E90/E91/E92/E93 (2006 - 2013)
Old 03-27-2012, 04:51 PM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i
Thats a nice shot
Originally Posted by Cruzcat View Post
Sorry to bump up this thread but I was finally able to test out the spare tire after 2.5 years.
My wife had a flat on the rear right tire at work about 15 miles from home. The AAA guys fixed the spare and my wife got home last night without any issues. I took the car today to the tire shop to get a replacement.
Just wanted to commend Orient330 for his ingenuity. Tks mate. The E60 spare worked perfectly fine.
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 833 Lincoln Ave, Suite 5, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
Old 04-25-2012, 04:25 PM
dragarwal dragarwal is offline
Mein Auto: BMW 335CI
BMW 335i Convertible 2009 tires
I have 2009 BMW 335i convertible with sports package. It has 24K miles. Front two tires have run out of all tread to safely drive. Back two tires can still run couple of years. I live in Louisiana. It does not snow. I am looking for tire to work in heat and rain. I would appreciate any good suggestion.
Old 04-25-2012, 04:59 PM
JimMetcalf JimMetcalf is offline
Mein Auto: 135i coupe
Go to Costco and take a look at both the Brigestone and Michellin tires that are not run flats. They will last longer, run quieter and cost only half as much as the run-flats. Keep your best run-flat-get a wheel and mount the tire -put in in trunk-buy a (BMW) jack and torgue wrench with the $ you save by buying NON-run-flats-put them under trunk floor---end of problem!
Old 04-25-2012, 08:25 PM
stoked335d stoked335d is offline
Mein Auto: 335d
Don't mix and match run-flats and regular tires. Get rid off the rears on craiglist/ebay. Go to tirerack.com and have them ship to an authorized installer a set of non-RFT 4 Michelin Pilot PS2. Get the donut/spare kit as suggested in this thread (which I already have).That's what I do.
Old 04-30-2012, 11:33 AM
Thanks for good suggestion. Micheline Pilot AS plus is going to last longer. It has got good reviews. However, my front tires are 225/40/18 and rear tires are 255/35/18. BMW 335 convertible has very small room in luggage. I can hardly put one tire in. Which side tire I should put in spare.
Old 04-30-2012, 12:19 PM
Use the tire with the most tread. Spare is for temporary use, while you have the flat/damaged tire repaired/replaced.
Old 05-02-2012, 07:08 AM
bimmerzone's Avatar
Supporting Vendor
Mein Auto: E63 650i
definitely get the non run flats and the spare tire combo. I probably would not use half run flats and half regular.
Old 08-01-2012, 08:16 AM
mrmax1984 mrmax1984 is offline
Mein Auto: Dodge Ram 1500
Update on Kit Details
I stumbled onto this thread for the same reasons as everyone else. However, this kit is discontinued. I talked to Jason Reighard at getbmwparts.com(Formerly known as Tischer BMW), and he provided me with the new "kit". It's basically all of the same components, but the tire comes unmounted.
Here's the link: http://www.trademotion.com/partlocat...catalogid=4462
Old 09-01-2012, 01:28 PM
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
broken record
sounding like one now. I highly suggest that you get the scissor style jack instead of the goofy leaning thing in this kit. Tischer has the other kit with the scissor style. I put together my own kit only buying the rim and valve stem from Tischer. I used an X5 (E53 or E70 doesn't matter) scissor and it works perfectly. I bought the jack. jack handle, and lug wrench (17 mm) on ebay. I already have a torque wrench and use 88 lb-ft as the spec per dealer advice.
Old 09-26-2012, 07:30 PM
SGCoupe SGCoupe is offline
Mein Auto: '09 E92
Sold!
2009 Space Gray, Saddle/Black E92
Old 09-27-2012, 03:21 AM
bimmerzone's Avatar
Supporting Vendor
Mein Auto: E63 650i
If anyone is interested in the kit that is already mounted do check out
http://www.bimmerzone.com/BMW_Perfor...T-E90-KIT.html
Old 09-27-2012, 08:54 AM
RBinDC RBinDC is offline
Mein Auto: 335is Coupe
Originally Posted by SGCoupe View Post
This is the trunk of my E92 that I traded today. This new, unused Tischer spare and BMW premium jack kit with pre-set torque wrench are available. Complete spare wheel and mounted tire alone - no jack $200 - Tischer cost $315 with cheap jack. OEM BMW Jack Set 71106773536 $100 - Tischer cost $145. I'm in South Florida and local pickup is preferred. If not will ship for actual cost.
