Z4MC Sway Bar Mounts... check for tightness! - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 07-03-2008, 07:28 PM
stephenti stephenti is offline
Mein Auto: cars
I was driving my car this afternoon after not having it for a few days, and heard a new sound... an occassional muted slight clunking noise on the right side. It seemed to have went away before I had a chance to investigate fully, so I didn't give it much thought.
It turns out, the right rear sway mount is missing... the rubber bushing was still there, but that was it. Spotted thanks to the sharp-eyes over at RPI. I've never touched the mounts up to this point, nor have anyone else.
So just as a FYI, check the allen bolts to make sure they're tight when you get a chance.
I called the local dealership... they'll have it for me on Tuesday w/ the bolts.
Old 07-03-2008, 08:36 PM
RobMCoupe RobMCoupe is offline
Mein Auto: 2007 Z4M Coupe
I had the same issue a couple of months back. It took the dealer two days to figured it out. The re-torque the rear sway bar and subframe bolt. Make sure you check the subframe bolts too.
Old 07-03-2008, 09:18 PM
Ron Stygar's Avatar
19,585 Miles
You talking about part #4 in the following:
http://www.realoem.com/bmw/showparts...37&hg=33&fg=45
Old 07-03-2008, 09:22 PM
Ron Stygar's Avatar
19,585 Miles
What subframe bolts are you talking about?
http://www.realoem.com/bmw/showparts...33&hg=33&fg=30
Old 07-04-2008, 08:53 AM
Ron,
I'm not sure because I didn't talk to the tech. See the work performed from my work order.
Old 07-09-2008, 02:51 PM
Mein Auto: cars
Yes, part# 3 & 4... except that part#s have been superseded. Or, at least, that's what the parts guy told me.
Stabilizer Support: 33 55 6 780 707 retail $2.46
I've been told the old part is plastic. The new part is metal. I wire-brushed it, and shot it flat black before remounting.
Fllister-Head Screw: 07 11 9 905 070 retail $.38
10mm Hex now intead of cap screw. Didn't notice class. Make sure you use thread-lock. Easy job, takes 10min.
I checked the driver's side, and they were tight. Also noticed plenty of left-over thread-lock. Don't know if there's been history of only one side, or both. But mine happened to the passenger side.
Old 07-09-2008, 04:16 PM
Ron Stygar's Avatar
19,585 Miles
33 55 1 096 697 $2.40r was ceded by 33 55 6 7 780 707 $2.46r. They are exchangeable. 697 weighs more than 707.
07 11 9 905 070 is not used on the Z4M. Maybe they (dealer) thought it was better. M8x20-10.9 ZNS3.
07 11 9 901 023 $0.53r M8x16 ZNS was ceded by 07 11 9 904 101 M8x16-8.8 ZNS3 $0.29r. They are not exchangeable. Looks like the change was for the no chrome coating ZNS3.
Old 07-09-2008, 05:04 PM
Ron Stygar's Avatar
19,585 Miles
Just looked at mine. The blue lines (means they torqued it) were in line on all four bolts.
Torque value is 22 Nm.
Old 07-10-2008, 05:30 AM
pal's Avatar
pal pal is offline
S54=Living on the Edge
Mein Auto: 2007 M Coupe, 2004 Audi T
Well timed post ... I had heard a muted clunk from the rear passenger side once a few weeks ago when turning left at 5-8 mph into my driveway. I visually checked for anything obvious in there but came back with nothing ... did not happen since so forgot about it.
Ordered the new bolts and mounts from Tischer today and will change them out once I get them in.
Old 07-10-2008, 07:16 AM
Ron Stygar's Avatar
19,585 Miles
Are your bolts loose?
Old 07-10-2008, 10:36 AM
pal's Avatar
pal pal is offline
Don't think so, but since I heard the clunk once and there is a superceded part I figured I may as well be OCD about it esp since I am going to Pocono next weekend.
Old 07-10-2008, 10:43 AM
Mein Auto: cars
I've got the same OCD... ordered the driver's side yesterday.
Old 07-10-2008, 11:22 AM
Ron Stygar's Avatar
19,585 Miles
The bolt is the same except for the zinc coating. The brackets are exchangeable. What you should do is safety wire them.
Old 07-10-2008, 12:26 PM
pal's Avatar
pal pal is offline
I am not equipped for that ... at least I don't think I am. Never done it before.
What tools do I need besides a drill and fine bits? Do I need any special type of "wire" ...
Old 07-10-2008, 03:46 PM
jmillet's Avatar
jmillet jmillet is offline
Mein Auto: E86 Z4 M Coupe 7LM08376
Thumbs up Tight
Prepping my car for the track tomorrow so checked the rear sway-bar bracket bolts and they are all tight (22N*m).
