E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
| View Poll Results: How many miles on your transmission before repairs or replacement needed? | |||
| 50,000 to 100,000...transmission repaired/replaced. |
124 | 7.79% |
| 50,000 to 100,000...no problems!!! |
582 | 36.56% |
| 100,001 to 125,000...transmission repaired/replaced. |
93 | 5.84% |
| 100,001 to 125,000...no problems!!! |
285 | 17.90% |
| 125,001 to 150,000...transmission repaired/replaced. |
60 | 3.77% |
| 125,001 to 150,000...no problems!!! |
188 | 11.81% |
| 150,001 to 175,000 or more...tranny repaired/replaced. |
40 | 2.51% |
| 150,001 to 175,000 or more...no problems!!! |
220 | 13.82% |
| Voters: 1592. You may not vote on this poll | |||
#101
However, this particular failure (cheap pot metal reverse drum failure) has been well known by BMW since 2001. The fact that a $20 part is fragging a $6K tranny and the only factory authorized service is a full tranny replacement is BS. On any other car that had an auto trans fail around 90k miles I'd say well, that's about par for the course. However, my tranny has not failed. It just won't engage reverse. It's perfectly fine otherwise. This is particularly frustrating when coupled with the fact that BMW removed my ability to at least flush and fill the tranny during its life as a ploy to save cost on their "all included" maintenance program. Want a real laugh? Google "final drive failure" and "bmw" to really become educated about a company that's given up all pretense of caring about their customers. |
#102
My gearbox started playing up at 125000Kms or 77500 Miles.
I had to have it rebuilt at about 132000Kms. My car is fitted with a GM badged French made ZF Transmission The transmission lock light would keep coming on and there was a strong smell of hot transmission fluid. The problem stems from a poorly designed 2nd gear cluster. The same transmission is fitted to some Isusu vechicles and they all suffer the same fate. It's enough of an issue the guys at Automedics keep redesigned cluster housings on hand. $3300.00 later, i now have a happy gear box. Now it's all the other problems i need to sort out. Steve 1998 E46 318i Narara, NSW, Australia |
#103
not sure if anyone has posted this link already but, this is what made me get a manual.
http://www.consumeraffairs.com/autom...bmw_trans.html |
#104
83,500. So far so good.
_______________Going to Bimmerfest East AND West ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
#105
60,000 on my '05 330CI Convertible with no problems.
#106
76,000 on my 04 330i Dinan no problems so far.
:X
BMW 2004 330I DINAN ![]() Black Sapphire Metallic-Ipod BMW Adaptor-Premium Package-Sport's Package-Steptronic-Xenon Headlights-Harmon Kardon- Dinan Performance Free Flow Exhaust-Dinan Performance Auto Trans SW-Dinan Stage 3 Software-Dinan High Flow Throttle Body-Dinan High Flow Air Box. |
#107
88k and running ok , i just had my friend help me with the oil change, but im not sure how to reset timer that comes on when oil change is due. can any one tell me.
#108
2001 330ci, 114700 miles. no problems with transmission to date. i have replaced the fluid twice and will continue to do so at 50k mile intervals. automatic transmissions are a weak link on most cars but much more expensive to repair on bmw's. this thread could also be usefull by covering lower cost repair options to the $6000.00 dealer route, provided they are of high quality.
#109
85k and some change. Nary a problem in sight, transmissions works flawlessly.
#110
144K on 328Ci, no problems yet. Although I am knocking on wood as I type this.
#111
Clocked up 96k miles now on my Switchtronic gearbox (same ZF box as step I think, but with different TC and management ECU, steering wheel gearchange).
Changed the oil soon after buying the car at 82k miles - I personally think it's madness NOT changing your tranmission oil. Quote:
Rich Last edited by Richy_Boy; 02-28-2009 at 03:20 PM. |
#112
I know this is late and has probably been addressed but if not I can shed some light on this. However prior to the release of my knowledge I picked it up from other post/research done on the web. I am not your local mechanic nor do I have any certification in any area dealing with cars except for having a license. Further more I am only an up and comer enthusiastic kid. So basically take this info for what its worth but dont hold me responsible for any misleading information. Anyway, basically the BMW lifetime transmission fluid is a bunch of 'baloney' to put it in nice terms. It has been allegedly proven by forum members and other people supposedly (although I cannot cite this) that the lifetime fluid can actually cause extreme damage to your tranny. Basically it was said that over time 'gunk' (i dont remember what defined gunk) would build up were the fluid sits. Also around parts that play the roll of what a gasket or O-ring would do. So further more it would shorten the life span of certain parts, other than gasket like parts aswell, and cause premature failure. So it has been recommend to change your transmission fluid i believe it was something like ever 20k. BUT... And this was a big BUTT, if your car is over 60k miles and you haven't changed your fluid you shouldn't do this. Because there is a chance that the transmission fluid caused this so called 'gunk', so when you change it it will break its seal with the O-ring / gasket typed parts. So whys this bad? Because supposedly the o ring typed sealant parts have been deteriorated and the seal will be broken. Which can lead to failure of your transmission and a costly fix. So anyway my suggestion would be to take this information into account because it hasn't been dis proven yet. And if you can disprove it please let me know because I would defiantly like to here why. Thanks, Skip |
#113
Although im almost positive that youll need some sort of computer to car mechanism. Like the ECU programmers they now have. |
#114
Transmission failure
I have a 2001 BMW 330i and the reverse on the transmission failed at 64k miles and cost 4500 to repair.
#115
No problems at 50mooo miles on '02330 ci.
#116
had mine rebuilt @ 99,000 miles. torque converter clutch problem...couldnt really find out the problem so i decided to just have it rebuilt.. runs great now!
#117
i got 140XXX, no probs so far
#118
BMW CCA Member, Capital Chapter |
#119
Explain to me "Driving Hard"?
no crass comments please :-p. we can all insert our own puns |
#120
Bmw transmission service refusal
Why is it that the Bmw dealer service refuses to change the trans fluid?? I had an independent also refuse - 65k miles & downshifting hard to a stop. Anyone know of a good shop in Atlanta, Ga? Thanks.
Bmw couldn't care less about you once your car is out of warranty! |
#121
I think it's SI 24 03 03 (update EGS control unit).
#122
Now you can see why I dumped my 330ci for a new Acura. Sure, there is nothing I know of that can compare to the confidence of driving a "Bimmer". but I could not x=stand the indiffrence of service and/or cooperation in handling problems. The lack of a spare tire and being forced to purchase run flats did it. I honestly miss the BMW buyt can live with what I have, and so far in a years and one half has not need one thing other that 2 oil changes.
#123
I had a lot different cars- Audi, Acura, VW, Nissan, Subura and etc, but I have never found better driving experience then BMW. I have not had a Benz. May be Benz will better for driving?! It's still a open Q.
#124
member of CRS Club '02 330i commute warrior '00 Dakar Duck CRS Edition '08 Mellow Yellow MCS + JCW Stage 1 |
#125
Unfortunately, BMW doesn't do same.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
