED 9/5-9/11/08, PCD 10/22/08
ďAn explanation of cause is not a justification by reason." --C.S. Lewis
Old 05-10-2009, 08:54 PM
armoredsaint's Avatar
armoredsaint armoredsaint is offline
Mein Auto: 2013 650i GranCoupe
you should lose your man card for a week
2015 F10 535i xDrive ///M-Sport / Carbon Black / ///MPerformance Exhaust
2013 F06 650i GranCoupe xDrive ///M-Sport / Black Sapphire
Old 05-10-2009, 09:32 PM
dean2c's Avatar
Yeah, I left myself open for that one.
I'll pick my card back up for next weekend.
Hopefully my trunk release doesn't malfunction between now & then...
