DIY E36 M3 folding mirrors installed (Pics & video) !
Hey guys,
Sorry for the late reply, but I've been busy the last couple of weeks. well, I finally installed the mirrors with the one touch switch of the E39 Electric sunshade button. The installation is quite straight forward, the only pain is guiding the wires from the doors to the switch location.
Well, here are the steps very briefly.
1- Remove the doors panels
2- remove your old mirrors.
3- install the new ones. This is a straight forward step, no tricks there.
4- Now, remove the plastic part that contains all the wires going from the inside of the car into the door. You need to add extra 2 wires in each door to be controlled by the switch.
This plastic tube is really full and it takes some patience and the use of a solid wire to find a way through.
5- Do the same step in the next door.
6- connect the new wires with the 2 wires coming with the mirrors, and then put back the door panels. Make sure you wire the speakers and the mirrors electric button switch.
7-now connect everything to the switch, the bottin have 5 wires connect them as follows:
- Positive end to the mirrors (+ve of the left and +ve of the right goes here)
- Ground end to the mirrors (-ve of the left and -ve of the right goes here)
- 12v positive (continuous)
- Interior light (to make the button light at night)
- Ground.
Push the one touch button and see it working! :supdude:
8- finally, insert the switch under the sunglass area, the switch goes is and fits perfectly without modifications/
Here is the video too as promised.
My next step is to connect the mirrors somehow with the alarm, so it folds up automatically when I arm the car, and folds down when I disarm it! Any ideas where to start ?!
Overall it took me around 3 hours to do it .. it's 2/5 difficulty level.. just need some patience That's it ! :thumbup:
