Old 05-28-2008, 08:39 PM
rtrevino rtrevino is offline
Mein Auto: 528i
1997 528i OBD port location
Hi Everyone, I'm the new owner of a 528i, and I just cant seem to find the obd port anypalce.
I've tried the left side below the steering wheel
all help is appreciated
Thnks!
Raul
Old 05-28-2008, 09:19 PM
JBss's Avatar
JBss JBss is offline
ASC OFF
Mein Auto: 528i
isnt it right below the steering wheel where you just mentioned?
Mad Photo Skillz - Flickr
This is with the NAWZ
Old 05-28-2008, 09:21 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
bottom left. look up and deep
when in doubt, use the pac man
americandan.com
It takes a lot of work to be lazy.
Old 05-28-2008, 09:27 PM
NNY528i NNY528i is offline
Mein Auto: 1997 528i
you already found it but there is another cover on the plug beneath the cover you see from the outside.(ie there are 2 covers a cosmetic one and another one below it)
>'97 528i, 175400 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers
>'87 528e, 210000 miles, mice, mouse nests, mouse pee smell, style 31s >'65 & '74 MG Midgets BFC OT Lego Club #48
Old 05-28-2008, 09:36 PM
Mein Auto: 528i
I, have checks what you guy told me and still no luck, I'll pot pics tomorrow with better light, but as far as i see...
I have some kind of small box attached with 2 screws, removed them already and found nothing (maybe its here but I didnt look for that "other" cover as for going low and deep I have a big black plastic cover with a whole lot more screws in (i really believe its not here.)
i'll cehck on tomorrow and if i have trouble with it i'l snap a pic
Thnks
Raul
Old 05-28-2008, 09:47 PM
Thnks
Raul
There is a cover that say OBD on it to left and below the steering wheel on the knee bolster just above the hood lever and the trunk button. Beneath that cover is the OBD plug with black plastic cover on it. There are 2 screws one on either side of the black plastic cover that you see. If you grasp the sides of the cover and pull straight back the plug will be miraculously revealed to you. I think what you are describing as a small box with 2 screws is actually the cover i am talking about. Try pulling on it and see what happens.
Old 05-29-2008, 06:03 AM
Max_VQ Max_VQ is offline
Mein Auto: little red wagon
I thought only 2001+ had the OBD-2 port to the left of the steering wheel.
From 1987-2000 is the round port under the hood.
Old 05-29-2008, 06:27 AM
Mine has one, I was staring at it last night and I have plugged my scanner into it a couple of times now.
Old 05-29-2008, 06:59 AM
spydrz's Avatar
spydrz spydrz is offline
Sandlapper Chapter
Mein Auto: 2001 525iA
The non-US model has different dash padding...the port might be in a different place in the OP's car.
1984 318i/man./Tornadorot*
1990 525i/man./Alpinweiß*
2001 525i/man./SP/PP/Cosmosschwarz/Sandbeige*
2002 X5 3.0i/man./SP/PP/Sirius/BT/Titansilber/Sandbeige*
2006 330i/man./SP/PP/CWP/Sirius/Blackline/Rear Fogs/Arktis/Grau*
2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige*
2012 VW Golf R/Rising Blue
*retired
Old 01-05-2010, 01:47 AM
crossfire_M5 crossfire_M5 is offline
Mein Auto: 5 series
I have the same issue with this thing.. my car is a 528i 1997 made in 96
went i got this car one day a Sir scan my car in the OBD port above the steering wheel (The normal one) it passed a year and my check engine light appear and i want to scan to see what it is..
The problem is there is no damn plug inside the port or nothing similar to plug in with an normal autozone scaanner ... and it use to be one..
What can i Do to reset my Codes? and elminate the check engine light or faulty codes?..
What other opcion do i have?
Do they sell the Plug that goes inside ?
Old 01-05-2010, 09:17 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
There's always the round 20 pin DLC connector in the engine bay.
Q {BMW CCA Member #191509}
(SOLD)
Old 01-05-2010, 11:49 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
The DLC under the dash is the one that BMW uses, up to 2001, however, all cars destined for the USA (and other parts of the world, too, depending on adoption of OBD) require the OBD II port under the dash. It's there!
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
