Old 05-20-2008, 10:57 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
DIY - Various Interior Trim Removal
I figured I would have one thread that dealt with the removal of various interior trim. I will post updates to the thread as I take more off my car.
Removing trim around shift boot
Remove the shift knob and shift boot.
With the shift knob and boot removed, remove the trim by pulling up. There are a few clips holding it in place.
Removing Door Handle Trim
The Door handle trim pieces are held in place with the same clips as the shift boot surround trim.
To remove the trim, begin at the bottom of the trim. I was able to remove by pulling the trim off, you may want to use an Interior Trim Tool to un-dock the connectors.
Slowly work your way up the trim releasing the 5 clips. You do not need to pull very hard, just enough to release the clip then move on to the next one.
Removing the Dash Trim
The Dash Trim is held in place with what I call the BMW straight clips. They are basically spikes that mate with a female plug on the dashboard.
Begin at the outboard point and use the Interior Trim Tool to un-clip the first clip. Work your way toward the Driver Side using the same precautions that you used on the Door Trim.
HVAC Console Trim Removal
The HVAC trim and the lower section that holds the heated seat switch bay is one piece. The line that you may think is designating where the trim is 2 pieces, is just for cosmetics.
To remove the HVAC Console Trim, begin on the lower edge. Use an Interior Trim Tool to undock the 2 clips along the bottom edge. Do not pull the trim out too far. You will create stress on the trim and it can break. You can see int he below picture where it is starting to stress. With the lower clips un-docked, move along each side releasing the 2 clips per side with the Interior Trim Tool.
Interior Trim Removal Tool
The Eastwood Company sells a nice set of Interior Trim Tools. They are plastic shims of different sizes, angles and shapes that allow you to carefully separate interior trim.
Old 05-20-2008, 05:02 PM
ARC///M's Avatar
ARC///M ARC///M is offline
Mein Auto: BMW 01 M Rdstr 00 M Coupe
Great Andy
Hey my car was built on 5/14/08 taken delivery @ plant soon!Will need to set some options in play at Homecoming I spoke with my contacts the tii will be out by the end off 09 so were told,I am thinking trade?
Old 05-21-2008, 01:09 PM
jeffng65 jeffng65 is offline
Mein Auto: MCS, 135i, F348ts SS
Thanks Andy! As soon as I get my 135i I'm hoping to trade out for brushed aluminum trim if I can keep the cost down.
Old 05-22-2008, 02:21 PM
adc adc is offline
BMW Fahrer
Mein Auto: E90 M3
Andy, do you have any experience with door panels?
I'd like to know if the middle part of the panel, the one that's upholstered in the same color/material as the seating surfaces, can be removed. My aim is to purchase Euro-only cloth seat covers, but if I want everything to match up, I'd better figure out a way to re-upholster the specific part of the panel (or swap it, if it's a separate part).
Thanks...
adc
15 M3 Sedan ED
13 X1 2.8i ED
04 Z4 3.0
Old 05-22-2008, 02:44 PM
AndyM's Avatar
Suede Master
Thanks...
I will be removing the door panels soon. My plan is to replace the center insert with Montego Blue Leather. I will be doing this when I get the LEDs to illuminate the door handles. I will post a how to when I do it.
Old 05-22-2008, 03:51 PM
adc adc is offline
BMW Fahrer
Mein Auto: E90 M3
Please post it, that will be interesting...
I was able to locate various part numbers for BMW cloth upholstery sold by the yard - the price was estimated between $140-180 per running yard. I'm thinking of ordering Black Leatherette or Leather, purchase the cloth and take it all to an upholstery shop to replace the seat center panels with cloth.
BTW, do you guys do this sort of work? Cincinnati is not really that far away...
adc
15 M3 Sedan ED
13 X1 2.8i ED
04 Z4 3.0
Old 05-22-2008, 04:05 PM
AndyM's Avatar
Suede Master
I was able to locate various part numbers for BMW cloth upholstery sold by the yard–the price was estimated between $140-180 per running yard. I'm thinking of ordering Black Leatherette or Leather, purchase the cloth and take it all to an upholstery shop to replace the seat center panels with cloth.
BMW stopped selling material by itself. What was the number for the Leatherette?
Old 05-23-2008, 09:20 AM
adc adc is offline
BMW Fahrer
Mein Auto: E90 M3
Perhaps in Europe they still do - I selected an Euro model over at realoem.
In any case, I found many numbers... I used this: E46 -> Sedan -> 330i -> 12/2004 -> M54 -> Left -> Browse Parts -> 52 Seats -> 52 60 Upholstery Code and Material -> Cover Material, running meter diagram:
FOR VEHICLES WITH
VINYL LIGHT BEIGE 2 K4HC=YES
01 IMITATION LEATHER HELLBEIGE 51928248028 $154.01
FOR VEHICLES WITH
IMITATION LEATHER/BLACK K4SW=YES
01 UPHOLSTERY IMITATION LEATHEAR SCHWARZ 51928153518 $154.01
I used a similar approach for the E46 330i/M3 and E90 330i to obtain some part numbers for all sorts of upholstery styles. If nothing else works, I'll call the big dealer in Munich, ask for the parts department and feed him some part numbers to see if he can get them and what the cost might be.
If you do find a way to order from the USA, or if you start offering some cloth options, please let us know. There were many people interested in cloth or cloth/leather upholstery, particularly for the 1 series.
adc
15 M3 Sedan ED
13 X1 2.8i ED
04 Z4 3.0
Old 06-09-2008, 06:24 PM
AndyM's Avatar
Suede Master
When you order leather, it gets bumped from the order. I ordered some of the leatherette and will see if I get it.
I did remove a door panel (which weighs 15-20lbs easy–They could have made this car a lot lighter with a minimum amount of work). The center section is not easily removable. It looked like the center part has 1" long plastic stalks that go through the door panel and then get melted on the backside of the panel to lock it in place. Taking that portion out won't be an issue, but putting it back in will. I will play around with it when I get the time. I think an easy way to swap that piece out would be to remove the section and use a thin material that will conform to the contour. Then have captive bolts that run through the material and when installed, you would secure the piece with washers and nuts from the back side of the door panel. On the finished side, build it up with some cotton badding and then cover in the material.
Not sure if that makes sense.
Old 06-10-2008, 09:09 AM
adc adc is offline
BMW Fahrer
Mein Auto: E90 M3
Makes sense. I thought the piece was going to be mounted like this when I realized you cannot order it separately, just the entire door panel.
I was thinking of removing the piece, stripping it, drilling holes where the plastic prongs used to be, and then use the bolt method as you suggest. I'll go to my HW store and see of the have some bolt with a very thin head, something like the galvanized roofing nails.
The more I look into this, the more it seems it may just not be worth it. Perhaps I should just order the black leather and then have an upholstery shop replace the center pieces with cloth/Alcantara and just forget about the door and side panels...
adc
15 M3 Sedan ED
13 X1 2.8i ED
04 Z4 3.0
Old 06-10-2008, 11:32 AM
AndyM's Avatar
Suede Master
I was going to replace the center section with Montego Blue leather. I may start on one of the rear panels to minimize the expense if it does not work out. I don't see any reason why it won't work though. There may be some hiccups along the way, but I think it will work.
