E90/E91/E92/E93 (2006 - 2013)
#451
good call, yep, just checked, not even close
#452
front cargo latches
Any idea what the p/n# is? I asked my dealer and they said they were welded on. I think there is a misunderstanding going on
#453
Sorry for the delayed response. I have been away. The service advisor is a moron. The holes are pretapped. I have the receipt for the hardware, I have to find it. go to the parts counter and order the hardware. Then you have the option of installing it yourself or having them do it for you. I will find the receipt and get back to you.
2011 335i Xdrive. Blue Water metallic Sport with 18" rims/Prem/Cold Weather/Nav/M steering wheel upgrade 2007 X3 Montego Blue, Sport with 19" rims/Prem/Cold Weather/Xenons. Returned, but definitely not forgotten. 1997 AMG C36 1992 190e 2.6 2004 X3 (retired) 1999 C230 Kompressor w/ sport package (retired) |
#454
Here is the parts list: 4 Socket head cap screw 51-47-7-130-768 2.19 ea 2 Cover, Fastening loop 51-47-7-132-893 1.76 ea 2 Fastening loop 51-47-7-129-196 12.80 ea 2 Cover fastening loop 51-47-7-129-652 2.10 ea Labor 1 hour, which probably means about 40 minutes! Hope this helps.
#455
So I finally got my tire mounted today and it is sitting in the back of the trunk with a 6 foot ratchet strap. It seems to move a tad back there and isn't completely fastened down but considering the weight it should work. I put the strap hooks in the same holes where the release switches for the rear folding seats connect (as shown a few pages before this one).
One question I had is what PSI I should put on the tire. I would generally crank it up a bit to ensure the tire has air when I REALLY need it. My local Firestone shot the tire up to 55 PSI. Is that a safe pressure? If I actually mounted it tonight I probably would drop it down to whatever I am running on that axel but just wondering what pressure is good to keep the tire at sitting in the trunk.
2009 328i Sedan - Ordered: 2/24/09 .:. Delivered: 5/6/09 Jet Black | Black Dakota | Aluminum | Premium | Sport | Xenon | CA | Split Fold Seats ![]() |
#456
As per the manual or is that a "general rule" for donut spares? I assume then also you should drop the pressure once you mount it? 60 PSI seems steep but I am no tire expert. The few times I have mounted a spare before I just wanted to make sure they had some pressure on them.
#458
the pressure should NOT be dropped. |
#459
For now I am using two large ovalish holes further back that somehow works a bit but am still investigating better mounting options. I also used a 6 foot ratchet strap for my install and it looks just like the pictures you provide. I am surprised yours stays on so tight. Did you have another person hold the wheel in place while you ratchedted it in? I did it by myself, which is a challenge.
#461
2009 E91 Montego Blue w/ Gray Dakota 6AT ZPP/Logic7/Sirius/Idrive/Butt warmers/6FL/PCD/CA/6NL/Xenons |
#462
Hi ORIENT,
Im sure this has been answered somewhere in this thread, but I went through 9 pages and I can't read anymore ![]() Will any E60 (ie 05 525i) Sapre fit an 09 328i? or does it have to be specifically a 550i? Thanks |
#463
C-Dub, you asked about the correct pressure for the donut spare. Take a look at the sidewall, the inflation pressure is always molded into it. It is usually 60-65psi but I have seen different.
#464
it should, the spare was the same across all the E60s (AFAIK)
#465
Thanks Orient,
And where can I find this handy tire net, seems to be the best option to store a spare or is there a better alternative? |
#466
I am embarrassed I did not think of the pressure to size ratio myself...
#467
Made the switch...
Thanks to all who have posted on this thread. Replaced the OEM run flats with Michelin Pilot Sport A/S last Saturday (Seattle rain 9/12 months...) - should have done it sooner, the difference in the ride is huge! Still need to get put them to the test on dry roads but I don't think we'll be disappointed.
Ordered the donut spare from Tischer last week. Took about 8 days to get to Seattle (they had to order the tire from BMW - took an extra couple of days). The tire price has gone up about $50 from earlier posts - new part number and price but I think it is the same tire that they had before. Excellent customer service though (Thanks Jason). Upgraded to the better jack as other have done and am pleased with what I received - Jack fits in the small storage are under the carpet in the trunk. The entire setup is not cheap, but this is a one time cost and I still saved over buying a new set of run flats. Shopped the tire elsewhere but couldn't save more than a $10 or so, so I stuck with Tischer for the whole package. Part Number Part Description Price Total 71106773536 SET LIFTING JACK $140.00 $140.00 36116758778 EMERG.WHEEL $60.00 $60.00 36121116326 VALVE $2.26 $2.26 36110306541* REIFEN CONTINENTAL C $126.00 $126.00 51470010557 OEM BMW Boot/Trunk Floor Cargo Net $55.00 $55.00 Sub Total $383.26 Shipping $54.95 Tax $0.00 Total $438. Discount Tire mounted the tire for under $9.00 and I put in on the front as a test (2008 335i Coupe/Sport Package). No problems with clearance on the calipers and test drive was uneventful. Also ordered a custom bag for the spare from the "Bag Lady" (http://www.njbaglady.com/) for $40. Looks to be a pretty nice item. Hope to see this in early January - I'll post a picture when it arrives. Thanks to all. |
#468
I will purchase a jack and a used wheel to mount a full size normal tire for use as a spare. I will lose some trunk space-but its a worthwhile trade for the security of having a spare tire that I can drive on with no limitation. RunFlat tire availability is not good in rural California! I travel a lot in California wine country-being "stranded" 3-6 days waiting for a RFT is not practical for me. It is disappointing that BMW does not supply a "real tire" for the 355i convertible!
#469
deleted-doublepost
#470
fwiw, i just picked up a nice scissor jack from the local parts store for $25, and its built very well, test lifted the car with no problems.
i keep a 1/2" breaker bar in all of my cars with the appropriate deep well socket for the wheel studs, and will keep one of my snow tires in the trunk at all times now. more space consuming for sure, but another option. |
#471
If anybody is interested I have a rim I took off my 09 335ix. It's the original 17" type 188, with 10 V spokes. I got rid of my run flats and in the process got conned by the local tire seller. Any way I have one I mounted a runflat to for a spare and have another I have no need for. I don't want it to hang around so the price would be right and I would also throught in a runflat. I had the rim checked out and there is nothing wrong with it. It has a little scratch on the lip that I don't think wouold be visible with th tire mounted. I am planning on taking a few pictures tomorrow or the next day if I get to busy. I am in Connecticut if a looksee is in order. A fair price with the tire that has 26000 miles on it is $150. My email is Icut@operamail.com and fone is 203-281-3851. I also have a brand new sicssor jack that is the same size as the BMW kit jack that I will throw in.
#472
I live in rural California- RFT availability here is app 4-10days! I elected to purchase the BMW jack kit, (app $150) a reconditioned spare wheel-$300 and two new Brigestone tires. Put the new tires on car-used the best RFT for the spare and placed it in the trunk. When my RFT are worn-I will replace with regular tires. The wheel and tire does take considerable space-but there wasn't really much usable room there to start-I consider it a worthwhile addition. I now have a spare that I can use with no distance or speed limitations. The hard top stows in the trunk OK! BMW should rethink this problem-or reduce pricing to reflect missing wheel and tire!
#474
buy a bottle of slim and a mini compressor
2004 X3 MINE'S 2007 328XI WIFE'S |
#475
wont work on a sidewall rupture or a large enough nail.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
