90k mineral oil to royal purple or stick with mineral? - Bimmerfest - BMW Forums
Old 07-24-2007, 01:41 PM
gpupp gpupp is offline
Mein Auto: 97 540iA
@ 90k previous owners used mineral oil...can i switch to royal purple or bmw synthetic? can i use oem filter if i switch? if not can i use mobil 1 5w 30 from walmart vs bmw's preferred oil?
Old 07-24-2007, 01:51 PM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: '12 X6 50i
The rule is : if you broke it in on mineral oil, or have run it on mineral for a long period of time then you shouldn't switch to syn because youre probably going to get leaks.
Old 07-24-2007, 02:02 PM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
I am not doubting you, but I never heard of such a thing. Do you have a link to a reference about this somewhere? Again, not doubting you, just want to educate myself more about it from a reputable source.
MatWiz
"The greatest thing about the internet, is that you can quote something and totally make up the source." - George Washington.
Old 07-24-2007, 02:06 PM
BigCo540i's Avatar
The Usual Suspect
i'm sure someone here can find a link to something, but i'm just going by what my mechanic told me, sure you can do it but it's not the best idea.
Old 07-24-2007, 02:09 PM
bimmerd00d's Avatar
bimmerd00d bimmerd00d is offline
just havin a heart attack
Mein Auto: 1998 540i 6-speed
Ehh i moved my g/f's Cavalier to synthetic and haven't gotten any leaks. BMW's should run on synthetic forever. Make the switch, you might get a leak or two, but once the seals condition it should slow. If not, replace whatever leaks!
2011 535i xDrive M-Sport - 129k miles
2006 Mazdaspeed 6 - 128kmi
2016 Triumph Tiger 800 XRT - 4900mi
Old 07-24-2007, 02:10 PM
Mein Auto: 97 540iA
according to couple of bmw mechanics from the dealerships...they did not go to synthetic until 2000...they used mineral oil up until then....they also recommend not going to synthetic due to leaks that could occur....
i just wanted to see people's experiences that have gone against bmw and went to royal purple and have not had any issues. if they are then i'll just stick with mobil 1/castrol 1 conventional oil.
Old 07-24-2007, 02:34 PM
bimmerd00d's Avatar
I guess my 540 had synthetic when i bought it....maybe. It has 2 leaks, front and rear main seals Could be a result of swiitching from dino to synthetic. I dont care though, i'll run synthetic in everything til the day i die. It's not more expensive
Old 07-24-2007, 02:37 PM
wing46man wing46man is offline
crazy bimmer driver
Send a message via AIM to wing46man Send a message via MSN to wing46man
Mein Auto: 99 528i
incorrect, i have a 99 528 and it says right under the hood to use BMW synthetic only, and leaks may or may not occur. it depends on the condition of the seals and how often the previous owner changed the oil and if the grade of oil was up to BMW's specs
Life is too short to drive non-BMW cars.-Bimmerfest member TimeOut
My wheel bolts require more torque than your honda makes
The fact is you are what you eat, and you clearly went out and devoured a fat man.
German Engineering, Astounding Ingenuity, Over 100 years of conceptual continuity...BMW, The Ultimate Driving Machine
Old 07-24-2007, 02:39 PM
BigCo540i's Avatar
The Usual Suspect
I was lucky when I bought mine, all of the service records showed BMW SYN. I also am a believer in the Man made stuff. Mobile 1 is my choice.
Old 07-24-2007, 02:42 PM
Mein Auto: 97 540iA
i bought this from an old lady and she did not keep any records since bmw kept it for her...when i went to try to get service records they will not disclose the information due to privacy owner act....unbelievable..all i wanted to know was what they did to this vehicle...
Old 07-24-2007, 02:45 PM
BigCo540i's Avatar
The Usual Suspect
The same thing happened to me about the Privacy thing, so I had the guy at BMW change the records to show my name since I was clearly the owner(title). So the problem was solved he didn't break any rules because the previous owners name was taken off the records. Give it a try.
Old 07-24-2007, 02:51 PM
kishg's Avatar
kishg kishg is offline
E30 Maniac
Mein Auto: too many bmws
not this topic again
typically a seal that is already compromised will have leaks when switching to
synth. if it's been run with dino till 90k i'd stick with it and change every 3k.
'91 SpecE30 #523
'03 540i/6 M-Sport
'00 Ford F-350 Dually Tow Vehicle
BMWCCA #360858 NASA #
128290
My Track Schedule
Old 07-24-2007, 02:56 PM
Mein Auto: 97 540iA
yes, i know kish
figure be good to get people's experience here and there.
Old 07-24-2007, 02:57 PM
Mein Auto: 97 540iA
bigcos...i changed the info through bmwna...so it did show up as my name as the new owner...guy said they can't disclose previous owner info...crock of crap...not like i want her credit card number or phone number...she is 70 years old for godsake!
