Old 05-14-2008, 03:02 PM
chipchidster chipchidster is offline
Mein Auto: 540 Touring
Driver side sun visor crashes radio
Hi,
i noticed something really odd on my way home this evening. I pulled down the sun visor and pushed back the mirror cover and the radio died. Nothing i did managed to get the radio back, the trip computer also refused to display - although i could still access the 'secret' test mode by holding in the right hand stalk on the dash.
After i had stopped and restarted the car, i managed to get the radio back by opening the passenger side sun visor and opening the mirror - this seemed to perform some kind of reset, although it didnt work when it all first fell over.
Does anyone have any idea as to what the heck is going on, my great worry is that the onboard computer is about to let go and is playing silly buggers first.
Dan
Old 05-14-2008, 03:08 PM
PJB. PJB. is offline
Mein Auto: 2000 528i (01/2000 mfg.)
Do a search for "ignition switch," and you should find your symptoms, a diagnosis, part number, and fix.
Old 05-14-2008, 03:10 PM
spydrz's Avatar
spydrz spydrz is offline
Sandlapper Chapter
Mein Auto: 2013 X1 xDrive35i
Definitely the ignition switch.
1984 318i/man./Tornadorot*
1990 525i/man./Alpinweiß*
2001 525i/man./SP/PP/Cosmosschwarz/Sandbeige*
2002 X5 3.0i/man./SP/PP/Sirius/BT/Titansilber/Sandbeige*
2006 330i/man./SP/PP/CWP/Sirius/Blackline/Rear Fogs/Arktis/Grau*
2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige*
2012 VW Golf R/Rising Blue*
2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Premium/Tech/Dinan Stage 2
*retired
Old 05-14-2008, 03:17 PM
I really hate to send you off an a search without a few results to look at, so:
People with similar symptoms:
http://www.bimmerfest.com/forums/sho...d.php?t=131976
http://www.bimmerfest.com/forums/sho...d.php?t=272888
The part number that you need to buy and replace (about $60):
http://www.bimmerfest.com/forums/sho...d.php?t=284526
DIY writeup (about 30 min):
http://www.bimmerfest.com/forums/sho...d.php?t=131977
R. Kelly - Igniton remix:
Lyrics: http://www.lyrics007.com/R.%20Kelly%...%20Lyrics.html
Video:
Old 05-14-2008, 03:21 PM
John@AstigRacing John@AstigRacing is offline
Past Sponsor
Send a message via MSN to John@AstigRacing Send a message via Yahoo to John@AstigRacing
Mein Auto: 2000 528i Sport
i heard that if your battery is weakening this can happen.
Old 05-14-2008, 05:14 PM
NNY528i NNY528i is offline
Mein Auto: 1997 528i
Nope not really, this is most assuredly the ignition switch. The symptoms are VERY repeatable and VERY, VERY Specifc(Passenger visor, Airbag, radio, Cruise Control)
This is caused by deposits that build up on the points of the ignition switch contact #2. The deposits increase the resistance through the switch which when over loaded causes the voltage to these specific items to be off and as such they do not operate properly.
Replace the switch and all returns to normal immediately.
While a dying battery can cause weird things to happen they are random and happen in all different car systems.
>'97 528i, 202500 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers Coming soon 5speed conversion
>'65 & '74 MG Midgets BFC OT Lego Club #48
Old 05-15-2008, 12:14 AM
Thanks PJB - i will have a go at that tonight and see if it resolves my problems. I does seem to fit with other electrical gremlins that i have been seeing - airbag light coming on every so often, cruise control dying intermittently.
It's a shame really, as otherwise it is a fantastic car - apart from the fuel bills that is!
Old 05-15-2008, 04:43 AM
The switch will absolutely fix your problems, its not that hard to do and does not cost you much at all.
Old 05-15-2008, 05:01 AM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
Video:
... R Kelly... hahahahahaa!!!!!!!!!!
americandan.com
It takes a lot of work to be lazy.
Old 07-17-2008, 11:55 AM
Mfecani Mfecani is offline
Mein Auto: 1998 528i
I'm having the same issues, but my mechanic insists the ignition swith is fine. Plan B?