The 6mm female Allen head bolt is somewhat unusual and the top ones are a PITA to get at.
Jim Millet
2007 Imola Red Z4 M Coupe'
Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates.
Old 07-10-2008, 03:59 PM
Ron Stygar's Avatar
19,585 Miles
My 2006 brackets are metal not plastic.
Was the flange of the screw serrated?
<img src="http://bimmerfest.com/forums/attachment.php?attachmentid=153224&stc=1">
<img src="http://bimmerfest.com/forums/attachment.php?attachmentid=153225&stc=1">
Old 07-10-2008, 04:01 PM
Ron Stygar's Avatar
19,585 Miles
Did you have the middle duct off?
Old 07-10-2008, 05:07 PM
Mein Auto: cars
Just took a magnet to the factory driver's side... it is metal as well for my '06. Painted black. As for the bolts... I don't recall them being clearly serrated, but I don't think they were smooth either. When I pick up the bolts next week, I'll let you know. Regardless though, I think serrated is the way to go. Heck, if you really wanted to, I think you can actually get a long enough bolt, and put a lock nut on the other side.
Old 07-12-2008, 01:08 PM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
Prepping my car for Buttonwillow next weekend, and two of the sway-bar bracket bolts were loose. Top one on the driver's side bracket, and bottom one on the passenger side bracket. The top driver's side one is just barely tight, the passenger bottom one is completely lose (the bolt had turned about 60 degrees looking at the blue paint mark on the bolt).
I replaced the allen head bolts with regular 8.8 grade hex bolt of the same size and slathered on some blue loctite.
On a completely unrelated topic, what I thought was going to be a 20 minute job turned into a 3 hour nightmare. I bought some washers/shim and a longer bolt from Turner Motorsports to add a little extra negative camber up front to preserve my tires, and on the very last bolt I managed to cross-thread the bolt. Made about 2 full turns when I realized it was cross-threaded, backed it out but the damage was already done. Took another 2 hours and 30 minutes and some serious HACK ingenuity, and copious amount of red loctite but managed to get the thing threaded back in right and torqued it down to 77ft-lbs. Hopefully no permeneant damage is done.
On another completely unrelated topic, visually inspected the engine mount bolts and all appear to be in good order. Since the engine mount and engine mount bolts are shared with the E46 M3, I wonder if the ones with the engine mount problems are built within a small window where the wrong hardware or a particularly careless assembly worker worked on the car. If we can get the VINs of the cars with the engine mount issues, maybe we can prove/dispel this engine mount problem.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 07-17-2008, 12:10 PM
Ron Stygar's Avatar
19,585 Miles
Wedge lock washer
McMaster-Carr91812A230 $11.41 for10.
May use them on the motor mount brackets too.
http://www.nord-lock.com/default.asp?url=1.16.37
<img src="http://bimmerfest.com/forums/attachment.php?attachmentid=153906&stc=1">
<img src="http://bimmerfest.com/forums/attachment.php?attachmentid=153907&stc=1">
<img src="http://bimmerfest.com/forums/attachment.php?attachmentid=153908&stc=1">
ID:	153906   Click image for larger version
ID:	153907   Click image for larger version
Old 07-18-2008, 08:58 AM
Mein Auto: cars
Good find.
Just as another data point, I ordered a backup sway mount... and this time, instead of bare metal, it was powdercoated black. This was in a span of less than a week apart in ordering. Really makes me wonder about BMW...
Old 07-18-2008, 07:20 PM
Ron Stygar's Avatar
19,585 Miles
Good find.
My stock ones are black. The two parts shown for the Z4 M are interchangeable.
The non black ones I've seen are Zinc plated.
Old 07-19-2008, 09:58 PM
Ron Stygar's Avatar
19,585 Miles
Nord-locks installed
Basically easy to get to with the center duct removed. 1.5 inch extension.
Did one at a time. Torque is 22 Nm.
<img src="http://bimmerfest.com/forums/attachment.php?attachmentid=154131&stc=1">
<img src="http://bimmerfest.com/forums/attachment.php?attachmentid=154132&stc=1">
ID:	154131   Click image for larger version
Old 07-20-2008, 12:13 AM
Mein Auto: cars
I jacked up the rear, and w/o removing anything, was able to access the passenger's side using sockets and driver's side w/ these:
EDIT: Now that I think about it, it's probably b/c the SS Race cans are much smaller than stock. Literally takes but minutes.
Old 07-20-2008, 08:22 AM
Ron Stygar's Avatar
19,585 Miles
How did you torque them?
HTML code is Off
