Old 06-30-2008, 07:17 PM
nuttybgc nuttybgc is offline
Mein Auto: 98 BMW 740il
98 740iL - Brake lights warning issue...
My brake lights are working fine but the brake lights warning comes on... Is it something wrong with my electrical wiring stuff? Anyone knows anything about this?
Old 07-01-2008, 09:34 AM
NC BMW Driver NC BMW Driver is offline
Mein Auto: 735il, M5
Try this - it is probably the "mustard relay".
http://evansweb.info/articles/2003/0...d-relay-repair
Mark
'91 735il
Old 07-01-2008, 11:15 AM
TerryY's Avatar
TerryY TerryY is offline
Old Fogey
Mein Auto: BMW '95 840
Do the lights in the third (center) light come on too?
Terry
Woodland Washington
'95 840Ci
'98 740i
'00 Range Rover Vitesse
www.wuffer.net
www.8coupe.com
www.8er.org
Old 07-02-2008, 03:23 PM
It doesn't come on. What does it suppose to mean?
Old 07-02-2008, 03:57 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
The brake warning is likely trying to tell you your CHMSL (Center High Mounted Stop Light), aka the third brake light bulb, is out. Replace it and the error may go away.
Also, corrosion of the connections of the bulb sockets/holders can cause a false error message (all if the lights are illuminating).
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 07-03-2008, 04:06 PM
crewdog843's Avatar
crewdog843 crewdog843 is offline
Mein Auto: '08 Z4 3.0si Roadie
Did you have any luck?
jake
Old 07-06-2008, 09:17 AM
jake
Oh I'm outta town for a week so I haven't tried yet, but I'll let you know when I do.
Old 08-06-2008, 01:38 PM
Where exactly is this fuse box located at?
Old 08-06-2008, 02:03 PM
TerryY's Avatar
Old Fogey
The Mustard relay was an early E32 problem. Your E38 has a far more advanced light control system.
Terry
Woodland Washington
'95 840Ci
'98 740i
www.wuffer.net
www.8coupe.com
www.8er.org
Old 10-18-2008, 01:08 PM
So where is this fuse box located at?
Old 10-18-2008, 02:48 PM
M.Wong's Avatar
Mein Auto: The E38
Two places:
Under the hood, passenger (US) side near base of windshield.
Trunk by the battery behind black felt-like insulation.
M.Wong
Old 10-18-2008, 08:51 PM
Originally Posted by M.Wong View Post
Two places:
All my fuses are good so I don't get why it's showing to check the brake lights?
Old 10-18-2008, 11:39 PM
M.Wong's Avatar
Mein Auto: The E38
Wait, do all three brake lights illuminate on the back of your car when the brake pedal is depressed? If not, that is your first issue. The "check brake light" warning on your dash will trigger if all three are not working.
Do none of them come on? If that is the case, you may have a pedal switch issue, or something more complex within the electrical system.
Do just the two (left and right), or just the third (center) come on? If that is the case, have you changed the bulbs? People have reported that aftermarket bulbs are more likely to cause the "check brake light" error due to resistance or impedence (or something?), but others have not had the same concern.
If all three lights work and you get the error message, you could have corrosion at the sockets and the light housings themselves. People have replaced their sockets, or even their tail lights, if cleaning the conctact points didn't work.
M.Wong
Old 10-26-2008, 02:16 PM
Well, when the break pedal is depressed the middle and the bottom right lights don't come on and only the bottom left light illuminates on both the taillights.
Old 10-26-2008, 02:37 PM
dannyc9997's Avatar
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
Well, when the break pedal is depressed the middle and the bottom right lights don't come on and only the bottom left light illuminates.
Well its probably just burnt out bulbs then. If you want to make sure so you dont waste your time going to the store (and 2$) take the bulb out of the working light (since you know that bulb is good) and put it in the center light socket, check if it works, then in the right socket and check. If it works in those 2 then you just need 2 new bulbs. If it doesnt then you have other problems (bad socket...no power to the socket ect)
Old 11-07-2008, 10:18 AM
So are you saying when the brake pedal is depressed the center light suppose to come on too? Because mine doesn't but when I turn the headlights on that center one illuminates...
Old 10-12-2009, 08:17 PM
biglata biglata is offline
Mein Auto: bmw 740il
break light
hello!! i have a problem with my break light on my bmw 740 il , when ever i start the car the break light come's on in the back even driving !! can anyone help me with this please
Old 10-12-2009, 09:01 PM
TerryY's Avatar
Old Fogey
The brake light switch mounted at the brake pedal is your problem. It is either broken or needs adjustment if the brake lights are always on.
Terry
Woodland Washington
'95 840Ci
'98 740i
www.wuffer.net
www.8coupe.com
www.8er.org
Old 10-13-2009, 07:09 PM
97E38Bimmer 97E38Bimmer is offline
Mein Auto: 1997 bmw 740i
You've gotten a lot of good advice, pointing you in the right direction. I will add to the discussion by saying that if you have at least one light working, you probably don't have any major issues to consider. Sounds like you have a combination of small occurences. Pull all bulbs and compare the internal elements (filament) to the known good bulb. If any don't match the known good one, replace it. Most of the time, the high mount (third brake light) bulb is blown.
The other problem sounds like you may have corroded or contorted prongs in the bulb sockets themselves. A very simple fix with a good quality pick, scribe, or any other sturdy but small-tipped tool, and lot of patience and eye for detail should do the trick.
To diagnose a little further, take the known good bulb and place in the sockets that are not lighting up. Upon depressing the brake pedal, if the known good bulb does not illuminate, then you know that socket needs repair or worse case scenario, replacing.
Hope this helps.
Old 10-14-2009, 09:20 AM
mom rocks mom rocks is offline
Mein Auto: 740i
I too have gotten the same warning. I was thinking it was just cause it rained.
Old 12-26-2012, 05:00 PM
cwbilb2407 cwbilb2407 is offline
Mein Auto: 1998 BMW 740IL
1998 BMW 740IL Brake Lights not working
Hello. My 1998 BMW brake lights on both left and right side will not work. I changed the light bulbs, sockets, and cleaned the place where the socket is inserted. I also checked the fuses. Please help.
Old 12-28-2012, 07:46 AM
BMWFatherFigure's Avatar
Old School
Wiring problems for cwbilb2407. Check with volt meter.
Current:
E38 Parts Car
Previous:
Old 02-26-2016, 05:13 AM
wikkel wikkel is offline
Mein Auto: 525i 2001
I solved the problem after many months of trials by cleaning ALL the contacts of ALL the holders as well as the the asses of all the bulbs and it rectified the problem. Remember the light above the boot lid. Wikkels StBosch Cape Town ZA
HTML code is Off
