Old 06-23-2008, 01:50 PM
bigpeps bigpeps is offline
Mein Auto: z3 2000
Exclamation z3 2000 transmission warning light
Trans warning light came on when I was backing out of my driveway which is on hill. I drove awhile and stopped then restarted the engine and the light went away. What is this all about. It happened twice in the lasr week. Any advice?
Old 06-23-2008, 03:01 PM
GBimmer GBimmer is offline
Banned
Mein Auto: 1998 M Roadster
From your DIY post: if it's the light that has a broken circle around it, it's just a brake pad sensor. Check your pads for wear as either the front or rear need to be changed. The sensors are located on the left front pad and right pad.
Old 06-24-2008, 06:05 AM
Mein Auto: z3 2000
Thanks for the reply, after looking at it is a closed circle with gears around the edges and an exclamation point in the middle
Old 06-24-2008, 07:35 AM
Banned
brake wear sensor warning light.
Does it look like this but with teo dashed lines around the outside instead of two solid lines?\
Better yet, just take a pic of the light.
Old 06-24-2008, 01:39 PM
Mein Auto: z3 2000
Since the car didn't come with an owners manual, I couldn't figure it out. I was able to download a manual this morning and it says it is the transmission warning light. The tranmission was shifting ok. It said if this light comes on the tranny woulg go into 3rd gear only. This didn't happen.
Old 07-30-2008, 08:16 PM
mharrison mharrison is offline
Mein Auto: 2000 BMW Z3 2.8 Roadster
My transmission light comes on from time to time. It tends to happen more when it is raining, so I suspect a short. No behavior changes, it still works fine.
I wouldn't expect too many responses on this as there aren't very many of us Automatic owners on here.
Old 08-05-2008, 10:24 AM
aljean aljean is offline
Mein Auto: 2000 Z3 2.8 Coupe
I have same warning light
.For the last 6 months, the transmission light comes on periodically...sometimes months will go by, sometimes 2-3 times in a week..the owners manual says, pull over, turn off engine, set parking brakem wait a miniute and restart...that works, almost as if they were aware of the impending problem..anyway, according to our local dealer, as long as that the car(ours is a 2000 Z3 2.8 Coupe) runs OK not to worry, just an erratic sensor issue, though I cannot figure what the parking brake has to do with it
Old 08-05-2008, 10:38 AM
ronnie38 ronnie38 is offline
Mein Auto: Z3, 325IC, 325E
I have a 2000 2.8 auto and it does the same thing the code said brake light sensor, but I swear that it comes on in a tight turn with out hitting the brake so I'm going to have the transmission fluid changed and replace the brake light. I got a 135K on the clock so it's time to dump the life-time fluid.
Old 04-19-2010, 01:51 PM
bosestereo bosestereo is offline
Mein Auto: z3
Transmission light
The same thing happened to me.
It was a faulty low brake pressure switch that lights the (gear / exclamation). $275 to diagnose and install.
Old 04-19-2010, 05:59 PM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: Z3 2.3iA/5MT 528iA VW GTI
Yeah it's the brake pedal switch, it's a $35.00 part that you can DIY.
Mine still does it from time to time because I've been too lazy to replace it.
Old 04-08-2011, 07:51 AM
tabongiorno tabongiorno is offline
Mein Auto: 2000 Z-3
transmission light on and off
I have the same issue with the transmission light coming on. I do one of two things. Pull over, shut engine off, set emergency brake. This generally takes care of it. I also have the little reset tool to plug in under the hood. That also works. I'm confussed about the break wear sensor response from one of your readers. Were is this located and how easy a fix is it. Why are these two sesors tied together. When the transmission light is on, the cruise control does not work?
Old 04-08-2011, 08:33 AM
Mein Auto: z3
Transmission Light
partsgeek.com
http://www.partsgeek.com/gbproducts/...ek+Google+Base
1998-2002 BMW Z3 Brake Pressure Switch OES Genuine
Retail Price: $139.23
Your Price: $117.64
Select Year 1998 1999 2000 2001 2002
Part Number: 1191-01121383
Notes: DSC pressure sensor @ master cylinder
Brand: OES Genuine
Availability: In Stock
Condition: New
Shipping Options:
Ground, Overnight, 2 Day
This Product Fits the Following: Catalog: Replacement 1
Vehicle Engine
1998 BMW Z3 2.8L 6 Cyl
1999 BMW Z3 2.5L 6 Cyl
1999 BMW Z3 2.8L 6 Cyl
2000 BMW Z3 2.5L 6 Cyl
2000 BMW Z3 2.8L 6 Cyl
2001 BMW Z3
2002 BMW Z3
Old 04-08-2011, 10:10 AM
FZbar FZbar is offline
Mein Auto: 2002 Z3 2.5 Roadster
I think there are two issues being discussed here. The auto transmission light usually is accompanied with no display of what gear you are in when you are in manual mode. This usually is related to the transmission control module.
The brake warning light is different & is usually related to the solenoid being talked about.
Fred
Old 04-08-2011, 11:39 AM
Mein Auto: z3
transmission light
I am not a tech. Call Steve Thomas BMW (805) 482-8878, ask for service and what they did to the 2000 z3 with the vin ending in G02317 about 1 year ago.
I was told a brake sensor problem fired my transmission light. The following sensors are usually part of the transmission: MPLS (Manual Linkage Position Sensor), input and output speed sensors, shift solenoids, and governor sensor.
Please be aware that some sensors are not part of the transmission itself, but in other areas of the vehicle. These include the TPS (Throttle Position Sensor), the MAS (Mass Airflow Sensor), MAP (Manifold Absolute Pressure sensor), PCM (Power Control Module or Computer), DSS (Differential Speed Sensor), CTS (Coolant Temperature Sensor), IAT (Intake Air Temperature) and because they are interelated can give false readings.
Old 12-31-2011, 12:05 PM
ronpolley ronpolley is offline
car poor all my life
Mein Auto: 2001 Z3 3.0i Auto
Z3 Auto Trans Light ON
As with others of you my Amber Gear Light came on this weekend,thanks for all the clues.I'll post a fix when I locate it.
2001 Z3 3.0 Auto 118,346mi
Old 01-01-2012, 08:53 AM
RedRig RedRig is offline
Mein Auto: 2001 Z3 Roadster
Had the same problem last Oct. with my 2001 3.0 Check out this thread: Z3 Transmission warning light 10/5/11
Old 03-19-2016, 08:05 AM
larry12 larry12 is offline
Mein Auto: 2000 z3
transmission warning light 2000 Z3
thought I read on here, something about replacing the brake pedal switch. I had no other symptoms, other than the light would come on occasionally. ordered one from advanced for less than 20 bucks. and it seemed to work. have added about 250 miles.
Old 03-21-2016, 12:59 PM
paultowle paultowle is offline
Mein Auto: 99 z-3
I have this problem too from time to time. I have original fluid and 410k miles. Still runs great.
Old 03-21-2016, 02:09 PM
Mein Auto: 2000 z3
the way I understood it is if the trans is acting fine the its the brake light switch. so far so good for me. its located up under the dash. found the instructions on how to get to it on bimmerfest. good luck.