Old 07-24-2007, 03:01 PM
BigCo540i's Avatar
The Usual Suspect
Yeah I know...the only thing that is her personal info is her address and if he changes that to yours your good. Try it at another dealer, I was lucky because I drove about 2 hours to the dealer and the first thing he told me was that he couldnt disclose the owners info, but then another guy suggested that he change the address in the system and it worked. Keep trying hopefully you'll get it
Old 07-24-2007, 03:03 PM
Mein Auto: 97 540iA
good idea bigcos...def do that...for anybody info...DO NOT USE west springfield, ma bmw...they are by far the worse....
Old 07-24-2007, 07:25 PM
devmc2 devmc2 is offline
Mein Auto: 1998 BMW 540I
When or how many miles should you change the transmission fluid and filters.
Old 07-25-2007, 08:20 AM
franka franka is offline
Mein Auto: E39 540i Sport
I went from many miles on dino oil to synthetic. Had a minor leak or two that stopped in short order.
Gf's Mercedes had to have the head gasket replaced after switch to syn. But her model of Mercedes had a known head gasket problem.
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 07-25-2007, 01:56 PM
jsayreshepherd jsayreshepherd is offline
Mein Auto: e39 touring, e46 ZHP
What model Benz? I had a W124 that had a slight leak that got worse when I went from dino to synthetic (granted, I waited until the car had 175k to switch, which was probably far too late).
Old 07-25-2007, 02:03 PM
A 320 E I think... Is there such a model?
Frank
540/6
Old 05-05-2008, 03:26 PM
E39music E39music is offline
Mein Auto: '01 525ia
I just noticed the same thing
Sorry to bring up an old tread. I just noticed today that my car has slow engine oil leaking - I believe it's upper oil pan on driver side and rear main seal. The car had 108Kmiles when I bought it in March. I inspected the car - it was very dry, absolutely no leak. I did my oil change using GC 0W-30 full synthetic as many recommended right when I bought the car.
This could be because the previous owner used dyno oil for a long time. What you guys recommend me to do (it's about 2kmiles on the new oil - including a long trip to LA)? Should I switch to something thinker right away? Or should I just wait and see if it will get better?
There is nothing dripping to the garage floor yet - but I can see the seepage (slow leak) clearly.
Old 05-05-2008, 04:56 PM
Fulltone74's Avatar
Fulltone74 Fulltone74 is offline
Mein Auto: 98 BMW 540i-6speed
Actually, they can verbally tell you what was done, but not hand you the service records print out, since that shows some of the owner personal info.
I just did the same with an m5 I was looking at buying. Dealer only read off his computer monitor what was done on the car, but wouldn't give me a hardcopy.
1998 BMW 540i 6-speed (SOLD)
Jet black on tan
Dinan springs, Dinan Koni dampers, Dinan front strut tower bar, M5 rear sway bar,
Dinan Stage-1 software, Dinan clutch, Dinan short throw shifter, CDV delete, Bosch Design III injectors,
Dice I-pod kit,
Hawk ceramic brake pads....
2001 BMW M5
Silverstone on Caramel
All stock.
Old 05-06-2008, 08:30 AM
In some recent reading I learned that conventional multi weight oils do swell O rings and such whereas synthetic allows them to shrink back to their original size. Not perfectly or completely but significantly.
Basically synthetic will not affect the size of a new O ring but conventional will expand it.
I read this is a highly respected journal in an article on oils.
Frank
540/6
Old 05-06-2008, 10:04 AM
Brian McKinney's Avatar
Brian McKinney Brian McKinney is offline
BMW Nuthead
Mein Auto: e92 M3 6mt
split the difference and go with a blend....
08 M3
TMS pulley
RPi scoops and drop in filter
DRB Motorsports axle back exhaust
Old 05-06-2008, 12:44 PM
JoeFromPA JoeFromPA is offline
Mein Auto: 01 M5, 08 535xit
To expand a little on this, synthetic oil molecules tend to be quite small and homogenuous which leads to better flow properties...but it also means that they tend to slip into very small spaces better. Good in the engine, bad near an old not-so-great seal. Sometimes, an engine will leak from switching to synthetic due to the above post's properties and the fact that they don't have "large" dino molecules blocking the oil's exit.
There are a variety of good solutions to this. As suggested by Brian, switch to a synthetic blend. Use a high mileage oil. Sometimes even using a higher viscosity synthetic (i.e. a 5w40 vs. 5w30 or even a 5w50 if weather permits). The greater viscosity (which is essentially resistance to flow at operating temperature) will reduce, minimize, or eliminate leaks that would occur under a lower viscosity oil.
There is nothing wrong with experimenting. Furthermore, if you are pretty easy on your oil (read: you don't track the car) then Dino is not exactly a risky proposition. Synthetic mainly helps in the extremes....extreme use, extreme hot, extreme cold, extremely long oil change interval, etc.
Joe
F80 m3 - 20k miles as of April 2015....08 535xit - 120k miles
