E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
| View Poll Results: How many miles on your transmission before repairs or replacement needed? | |||
| 50,000 to 100,000...transmission repaired/replaced. |
124 | 7.79% |
| 50,000 to 100,000...no problems!!! |
582 | 36.58% |
| 100,001 to 125,000...transmission repaired/replaced. |
92 | 5.78% |
| 100,001 to 125,000...no problems!!! |
285 | 17.91% |
| 125,001 to 150,000...transmission repaired/replaced. |
60 | 3.77% |
| 125,001 to 150,000...no problems!!! |
188 | 11.82% |
| 150,001 to 175,000 or more...tranny repaired/replaced. |
40 | 2.51% |
| 150,001 to 175,000 or more...no problems!!! |
220 | 13.83% |
| Voters: 1591. You may not vote on this poll | |||
#226
I had one last 200,000. 1991 325 i. I miss that car the timing belt popped and it was changed at 170,000 miles grr.......I had a really cool europlate on the front that read eurobred lol I still have the plate.
I got the plate from www.europlates.com I plan on getting another one soon for my newer 2006 bmw not sure what to get for the custom plate but I just want something different its black so I was thinking of getting a black on black europlate with some hidden message? badazz or something.
#227
this is my seventh bmw and i have never had any problems with transmission, however, in this one i had to replace transmission gasket. Fluid was leaking. No big deal, it runs great. I like it better than Porsche.
#228
171,000 540I v8 motor and trans never touched. Reading on here, I took it to BMW dealer and they said to not change anything as it may make it worse.
#229
160.000 miles and it works like new.
#230
You flush? If so, when for first time and how often?
#231
My 2000 323i w/sports option has 157,000 KMs and no issues with the auto trasmission.
2000 Grey 323i w/ Sport Package and BSW Stage 1 Upgrade |
#232
Failed at 91,000. Tranny replaced under 3rd party warranty (luckily).
#233
Currently at 120,000 on our 330i and no issues, we're due for our 2nd change. We had the transmission fluid drained and refilled along with a new filter at 60k miles. A little maintenance goes a long way.
#234
Changed transmission fluid by AMMCO at 114000 miles currently has 17XXXX *I dont remember exactly*. Car shoots out 1 code torque converter, I guess I need to get it checked soon. Sometimes the service light doesn't come on for a while but when it does, it shoots that code.
#235
Let me guess... P0741?
E46 330Cic Executive 07/2003 Silver Gray Metallic |
#236
Yea that code lol. :/
2001 BMW 330I![]() |
#237
Which company did you go with on the 3rd party warranty?
"The money powers prey upon the nation in times of peace and conspire against it in times of adversity. The banking powers are more despotic than a monarchy, more insolent than autocracy, more selfish than bureaucracy. They denounce as public enemies all who question their methods or throw light upon their crimes. I have two great enemies, the Southern Army in front of me and the bankers in the rear. Of the two, the one at my rear is my greatest foe." Abraham Lincoln |
#238
I went with Guardian which was offered at the lot I got my car off of. Since my car was automatic I decided it was probably a good idea to do so and it paid off. My family has had past experience with Guardian, they have replaced the engine on my sister's used car she has under the shop's recommendation and now have replaced my tranny under AMMCO's recommendation instead of rebuilding (I was very pleased with the AMMCO shop near me). Like alot of warranty companies out there, there are plenty of complaints about them. But as far as the experience we have had with them, we are pretty happy. Just remember when you go with any warranty company, it's probaly not a good idea to heavily mod your vehicle while under warranty, specifically performance related (intake, headers, exhaust). They will use that as an excuse to not cover any claims you may have.
#239
On the car I bought the trans was changed at 110K. Now the car is at 148K. Trans was a rebuild from BMW (cost A LOT to previous owner). Planning to drain-n-refill as soon as I fix all other problems (oil leak, vanos, cvv, CAB, control arms, etc).
#240
116K miles. I changed the fluid at 100k miles and it works like a champ. And if it pukes, it will get replaced with another one.
#241
Just did the 2nd tranmission service @ 110k miles, first one was done @ 60k miles with the steptronic. Works great w/o any issues, smoother shifting and transition after the transmission drain, fill, clean pan, new filter, gaskets and bolt.
IMHO, highly recommended to get the transmission service done. Now off to the trackday.
#242
My E34 has 199,600 miles. The clutch was replaced somewhere around 110,000 miles I believe. I was not the owner of the vehicle at that time, however. There seems to be something leaking out of the transmission but very little around the sway bar area. A while back I was accelerating up a hill and heard a loud bang from the underside of the vehicle which I assume was the transmission but there hasn't really been any issue since to indicate there is a major problem with the system and that was way back in May. For the most part it still shifts fine. I am going to be taking it to a transmission specialist sometime soon to get it looked at and fix any issues before they become catastrophic because the vehicle itself is in fine condition. It just blows my mind how some posts on here indicate the transmission needing to be replaced before 100,000 miles. I just don't understand how that's possible aside from poor build quality on behalf of BMW. There is no reason that should happen, especially on such an expensive car as a BMW. I had a 92 Ford Explorer that has 230,000 miles on it and has never had any transmission problems at all. The owner of the car now is still driving it. Fortunately, the reliability of my E34 has been the best out of every car I've owned. It is built like a rock, far more reliable than my 98 328i was.
1995 BMW 530i Last edited by wisbimmer20; 12-05-2010 at 05:22 PM. |
#243
Hey all,
I am at about 111K miles on my 2001 330i. From looking at RealOEM.com it seems I have a ZF 5HP19, so I am dreading the reverse drum failure. My tranny was flushed a very reputable local shop (Curry's, Falls Church, VA) at 95K, but the filter was not replaced since they used a BG Auto Trans flush machine and BG ATF. Upon reading on BG's website it seems that the fluid meets all specs, but I have not been able to find much online on any forums about user experiences. Overall runs well, I have the RPM dip when going from Park to Drive or Reverse. I am not sure if its caused by the torque converter, partial lockup issue. No error codes though. The questions I have are 1. Is the fluid that is in my car currently ok? Can it cause serious hard in the long run? 2. I drive in the Manual mode all the time, does that have any adverse effects on the transmission life? Thanks a bunch. These forums have an amazing amount of info on here. |
#244
OK, after reading 9 pages of reports, it's still not clear to me what the point of no return is for cars which have not had their transmission fluid changed yet. I bought my car with w/134K miles and the original owner had not had the fluid changed and I'm wondering whether my transmission would benefit from a fluid change at this point given the risk. If I were to do it, I'd use the drain/pan drop and clean/filter/fill w/ OEM fluid without the power flush but even that can be risky.
I'd like to hear from folks who have had their fluid chagned (or any other transmission maintenance) for the first time after 125K miles, whether their experience was positive or negative and if they did it themselves, what the fluid/pan looked like. Also it's important to state what method was used whether it be a power flush, drain and fill, drain/filter/pan cleaned/new fluid, drain and fill more than once, ect... For those who have no problems at greater than 125K, was their fluid changed and at what miles? It would be interesting to know whether there is a longer life expectancy for transmissions that have had their transmission fluid changed or with the original fluid. How many miles on your transmission AND has the fluid been changed? Whether it is a GM or ZF would be interesting also. AFAIK, the ZF units with the defective reverse drum were phased out in early 2001 and cars built after that have not experienced no reverse. Please correct me if you had a June 2001+ build date car with no reverse. From the posts so far, it seems that the no reverse occurs before 100K miles so if you've gone past that, you should be pretty safe from the no reverse problem. What are the symtoms of a transmission needing attention or on its way out? A lag in engagement between D/R/P? It seems a torque converter problems with code is the most prevalent. |
#245
I would love to know the same... I have waited a few months and talked and asked and looked around... I have deceided its just not worth the worry. I am going to do my fluid this month at 80k miles.
07' 550i Burgundy interior, nav, mint! ![]() |
#246
Strong
142,000 no problems
#247
105k, no issues. Changed filter, gasket and fluid with AMSOIL at 70k and again at 80k. I had intended to do it at 5k after the first change, but just didn't get the time. I did not have the right tools to "Reset" the transmission computer after any of the changes. After the 80k change, it felt like it was slipping a little for 4-5k, but now is fine, just freaked me out for a while. I too read the 9 pages here and thousands of other pages of info out there on the web about the GM "Zero Maintenance" transmission. I took the leap and have been pleased. Hopefully it was the right choice!!
#248
92k miles and no problems. To my knowledge the fluid has never been changed.
#249
very nice to know
#250
172,000 miles on 97 540I V8 automatic transmission and never been changed. Dealership said at this mileage it would be better to leave it alone since it is not causing any trouble.
They have seen problems come up after a high mileage change. I'm doing what they recommended. Computer only shows an Oxygen sensor 1-4 needs replacing. It will be done next week for $200.00. Most folks that have BMW vehicles do not post on these sites, mainly those with problems do so be careful or you may get the wrong impression. Some of the nicest older BMWs I ever seen are posted on here. With as much as they have had replaced, they are same as brand new or better. If I had one of those, I'd show it off too. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
