Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 05-10-2008, 01:25 PM
323ivabeach 323ivabeach is offline
Mein Auto: 2000 323i
Cracked frame
I have a 528e with a braking shimmy problem.So I looked at the lower control arms and found where they are mounted to the frame,the frame is cracked. And there is this bracket welded to the frame and connected to the control arm on the passenger side tha is not there on the other side.I'll just weld the frame,this is a beater.But does anyone have a picture of what all this is supposed to look like.
Old 05-10-2008, 06:52 PM
I'm sorry, I'm retarded. I'm talking about the trust arms and where they are attached to the body/frame rail of the car. Does anyone have a good pic of this area of the car? I just bought this car on the cheap and I am not very familiar with them.
Old 05-12-2008, 06:35 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
See if any of the pictures here helps you. This website is awesome and shows how methodical some people can get when working on their cars!
Jimmy Moreno
1995 530i
1986 535i
Old 05-15-2008, 06:01 PM
Thanks that helped, I'm welding in some angle iron this sunday. I need new lower control arms and thrust arms too. You know were i can get those the cheapest?
Old 05-19-2008, 07:40 AM
Mein Auto: 2006 X3
Well, if you go the "cheapest" route you will be doing them again in a year or two. You should get only Meyle or Lemforder brand and, if possible, with the HD bushings on them (upper arm). Depending on your location, contact Steve Haygood or AutohausAZ (free ground shipping) for the best prices around.
Good Luck!
Jimmy Moreno
1995 530i
1986 535i
Old 05-19-2008, 02:02 PM
Wow, I'm missing the entire sway bar! The bracket I was talking about is where the sway bar bolts too, and someone just hacksawed the end links off too! Looks like I'm going to have to source that bracket and do some more welding! Yesterday was the first day I was really able to get under the car and really look at everything. It looks like someone jumped some railroad tracks or something! Good thing is at least the subframe assembly looks undamaged. Could you help me find a sway bar and end links? by the way i really appreciate the help!!!!!!!!
Old 05-20-2008, 10:21 AM
Mein Auto: 2006 X3
Go here and post a WTB (Want To Buy) ad. There are people always parting out e28's here. I hang out there a lot!
Good Luck!
Jimmy Moreno
1995 530i
1986 535i
Old 05-20-2008, 11:05 AM
Well I just found these http://cgi.ebay.com/ebaymotors/BMW-E...m140233121954&
And someone told me about a place called Stan Gills junkjard not far from where I work. So i guess I'll get the mounting bracket I need with a portable reciprocating saw while I'm getting the sway bar and endlinks. I'm told they have more e28,e23,e24 then anywhere else near me.
HTML code is Off