Old 07-17-2008, 12:35 PM
A few things...
1) Tell us your symptoms, then tell us if those are the same symptoms that you described to your mechanic, then tell us why your mechanic is saying it's not the ignition switch and what your mechanic says it is.
2) Get a second opinion from another mechanic over the phone, keeping in mind that they might tell you it's your alternator.
3) Welcome to the 'Fest.
Old 07-17-2008, 12:40 PM
Symptoms are: no radio, none of the steering wheel controls work, when I pull down the visor and expose the lights the steering wheel tilts up and down. My mechanic saw of this himself. he couldn't believe it. He ran a diagnostic test and says its not generating any faults. He doesn't know what it could be.
Old 07-17-2008, 12:48 PM
pauleeee pauleeee is offline
Mein Auto: 98 540i
When my ignition switch was bad I didn't have any steering wheel controls, No Radio, Airbag light on, and no rear sunshade activation. You decide.
Old 07-17-2008, 12:55 PM
Personally, if it were me, I would gamble the $60 and get the ignition switch. Your symptoms are very indicative and consistent with others who have had a faulty ignition switch. When our ABS units are malfunctioning they don't give codes because the module that finds faults is itself at fault. Kind of like how a sick cop won't give tickets, ya get the analogy? Point being, the switch being faulty might not give codes, or it might be a component that wasn't designed in the first place to give codes.
Hopefully you don't know this by now and hopefully you won't know it anytime soon, but $60 for a part for our cars is not that much, relatively. A tank of gas costs more. Spend the $60 at a place with a return policy, and give the DIY an hour of your time. If it doesn't fix the problem, return the part and you may only be out $20 or so, not a big deal. If it DOES fix the problem, inform your mechanic and he may hook you up for proving him wrong and providing some knowledge.
I know that throwing parts at a problem is the most expensive way to diagnose, but in this case there's not much else it can be and the part is not that expensive. Don't use this technique on a suspension problem, though. THAT will cost a lot.
Old 07-17-2008, 02:01 PM
The only reason your mechanic is saying this is because he has not encountered this issue before. Your problem is WITHOUT ANY DOUBT AT ALL the ignition switch.
Inside the switch there are several different contacts which are very much like the condenser points from back in the day(your mechanic will know about those) Any way the problem that occurs is with the contactor for the second circuit which feeds all of the items discussed before. The ONLY thing these different systems have in common is that they are connected through this particular switch contact. The other switch contacts are unaffected and behave normally. the problem arises I believe from arcing, voltage or amperage fluctuations across the contact(that is why the visor trips everything weird because it is a high amp draw, same with the CC)
I will personally guarantee that if you change out the ignition switch as described in the above references your problem will go away. I would print this information and take to your mechanic, order him to change the switch and then let us know how amazed he was when it worked like we said it would. You too will believe and become one of the enlightened of the cult of the switch!
Seriously though, there is no doubt about this, change the switch your car will be like new. You could even bet the labor with your mechanic that the switch will fix it(if it does he doesn't charge you for the work) I bet he would take that bet.
Now what would be really cool would be to meet the guy who figured this out for the very first time, that has to be either one lucky bastard or the worlds greatest troubleshooting genius.
Old 07-17-2008, 03:54 PM
Great advice from everyone. Its greatly appreciated. I did print this thread, and he's going to change it. I will keep you posted.
Old 07-24-2008, 04:23 PM
You were all correct. Switch was changed and all is back to normal.
Old 07-24-2008, 06:24 PM
Waveho Waveho is offline
Mein Auto: '07 335xi 6MT 4door
Remember, these are the same techs who INSIST that you must remove the windshield, which is glued to the frame, in order to replace the cheap rubber windshield covering, which is not....
'07 335xi 6-spd 4dr, Montego blue
'98 540i 6-spd Sport, Jet Black II(sold)
'92 325i 5-spd 4dr, burgundy(sold)
Old 07-24-2008, 06:32 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Congrats, glad to hear that worked for you.
The first time I saw one of those threads I was absolutely amazed at the weird connection between the two.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
