E46 (1999 - 2006)
Old 06-26-2008, 08:49 PM
BMWayne BMWayne is offline
Mein Auto: 2002; titanium 325 Cic
car makes a weird smell after my usual redline driving
So after i drive my usual spirited way, i notice a burnt popcorn smell. Anyone know what that is?
2002 convertible - 18 inch SSR GT3
Old 06-26-2008, 09:01 PM
kimmy's Avatar
kimmy kimmy is offline
Das rampen abwarten
Mein Auto: 04 330xi,Audi A6,AlfaSpid
Squirrels have been sneaking under your hood at night and storing corn from your neighbors' bird feeders on your exhaust manifold in preparation for a long winter?
Old 06-26-2008, 09:09 PM
cant be that. My bmw is low carb,so any corn would show a weight gain Kimmy.
Old 06-26-2008, 09:12 PM
dboy11 dboy11 is offline
Mein Auto: 99...540i
Maybe slow down and run the car at less than RL
Its Going To Cost How Much???????
Old 06-26-2008, 09:31 PM
dubis dubis is offline
Mein Auto: 325Ci
Smells like corn-based, ethanol blend.
Old 06-26-2008, 10:18 PM
Nice area you live in!!
Old 06-27-2008, 06:59 AM
Narcisse91 Narcisse91 is offline
Mein Auto: A few choices
I can't think of anything that smells like burnt popcorn, but a smell after hard acceleration is usually the clutch, in my experience.
Old 06-27-2008, 08:11 AM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
burnt atf smells like that.(burnt popcorn that is)
Old 06-27-2008, 08:32 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Have you looked under the hood? The power steering reservoir, which uses ATF fluid, has a breather hole in it that leaks fluid all over the place during aggressive cornering maneuvers. I cover mine with a tube sock to soak it up.
Jeff R.
Old 06-27-2008, 08:58 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Good point. It could also be a valve cover gasket (or other) oil leak. As you rev it hard the pressure picks up and can leak out onto hot parts. I have the same problem, my valve cover is leaking all over the place!
Old 06-29-2008, 08:51 PM
so i drove around today really spirited and the burnt popcorn smell was worse than ever. I looked for any liquid and didnt see it. Now what? should i be worried?
~A
Old 06-29-2008, 09:05 PM
Noamsky Noamsky is offline
Mein Auto: 328
I'd do a pretty thorough hose inspection. I had the same problem after pushing mine, and it turned out to be leaking power steering hoses. Replaced the failing factory clamps with the screw-tight kind, and now she's
Old 06-29-2008, 09:07 PM
Synaps3 Synaps3 is offline
Holy Flamebait, Batman!
Mein Auto: 2001 BMW 325xi Sedan
I'm putting my money in leaky power steering hoses.
Old 07-02-2008, 06:06 PM
Theres been no leaks (unless its collecting somewhere at the bottom of the engine bay,but i would smell it right?). I drove very modestly and there was no smell at all. So it has to deal with redlining, what could it be?
Old 07-02-2008, 08:18 PM
Mein Auto: 328
I only seemed to smell it after maintaining high rpm's on the interstate. My leak was under the reservoir, where the the hoses connected. If you're not finding one anywhere, then I don't know.
Old 08-18-2008, 12:21 PM
cla325 cla325 is offline
Mein Auto: 325i - e46
I have the same smell problem - e46 325 - 2001
Hi Guys,
Recently I encountered the same problem. I was driving in the mountains and the automatic gear box used to change the speeds from 5 to 3 and the RPM use to go over 4000 sometimes... than the smell use to appear and than disappear after a while when the road got better (no more up and down); also, if I drive a bit more sporty same thing happens - bad smell, like hot engine, even though the temperature in dashboard was normal. Did you find out where is it coming from? I do not see any leaks. What can it be?
