how many quarts of oil. 1999 323i - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 06-13-2008, 10:31 AM
stevenj's Avatar
stevenj stevenj is offline
DIY Enthusiast
Mein Auto: 1999 323i ZSP
about to change the oil by myself for the first time in my 1999 323i bmw and am wondering how many quarts of oil this should take???
and would it make a difference if i mixed about 3 quarts of 5w30 with 10w30? or should i really try to get it all the same?
Old 06-13-2008, 11:04 AM
KeithS KeithS is offline
Mein Auto: '11 335d, '17 340iGT
Technically 6.8, but I throw in the full 7. It places the level a tad over the full mark, and when I change the oil after 8K miles it's right on the full mark.
You can mix similar weight oils wihout issue. However best use one that is BMW-LL1 approved (it will be printed on the back of the bottle if it is)
Most common ones are:
BMW 5-30 Synthetic (a custom formuallion from Castrol)
Castrol European Syntec 0-30 (made in Germany, NOT USA)
Mobil1 0-40.
WAM's Avatar
WAM WAM is offline
ober-slacker
Send a message via AIM to WAM
Mein Auto: 325i Sport
You have the M52TU engine which should be the same as the M54 engines, 6.5 liters, or 6.9 quarts.
I don't know why you want to mix oils.
Old 06-13-2008, 11:16 AM
stevenj's Avatar
DIY Enthusiast
ok
dont "want" to mix oils.. but its what i have on hand... 7 quarts or a little bit less... thanks,.
Old 06-13-2008, 11:27 AM
stevenj's Avatar
DIY Enthusiast
hey
am i supposed to refill the canister filter compartment with oil? or does filling the engine with 7 quarts of oil take care of this automaticaly?
Old 06-13-2008, 11:37 AM
You only put the oil in the engine, the filter canister will fill up once engine is started. Aslo know that you need to replace the oil filter (or at least open the canister) BEFORE you put the pan drain plug back in. Reason is once you break the seal on the filter canister, about a quart of old oil will dump back into the pan.
Old 06-13-2008, 11:46 AM
stevenj's Avatar
DIY Enthusiast
thanks
thank you, i was smart enough to realize that the oil from the canister would dump back into the pan and had already removed the filter. however i didnt know that the oil in the canister would refill automaticly. thank you for all of your help.