I noticed you are using that webbed cover to hold the spare in place. In an accident the spare tire could become a missile hazard because that cover is not strong enough to secure the spare in place. You had better hope the rear seat latches are strong enough to keep the seat locked in the upright position.
I secured my spare tire with heavy duty cargo straps that pass through all four eyelets in the trunk.
Old 09-27-2012, 11:38 AM
Mein Auto: '09 E92
Thanks for the tip...
Old 11-17-2012, 07:29 AM
dme369 dme369 is offline
Mein Auto: X3
E90 Spare Kit For Sale
I have the E90 Spare Kit w/ carrying bag. from Bavarian Auto for sale.
$250 plus shipping.
Old 11-23-2012, 09:06 AM
luv2ride2 luv2ride2 is offline
Mein Auto: 2008 335i Convertible
Question.
New to the forum and thanks in advance for any help. Wondering if there is a spare tire option that will work for my 2008 335i convertible??? Thanks
Old 11-23-2012, 12:05 PM
bimmerzone's Avatar
Supporting Vendor
Mein Auto: E63 650i
Hi
The spare tire option that we offer does fit the convertible (it also fits in the trunk) For a picture do take a look at:
scroll to the bottom of the page
Originally Posted by luv2ride2 View Post
Question.
Old 12-01-2012, 12:40 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
for those moving on to the F30, i think we can adapt this spare tire kit to fit. unfortunately it will require a spacer (something i wanted to avoid). i'll know more in about two weeks
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 12-05-2012, 07:46 AM
bimmerzone's Avatar
Supporting Vendor
Mein Auto: E63 650i
We actually did try it, but it could not fit, a spacer was needed, we decided to go with the bigger wheel (and unfortunately more expensive Bridgestone tire) and maintaining the outer rolling diameter at 26 inches
Old 12-05-2012, 02:21 PM
captainaudio's Avatar
Worlds Foremost Authority
Mein Auto: 335i E93 - 750Lix
Originally Posted by bimmerzone View Post
Hi
After the spare is installed what do you do with the tire that came off the car?
CA
Drivers Club at Lime Rock
The Glen Club
BMWCCA
Cayman Club Nor'Easters
Sports Car Club of America
American Mural Project
Old 12-17-2012, 04:17 AM
Henry3tt Henry3tt is offline
Mein Auto: 2010 335I/M SPORT
Not to sound naive ,But does anyone have pictures of how the spare kit would fit
in a 2010 335iM coupe under the trunk lid . I know I have to remove the original plastic assortment box under that lid . would like to see how it fit before ordering one . Thanks
Old 12-17-2012, 05:12 AM
bimmerzone's Avatar
Supporting Vendor
Mein Auto: E63 650i
Unfortunately its not going to be able to fit under the trunk mat, would have to be over the trunk mat, and strapped down. It does take up some trunk space, but at least its a space saver spare.
Old 12-17-2012, 09:04 AM
Lufthansa Lufthansa is offline
Mein Auto: 2010 E92; '07Lexus GS350
I bought the Tischer kit and have it in the trunk of my 328 Coupe. I put it in a garbage bag, and have the container with the tools settled in the middle recess of the wheel (on top of the bag). I secured it with the netting that came in the trunk of my Lexus, and it works fine, as would cargo straps, etc. On a cross-country trip last year I folded the rear seats down and pushed the spare onto the backs. It was then held in place by my luggage.
Old 12-31-2012, 05:10 AM
bimmerzone's Avatar
Supporting Vendor
Mein Auto: E63 650i
We finally had a chance to test on the 328i. The spare tire on the E90 actually fits the F30 328i (NOT the 335i as the brakes are too big, we tested that a while back)
Old 01-01-2013, 08:54 PM
supremegpc supremegpc is offline
supremegpc
Send a message via Skype™ to supremegpc
Mein Auto: 2008 328 xi
Can't afford to lose any room in the trunk but a spare is a must.
Old 01-03-2013, 07:13 PM
DrT's Avatar
DrT DrT is offline
BMW CCA Member
Mein Auto: 10' 328i Cp;12' X5 35d
Does any one have any pictures showing application?
2010 328i M Sport Package, BMW Performance Exhaust & Short Shift Kit.
