E46 (1999 - 2006)
View Poll Results: How many miles on your transmission before repairs or replacement needed?
50,000 to 100,000...transmission repaired/replaced. 143 7.81%
50,000 to 100,000...no problems!!! 616 33.66%
100,001 to 125,000...transmission repaired/replaced. 107 5.85%
100,001 to 125,000...no problems!!! 323 17.65%
125,001 to 150,000...transmission repaired/replaced. 79 4.32%
125,001 to 150,000...no problems!!! 220 12.02%
150,001 to 175,000 or more...tranny repaired/replaced. 51 2.79%
150,001 to 175,000 or more...no problems!!! 291 15.90%
Voters: 1830. You may not vote on this poll
Old 03-02-2010, 08:50 PM
freeway freeway is offline
Mein Auto: 2003 325i
92k miles, trans dead. enough said...
Old 03-06-2010, 11:34 AM
Clayton328 Clayton328 is offline
Mein Auto: 2000 328I
Tranny died with 132K on the ticker. I did a tune up and rebuilt the vanos assembly. Apparently the increase in power killed what was left of the transmission.
Old 03-18-2010, 05:11 PM
SpeedDemon SpeedDemon is offline
Mein Auto: 05 330Ci ZHP 6MT
I'm at 80k miles on my 325i it seems to be running better than ever. I just swapped out the tranny fluid at 70k miles for the first time and used Mobil 1 Dexron VI and I think it was definitely a good choice because its been 10k miles now and no problems. I'm gong to continue to change the tranny fluid every 30k miles going forward and hope to make it past 150k (when I'll probably sell the car).
Old 03-22-2010, 11:31 AM
phoenixreborn's Avatar
phoenixreborn phoenixreborn is offline
I'm an agent of chaos
Send a message via AIM to phoenixreborn
Mein Auto: '02 530i
I got a the dreaded gear and my DSC light came on yesterday. Symptoms include abrupt jerky shifts into D and seemingly no first gear.
How can you move faster than possible, fight longer than possible without the most powerful impulse of the spirit: the fear of death
Old 03-24-2010, 10:21 AM
fm_illuminatus's Avatar
fm_illuminatus fm_illuminatus is offline
Mein Auto: '07 MCSa, '04 325iA SULEV
So in conclusion, from this poll, about 20% of E46 owners have needed a transmission replacement.
Old 03-24-2010, 11:33 AM
spacegeek spacegeek is offline
Mein Auto: 335d, 330ci
Got 193K on mine, with original transmission. Regular fluid changes, etc but nothing out of the ordinary.
Old 03-26-2010, 10:40 AM
hyper64 hyper64 is offline
Mein Auto: bmw 330xi
Smile 2001 330xi Automatic Tranny
bought car used at 74k nothing wrong with it, now it has 97K on it. I only changed the ATF fluid and gear oil at 90k with Red Line and it still drives like brand new. So much fun to drive, it is still tight no prob what so ever. my mechanic tells me it will easily get 1/4 m miles on it no problem their just stong cars.
Old 03-26-2010, 04:42 PM
Linhansell Linhansell is offline
Mein Auto: Z3 Roadster
Unhappy Transmission control box and transmission replaced
My Z3 just turned 60,000. The warning indicator light came on several times and we went thru the ritual and everything was OK for awhile. Then, it didn't correct the problem. Had my car towed in and the repair person replaced the control box. When the new one arrived, it blew out and we knew the transmission was kaput...... I replaced the transmission because I love my car and thought it was the wise thing to do. Very sad in Chapel Hill.
Old 03-30-2010, 09:23 AM
jimjavad jimjavad is offline
Mein Auto: E46 318i
My car has same symptoms so what happened for your case
Old 03-30-2010, 09:26 AM
Mein Auto: E46 318i
Mine started to slip at 75 Kmeter
you can read more here
http://www.bimmerfest.com/forums/sho...144&highlight=
Any help would be highly appreciated
Old 04-02-2010, 07:16 PM
jgraves's Avatar
jgraves jgraves is offline
Mein Auto: 318i,325i,330i,328ci
I currently have 116k miles on my engine and transmission. I have never had any problems with the transmission at all, because I've changed all the fluids in the rear differential, transmission, and transmission filter every year.
Old 04-13-2010, 02:00 AM
MechTrav MechTrav is offline
Mein Auto: 2004 325xi
I'm just shy of 125k and not a problem. My mechanic says he can see where the trans cooler has leaked at one point, but there is no evidence of a current issue, and not enough was lost to even detect when checking it. I've never seen a drop in my garage. It must be considered though, that it has been taken care of meticilously its whole life.
