Questions for e39 DICE Silverline users
I am ready to get the DICE Silverline from EAS but have some questions for e39 users, specifically non-DSP variants. The only real decision is between the radio or the trunk install. The original EAS thread in Jan announcing the availability of the Silverline system seemed to indicate some issues with various early users (not a surprise), given the lengthy thread. Mostly with other models (non-e39). Tom did a great job in responding. So here are some questions specifically for e39 users:
1. Given four months of use, what is your opinion of the Silverline? Would you do it again? 2. The trunk variant definitely appears an easy DIY install. For radio install users, is there any feedback on the degree of difficulty for the radio install? Any special tools required? 3. For those with the trunk version, have any experienced problems with noise? If yes, was there any cure? Your feedback is greatly appreciated. |
Let me know if you have any further questions!
Tom G. | european auto source (eas) email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 | ca: 714.369.8524 x22 | fax: 714.908.1796 Blog | Facebook | YouTube | Flickr | Twitter |
Darn, I just ordered the trunk interface version. No worries. I would like to put the iPod in my center console compartment for easy access. Thanx for the help! i look forward to installing it!
Hey Fudman, I wonder how it's working for you. I've had the the radio kit for my 2000 E39 Non-DSP and I still have not figured out why I can't see my playlists. It plays and sounds great but no text...
Are you sure you have a SILVERLINE kit?
That's what I ordered and what the Installation Guide/User Manual that came with it says...
If you can shed any light on this issue, it would be great? All the Dip switches are up. And have I disconnected the ipod and car battery for 15 minutes, several times...
Pressing CD6/TRACK4, then CD1 will place the text on the MID. CD2 is your Playlists.
I've tried CD6/TRACK4, then CD1 and the screen comes up blank and then individual letters begin to cycle in the 1st character(far left) location of the head unit screen. CD2 also doesn't give me any text. I can control the iPod from both the head unit and the steering wheel via the arrows.
1. Disconnect iPod from cable 2. Remove battery cables, negative first 3. Touch battery cable terminals together (away from battery) for +5 seconds, a small spark is normal as this is stored power draining from the system. 4. Allow cables to remain disconnected for about 5-7 minutes 5. Reconnect battery cables onto battery, negative last. 6. Reboot iPod by pressing on MENU and CENTER buttons for +5 seconds and then reconnecting to the DICE cable after the reboot process is completed. Let me know if these steps correct the problem
Just yesterday (in the 95 degree heat) I installed a DICE SILVERLINE kit into my '03 540 wagon. The instructions provided through BSW were great and it was a straight-forward project. I went with the console docking station (2point5) and that too went easier than I would have imagined.
It sounds great, though I'm still learning to navigate various playlists, etc. SILVERLINE is relatively intuitive. I'm a neophite to the iPod as well, so I've got learning curves at both ends. The only tip I can offer with a wagon is to use a straightened metal coat hanger to thread the wiring harness from the back area through the rear seat. Saves you from having to remove the panel in the rear cargo area. |
Will do Tom. Thanks! It will be a few days before I report back as I'm traveling on business the next few days.
"1. Given four months of use, what is your opinion of the Silverline? Would you do it again?"
Absolutely, if it was for my car. Not sure if I would do it for my wife again though. She didn't have much patience or willingness to figure it out herself. Things are slower and not as straightforward as "put cd into cd player". I may have just opted for one of EAS's aux audio input kits if I was going to do it for my wife again. Ours worked for a while, then failed. Tom @ EAS and I went back and forth via email trying to figure out what was going on. He was very helpful and patient, but I wasn't so I asked if my wife could stop by so he could just take a quick look at it. He agreed to meet later that day and promptly got everything working. So if you decide to get the Silverline, I highly recommend EAS |
I've had mine installed for over a month now and absolutely love it. I have the trunk cable routed into my armrest console, where I store the iPod. A completely invisible install. This gives me ready access to the iPod instead of keeping it in the trunk. Total install time took about 30 minutes. Ratign: Easy as pie.
All in all, the system works great. The iPod will occasionally have a hiccup at the end of a song but I just disconnect, reconnect and I'm back in business. Absolutely no issues with the dash readout. And the sound quality is a huge step up from the FM transmitter with no more annoying power line buzz. A great complement to upgraded speakers and armrest subwoofer. Tom at EAS was very helpful in answering questions and helping out on an initial install glitch. Those instructions he just sent tonite worked for me. It is great to have such good product support. Tom & EAS is highly recommended! |
Hey Tom, FINALLY got it playing and listing songs after following these instructions...you should include these under the trouble-shooting section.
Thanks again! R Quote:
![]() Thanks for following up.
ok i'm a noob when it comes to installs and anything to do with electronics.
i want the dice kit but as it stated in this thread....you can choose to have it installed in the trunk or radio?? correct? will it charge my ipod when the car is on? also does it come with a dock to place the ipod in?? any info would be great my cars a 98 non dsp
The basic DICE kit has either the trunk or the radio interface. I'd recommend the trunk interface for easier install (longer cable will go anywhere). The DICE will charge your iPod when the car is on. It does not include the docking stand which is additional $. The DICE attachment cable looks just like the computer cable provided by Apple. I routed my trunk cable into my center console compartment, where I have easy access. The DICE works like a charm. Two thumbs up!
also there a jack in my glove box, whats that for, can dice be hooked up through that??
chiefwej 2003 540i ///m-tech 6-speed Black Sapphire Metallic w/gray
I was initially going to put my iPod in the trunk too, but put it in the center console for easier access. I have had the occasional (twice since Jun) glitch, where the iPod freezes up. I have had to disconnect the iPod and reconnect it to the cable. Works fine after that. Easy to do while driving when in the center console compartment. |
Do you have Business Cassette or Navigation?
Business Cassette but i have some sort of jack in the glove box...... there used to be a cd changer but i think it was sold off.....
There's no factory-supplied jack in your model year, can you post a picture?
#25
it looks lie a aux line.....i'll snap a pic in a few
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
