Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 05-04-2008, 12:34 PM
Gold86Bimmer Gold86Bimmer is offline
Mein Auto: 86 528e
load reduction relay ??
528e 86' auto trans
Need info on and to find 'Bosch 0 332 014 454' ; four prong relay???
Fuse box says 'relief relay'......workbook says 'load reduction relay'......what is it and where can I get 'exact' replacement?......thanks for any info.
BTW- how do I test to see if it is still working???.... (if can find another; looks faded maybe gray/light blue in color, also looks 'scorched' on terminals; searching for 'short' in system ).
Old 05-05-2008, 09:50 AM
totalautofremnt totalautofremnt is offline
Mein Auto: 528e
Same relay as # 0332-019-451. Standard run of the mill 4 pin relay. To test supply power and ground to terminals #85 and 86. You should hear a distinct click. Now test continuity between 87 and 30, you should have continuity now. Hope that helps
HTML code is Off
