E46 (1999 - 2006)
Old 06-06-2008, 06:36 AM
davidross1 davidross1 is offline
Mein Auto: 2001 330 Ci
how do reset service counters 330Ci 2001??
Have just carried out service on 33oCi 2001. Also changed the brake fluid. how do i reset the oil service indicator and how do i reset the little clock for the brake fluid change?? pls help. thanks
Old 06-06-2008, 07:54 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Welcome! It's in the Wiki...
http://www.bimmerfest.com/wiki/index...vice_indicator
Jeff R.
Old 06-06-2008, 12:20 PM
Jimp1114 Jimp1114 is offline
Mein Auto: 2001 330 CI
This will work
You need to hold the odometer button down for about 5 seconds when you turn the key from off (position 0) to accessory (prosition 1). When you first turn the key, you will see "test 1", don't let go of the odometer button until the display changes to show "reset". Once you see "reset", let the odometer button up, then press and hold it again for about 5 seconds until the "reset" starts flashing. Once it is flashing, let up on the odometer button then press it one more time. Now you should see a message that says "END SIA" and your oil service light should be reset. This worked for me on my 2001 330ci.
Old 06-06-2008, 05:49 PM
Thanks. worked at second attempt of trying.
Old 06-17-2008, 11:12 PM
boufarik boufarik is offline
Mein Auto: 320i
Originally Posted by Jimp1114 View Post
This will work
hi, i bought 2001 320i 3 days ago from gm dealer, he changed the oil before i picked it up the car, when i turn the engine on, i drive few seconds the oil light come out for 10 seconds and then it goes, am i supposed to reset the oil light.
Thank you
Old 06-17-2008, 11:29 PM
jvr826's Avatar
Is it Trackday yet?
Thank you
This is different, it is the oil level sensor IF the oil light is YELLOW. If it is RED, you have low oil pressure and should not drive the car. Most likely it's yellow.
Check the oil level and make sure it's on the high side of correct and this light won't be a bother any longer.
If you need an owner manual, check the Wiki at the top of the forum for links.
Welcome to the 'Fest!
Jeff R.
Old 06-17-2008, 11:35 PM
Mein Auto: 320i
it yallow, i will check the oil level.
Thank you again
Old 06-19-2008, 05:30 AM
Erregend's Avatar
Erregend Erregend is offline
535i M-Sport ED May 2011
Mein Auto: '11 M-Spt 535i & '04 SLK
Note: It is very common for this oil level sensor to fail in older E46's.
Mine (2001 330i) failed last year. It will come on for 10 seconds every time you start and drive off in your car.
It was a simple 15 minute job to replace at an oil change if you can get the car up high enough that you can get under and work at the rear of the oil pan.