Old 04-14-2010, 08:50 PM
nathandimond nathandimond is offline
Mein Auto: 2001 BMW 330i 5-speed
Are there any signs to tip me off that my transmission is failing or will I go to leave for work one day and find that my car has turned into a real expensive paperweight.
Old 04-19-2010, 12:20 AM
cotomoto cotomoto is offline
Mein Auto: CA
I just started thinking about that lifetime tranny oil the last couple of days. Mine is 03 - 65K now with no problem but never changed the tranny oil. May be I should drain and refill or something. I do not like this car any more. I will sell as soon as possible and go back to Honda or Toyota.
Old 04-19-2010, 04:05 AM
TechGuy TechGuy is offline
Mein Auto: E46 325i
It really depends on driving style. We have had some coming in the w'shop at a mere 30K and I have a customer with 165K on the clock and it's still beating like it's new. It mostly depends on whether they are towing something with the car or are they constantly in S mode making manual shifts causing the oil to overheat. But normally a heavily used gearbox shall undergo an oil and filter change at about 80K.
Old 04-20-2010, 11:12 AM
BimmersRule!'s Avatar
BimmersRule! BimmersRule! is offline
Send a message via MSN to BimmersRule!
Mein Auto: 325I
I'm at 106k and no problems so far (knocking on wood). Reading this thread is making me nervous, since I have not changed my transmission fluid or replaced anything related to the tranny......
Speed limits are just a suggestion
Old 04-21-2010, 11:33 AM
Starless Starless is offline
Mein Auto: 2002 325i Auto
86K car here. GM tranny, changed the oil myself at 85K. Put in Texaco 8072B (the original fill). No problems so far. Old oil was not bad at all. I do not know about lifetime but I believe one can get 125K out of the original oil easily. However changing the filter is always a good thing. If everything is done right it should be only for the better. The write-up in my signature.
Old 04-29-2010, 05:32 PM
roguedeadman77 roguedeadman77 is offline
Mein Auto: 2003 330xi
I don't think the tranny is goin on my 03 330xi, but when I start mine after it's been sitting in the sun or hot weather it shifts fine into D but seems to stay in neutral and the engine just revs for a couple seconds until it shifts into first and goes fine.. 82000 on the odometer
Old 04-29-2010, 05:48 PM
bmw1453's Avatar
bmw1453 bmw1453 is offline
2nd Gen. Turkish Bimmer
Send a message via Yahoo to bmw1453
Mein Auto: 02' 330XI Auto.
2002 330XI @92.500+ no problems at the moment but i do not trust any kind of auto trannies...you never know. 92.500 fine, 92.501 may broke... manu rocks...
Old 05-04-2010, 11:20 AM
bimmerb*tch325 bimmerb*tch325 is offline
Mein Auto: 2004 325Ci Sports Package
help :/
http://www.bimmerfest.com/forums/sho...=1#post5156636
Old 05-05-2010, 05:46 AM
ROCKYTOP2's Avatar
ROCKYTOP2 ROCKYTOP2 is offline
Mein Auto: 2007 550i
Sry man I can not help here... Good luck and let us know.
07' 550i
Burgundy interior, nav, mint!
Old 05-09-2010, 01:31 PM
Problemeveryday's Avatar
Problemeveryday Problemeveryday is offline
Mein Auto: 2011 335i coupe
03 330i 83k miles as of today
ive been having problems ever since warranty expired. especially when the car is stopped, i have this huge vibration problem but hopefully after i clean the MAF sensor it will fix it. but other then that my trany is about to fall lol everytime it changes gear i feel like someone just hit my bumper from behind. i changed the fluid and filter but still the same ****.
Old 05-16-2010, 08:27 PM
zx6turnedbmw zx6turnedbmw is offline
Mein Auto: zx6r
is there a poll for manual trans? sorry if there is, I'm a newbie. thanks for the help
1990 mustang convertible... barley running
2004 zx6r 636 edition.... crashed and almost died from it thank god im alive
2004 bmw 325i... new toy
Photobucket
Old 05-16-2010, 08:56 PM
tturedraider's Avatar
Freedom isn't free!!
I don't think there is. BMW manual trannys are pretty bullet proof.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- Geo. Orwell
2006 330i Sonora w/ ActiveAutoWerke flash tune :-)
2004 330i ZHP Imola/NB - missed
2000 328i TiAg - gone but not forgotten
** Join the BMW CCA www.bmwcca.org
member #388003 - Use me as a referral & you could win a one day ///M Driving School!! **
Old 05-16-2010, 09:27 PM
Mein Auto: zx6r
ok thanks for the answer im looking to get an 04 325i 5 speed with 69k on it. will it hang with all these other autos? 100k? 120k?
Photobucket
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
