Mileage Check In... - Page 21 - Bimmerfest - BMW Forums
Old 12-23-2013, 12:13 PM
SonicBoom SonicBoom is offline
Gearhead
Mein Auto: 2007 X3
2007
120k miles
Old 12-23-2013, 03:04 PM
bobbyp bobbyp is offline
Mein Auto: '98 m3, '10 X3 3.0i
2010 x3 3.0i - 12,000 mi.
Old 12-23-2013, 03:54 PM
madurodave's Avatar
madurodave madurodave is offline
BMW Enthusiast!
Mein Auto: 2007 Z4+X3, 2006 530Xi
Mileage Check In...
Wow! New X3!
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 12-23-2013, 04:04 PM
x3brian x3brian is offline
Mein Auto: X3
Mileage Check In...
That's it??????
I had that on my 09 well before 2009 finished as being the calendar year.
Check my list of PMs above. With that low of mileage you are still very much due for every fluid change I have done....
Old 12-24-2013, 05:36 AM
I bought this in March 2013 from out of state dealer with 4k miles. Paperwork says it was executive car. Loaded Black/Oyster with 18" rims. Under new car warranty until May 2014 (and extended after for 3 years). I won't be replacing any fluids until next spring. Thanks for the list. Only concern I have is a slight whine in the transfer case at 40mph which local dealer says is "normal". Love this SAV. Hate BMW navigation.
Old 12-24-2013, 06:53 AM
Mein Auto: X3
Mileage Check In...
That is awesome!
Slight whine I assure you isn't normal (we have the exact same car...I just have 17in tires).
One of three things come to mind causing this:
1) one of your tires has a slightly different outside diameter than the others. The xfer case is very sensitive to this. When the diameter is drastically different it mostly causes very load clunk noises especially when turning.
2) time for xfer case and differential fluid change.
3) tire design is noisy and you are hearing road whine at spread from the tread pattern.
The e83 has a cruddy nav. I agree. It is technology from circa 2003 and wasn't brought to moderne standards until the f25 refresh in late 2010 for the 2011 my.
Old 12-24-2013, 07:47 AM
Casselx Casselx is offline
Mein Auto: 2006 BMW x3, 3.0i
Mileage Check In...
2006 with 82k. Running strong, time for some maintenance, but still going
Old 12-24-2013, 10:57 AM
Originally Posted by x3brian View Post
That is awesome!
Dealers...
I first thought it was tires and asked service manager when I took him on a drive to hear the noise. He said no. It makes no noise at 40mph if I'm applying throttle - or - if I put it in neutral and coast. Noise only when coasting in gear at 40mph. I also asked for a fluid change. He said it probably wouldn't help. He also said that if he replaced the transfer case it may quiet down or it may just end up making the noise at a different speed. I'll bring it in again in the spring when the fluid thins out with the warmer weather. Noise was a bit louder this past summer. And, maybe I'll rotate the tires to see if the noise travels to another part of the car.
Anyway, absolutely great car in every other aspect. Even got to take it out in a recent snow and it performed well.
Thanks for taking the time to reply.
Cheers!
Old 12-27-2013, 10:06 PM
Mein Auto: X3
Mileage Check In...
My 09 hit 130,000 miles this morning. No troubles to report.
Old 12-31-2013, 07:44 AM
kenza kenza is offline
Mein Auto: 2007 X3 2.0d MT
07 here - 107K miles (172.000 kms). Preparing to buy a third set of new shoes in 10-15K (will stick with 17" Scorpions)
Old 01-01-2014, 08:21 AM
911 911 is offline
Mein Auto: 2005 X3, 2004 911 Cabrio
My '05 (original owner - Feb '05 European Deliver) hit 100K miles week before the holidays - at 100,364 today and counting.
Old 01-03-2014, 12:29 AM
ngcreese's Avatar
ngcreese ngcreese is offline
Mein Auto: '11 X3
141K on my '07 3.0si...
Put in new Bilstein HD shocks & struts, upper & lower control arms, ball joints, and front / rear wheel bearings.
Looks like there's a small oil seal leak between engine and tranny just starting up. Glad I did the other work myself. Don't think I can do this one on my own.
'11 X3 xDrive35i -- Coded
'07 X3 3.0si -- Coded & Traded
'91 e30 325i -- Sold
BMWCCA Member
Old 01-14-2014, 07:53 PM
madurodave's Avatar
BMW Enthusiast!
