Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 06-22-2008, 04:19 PM
Longshlong Longshlong is offline
Mein Auto: 1983 BMW 533i
need new rearend for 83 533i
need a used rear end
Old 06-23-2008, 07:41 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
Ebay or mye28 For sale/want to Buy section. You can end up with improved acceleration if you look for a "taller" gear set. You first need to know what it is installed in your car. There is a small metal tag on the diff under one of the bolts and it has the ratio on it (2.93, 3.25) if it has an "S" it is a limited slip differential which is the preferred one (great if you need to drive on snow!).
Good Luck!
Jimmy Moreno
1995 530i
1986 535i
HTML code is Off
