Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series > E21 (1975 - 1983)
E21 (1975 - 1983)
Old 05-15-2008, 11:08 AM
fireman steve fireman steve is offline
Mein Auto: 1981 BMW 320i
Vacuum advance help
While wrenchin' around on my 320i, I discovered that my vacuum advance hose goes from the distributer to nothing... Yep, the previous owner cut it, and I can't find where it used to hook up. Can one of you take a look under your hood and trace the flex line for me? I would really appreciate any help you can offer. I found one spot on the intake manifold that has a cap on it, it could be the right connection, but I want to make sure. besides, why would that knuckle-head cut off the vacuum line and cap the connection???
Thanks in advance, and I can probably figure out your directions with some good landmarks, but a picture would be awesome!
..Fireman Steve..
Old 05-31-2008, 07:49 AM
geraldgj geraldgj is offline
Mein Auto: 1982 320is
Vacuum Advance
The capped of connection on the manifold is probably the where it goes. The connection on mine is right below thw cold-start injector. You will have to reset the timeing with the advance connected.
Old 06-04-2008, 05:37 PM
That was it! (Photo included)
That was it! For anyone in the future that wants to reference this, heres a photo:
Photobucket
..Fireman Steve..
Old 11-03-2008, 03:20 PM
dictator dictator is offline
Send a message via AIM to dictator Send a message via Yahoo to dictator
Mein Auto: 1982 BMW 320iS
i believe the advance should not be connected when timing. otherwise it will be adjusting your adjustments
Old 11-03-2008, 03:23 PM
willysully's Avatar
willysully willysully is offline
Mein Auto: 1995 325i
Did Żou have to reset timing?
Old 11-03-2008, 03:26 PM
yes had to replace the rotor