Over 155k now!Click image for larger version
Madurodave
Member of BMWCCA!
Old 01-16-2014, 03:58 PM
neosimago neosimago is offline
nsmgo 2006 X3
Mein Auto: 2006 X3
79,000 for a 2006 X3
Old 01-24-2014, 07:58 AM
bmwsigmanu bmwsigmanu is offline
Mein Auto: X3
2005 X3 3.0 106,500 Runs Great
Old 01-24-2014, 10:54 AM
Desslok Desslok is offline
Mein Auto: X3
2004 X3 3.0 with 125,xxx
It has been a great SUV for us.
Old 03-02-2014, 09:02 AM
iamthewalrus iamthewalrus is offline
Mein Auto: 2014 X1 xDrive35i
Originally Posted by iamthewalrus View Post
Just 48,500 miles on my 2006 X3 3.0i (m-sport, 6-spd manual, xenons, pdc, premium pkg)
Since I started walking to work, I'm barely putting on ~10 miles in a typical week. I really only use my X3 to go hiking, x-country skiing, or road trips to Portland and Vancouver.
-James
Seattle, WA
4 months later, I crossed the 49K mark! At this rate, I'll be driving my X3 for decades more...
Old 03-02-2014, 09:14 AM
328 M Sport 328 M Sport is offline
Mein Auto: 2013 328 M Sport
2013 328i M Sport; 24,000 miles in 8 months. Been parked for winter since November.
ID:	425835   Click image for larger version
ID:	425836   Click image for larger version
Old 03-02-2014, 03:01 PM
Mein Auto: X3
Mileage Check In...
^^^show off. I love the estoril blue!
09 at 128,960. No issues to report. Just put on new Michelins 2k miles ago (3rd set of tires). Still runs and looks new...
3 sets of tires
16 oil changes
3 transmission fluid changes
3 front/rear differential fluid changes
3 transfer case fluid changes
2 brake fluid changes
1 coolant flush
1 power steering flush
2 sets of spark plugs
1 set of rear pads (75k miles)
1 set of front pads/rotors (100k miles)
1 set of struts and shocks
3 alignments
Hit 135k on Friday.
No new issues but am getting an intermittent fault code for a box fan short. Showed up about 1000 miles ago. I cleared it when I changed the oil and it hasn't reappeared yet on my weekly fault scan. Keeping my eye on it.
Now at
17 oil changes
4 transmission changes
4 transfer case fluid changes
4 differential fluid changes.
Old 03-04-2014, 12:03 PM
amiratish amiratish is offline
Mein Auto: BMW X3 Si
2008, X3 SI, 158K KM and no problem at all
Old 03-04-2014, 12:32 PM
Gearhead
Mein Auto: 2007 X3
2007
125k miles
Old 03-04-2014, 01:12 PM
Roos_Goos Roos_Goos is offline
Mein Auto: BMW X3
2007 3.0si recently hit 103k miles.
Lots of work done right before.
- VCG
- Spark Plugs
- Oil and Filter change
- Oil filter housing gasket
- Thermo
- Waterpump
- Trans oil and filter change
- Trans software update
- Rear T-case fluid change
- Bilstein HD's in all 4 corners
- REPAIR BILL - $2,800 USD
I think that was all of it.
Old 03-11-2014, 08:09 PM
madurodave's Avatar
BMW Enthusiast!
Getting up there!
Madurodave
Member of BMWCCA!
Old 03-24-2014, 08:51 AM
madurodave's Avatar
BMW Enthusiast!
Turned 160k this morning.
All is well.
Carry on, X3, carry on!
Madurodave
Member of BMWCCA!
Old 03-24-2014, 09:22 AM
YetiVanHalen YetiVanHalen is offline
Mein Auto: X3
05 x3 at 92K. Have owned it as a CPO since 41K.
replaced:
1.) valve cover gasket - DIY
2.) spark plugs - DIY
3.) coolant overflow tank - mechanic said it cracked.
4.) brake caliper - mechanic said brake fluid bleed nipple stripped.
5.) engine oil/filter every 10k. DIY
6.) one set of brakes at 55K.
7.) oil filter element holder gasket.
8.) one set of Hankook Tires - Done by Pepboys.
10.) converted to K&N air filter
12.) cabin filter - replace after every spring pollenation.
13.) replaced passenger drl twice
Broken - panoramic sunroof sunshade - the two shades sepoerated now only the front slides and the rear i have to adjust by hand. Afraid to use any further.
