Old 05-13-2008, 07:09 AM
osikani osikani is offline
Mein Auto: 2000 528I
Arrow Alarm goes off
My alarm is faulty. A few minutes after the car is locked, the alarm goes off. Any ideals!!!
Thx.
Parto.
2000 528i
Old 05-13-2008, 07:42 AM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
one of two things. it's either the alarm button under the hood, or the batt. going bad. take it to advance and see if the batt. is any good. and if it is than the new alarm thingy is 20 bucks at the dealer. or so last i heard.
The more you complain, the longer God makes you live. SPHOBA #00002
Old 05-13-2008, 07:55 AM
spydrz's Avatar
spydrz spydrz is offline
Sandlapper Chapter
Mein Auto: 2013 X1 xDrive35i
I believe you can also just disconnect the hood sensor...
1984 318i/man./Tornadorot*
1990 525i/man./Alpinweiß*
2001 525i/man./SP/PP/Cosmosschwarz/Sandbeige*
2002 X5 3.0i/man./SP/PP/Sirius/BT/Titansilber/Sandbeige*
2006 330i/man./SP/PP/CWP/Sirius/Blackline/Rear Fogs/Arktis/Grau*
2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige*
2012 VW Golf R/Rising Blue*
2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Premium/Tech/Dinan Stage 2
*retired
Old 05-13-2008, 08:31 AM
Brevity= the soul of wit
Could also be the internal motion sensor on the headliner. 528's do have that, don't they?
Old 05-13-2008, 08:39 AM
lild's Avatar
livin the 'Fest
yeah they do. doubt it that though. usually it's one or the other as i said earlier.
Old 05-13-2008, 08:47 AM
Thx, I 'll check the battery. where under the hood is the alarm buttom? Is the "new alarm thingy" the same as the buttom?
Old 05-13-2008, 08:51 AM
synenergy52's Avatar
synenergy52 synenergy52 is offline
Send a message via AIM to synenergy52
Mein Auto: 2016 Lexus Hybrid
Yeah my 97 528i does it too after being locked a while. Could go off anywhere from 5 minutes after to 5 hours after. No clue whats going on and I doubt my battery's going cause I have no signs of a weak battery. I'll try disconnecting the hood sensor. As for now I have the fuse pulled.
Old 05-13-2008, 08:56 AM
lild's Avatar
livin the 'Fest
i had the same issue of mine going off for no reason. i knew it wasn't the batt. and it turned out to be the hood sensor. so i took a paper clip unfolded, cut some length out of it made it into a "u" shape and placed it under the sensor , wedgeing up some so it would make good contact with the hood or you can unplug it. the sensor is located on the cabin air box, drivers side, on the outer edge towards the shock tower. oh and i hadn't had a problem since.
Old 05-13-2008, 03:53 PM
bscarlett's Avatar
bscarlett bscarlett is offline
Mein Auto: 2011 550xi
My alarm used to go off for no reason and it was the hood sensor. I simply unplugged mine under the hood, in front of the driver's side filter. When the alarm didn't trigger for several days, I knew I had found the fault.
2011 550xi Carbon Black/Oyster, M-Sport, Premium Package, Technology Package, Electronic Damper Control, Dynamic Drive, Comfort Access, Active Seats, Surround Cameras
2013 X5 5.0 Space Grey/Black, M-Sport, Technology Package, Comfort Access with Soft close doors, third row seats, Surround Camera
Old 05-19-2008, 03:19 PM
Thx guys. I simply unplugged the hood sensor.The alarm has not trigger for since then.
