Fan clutch & fan <== is it time for replacement?
hi all-- my 2000 528i is now aproaching 95k miles. is this a good time to replace the fan and fan clutch? my fan and fan clutch looks to be in good condition but i need you guys to tell me if it's time for replacement.
fyi: there are no signs of temperature issues and what not. i just saw a member's hood badly damage due to a fan failure. thanks, john |
In one word: YES.
Take the opportunity to do a COOLING SYSTEM OVERHAUL. You are sitting on a time-bomb. Here is the DIY: http://www.bimmerboard.com/forums/posts/199986 http://www.bimmerfest.com/forums/sho...d.php?t=213002 |
I would replace it, no doubt. While you are at it, change the waterpump and thermostat, and cooling fluid. inspect all hoses, fan blades
do not wait for trouble, it is cheaper to prevent than to repair with e39. The problem with the cooling system is one of the above items fails, leads to problems in all of the others, trust me, I have been there last month. good luck
**delete**
Yeah, it needs to be replaced.
All of the cooling system, except for the fan clutch (which, at the time, was "okay" according to the mechanic), was replaced on our 2000 528i at 90K miles. By then, the radiator had developed a small leak and the thermostat was stuck open, throwing me SES codes about low coolant temperature. Then at 100K, I noticed a rumbling sound coming from the fan area. Replacing the fan clutch fixed that. Do it all at once. Saves you on labor, too. |
thank you all.
i calculated everything, it will cost me between $650-$750 on parts alone. i will be doing this cooling system job myself after i get all the parts needed. |
I dunno, I had a fan clutch on my 325i that lasted over 200k and is still just fine. Personally, I think a lot of the problems are really caused by failed waterpumps that cause the fan clutches to do the damage to the car. The fan clutches get the blame when it was actually the water pump that caused the problem.
2007 Z4 M coupe Premium Pkg, Heated Seats, ZHP shift knob, Satellite Radio (XM) from EAS 2003 530i 5-speed, SP, PP, CWP, Xenon Bilstein Sports UUC short shifter with DSSR and ZHP shift knob Michelin Pilot Sport A/S BSW IQ speakers, Sirius CDV delete Huper Optik tint 2007 X3 3.0si 6-speed manual, CWP, Xenon, Cft. Seats, Premium Pkg, Sirius, Privacy glass |
mhughett,
I agree with your statement but there are members here who have fan clutch toasted at 100-120K. Fan Clutch: $95. Fan Clutch failure: $3K damage: fan blades flying, hood damaged, paint/body work etc etc. Not worth it to keep the fan clutch after 100K miles, in my opinion. Search the forum using terms: "fan clutch seized hood". http://www.bimmerfest.com/forums/sho...an+clutch+hood http://www.bimmerfest.com/forums/sho...d.php?t=235823 --------- astigracing, Waterpump: I use HEPU brand as in the write-up; if not sure use only dealer WP; Geba can leak. Fan Blade: Stay away from "MTC" brand it is garbage. I tried to save a few dollars by using "MTC" Fan Blade, it cracked after one year. Use only Dealer Fan Blade. The rest: use the brands in my write-up. Last edited by cn90; 07-15-2008 at 08:02 PM. |
I think my clutch has 140k on it...will be doing the rad and water pump soon cant do the rest due to lack of funds lol
cn90-- thank you.
radiator Bher at this place, I purchased mine there. I think it was a good price
http://cgi.ebay.com/ebaymotors/ws/eB...065174180&rd=1
i have my cooling system all apart now after reading the DIY link above and im all ready to order parts...But i have some questions about the thermost. I have a 2001 530i and not 97 528i and when i took the thermostat housing apart it was different than in the write up the thermostat and housing are together as one unit it seems.I also looked on autohaus.com to find the thermostat and they had the dual thermostat and housing for my car and not seperate....My question is do i buy this thermostat and housing and if so how do i or do i at all have to drill the small hole in thermostat? also were do i get the HEPU waterpump for my car.
99-2003 5series used electrical thermostat. So you are correct, buy the thermostat+housing (as a combo unit) for your car. Get a long drill bit, put a small masking tape on so you only drill 2mm (to avoid drilling the housing) and drill slowly at 12 o'clock position. 2. http://www.eeuroparts.com/Main/PartsResults.aspx carries HEPU Waterpump for $62.00. I have had HEPU WP now for 3 years, knock on wood no problem at all. I just saw that http://www.eeuroparts.com/Main/PartsResults.aspx carries Febi Fan Blade. That is good brand. Febi is good. HTH! |
i would skip on the mechanical fan clutch and the fan blade and just invest in an electric fan. reduces stress on the water pump
americandan.com
![]() ![]() ![]() It takes a lot of work to be lazy. |
OK so i still drill the hole...i should have asked before but what is the purpose of drilling the hole and why is there not a hole already in the thermostat???
My fan blades seem to be in perfect condition so i wasn't going to replace them...i did replace the clutch thou.I wasn't going t replace the Reservoir either because it looks like its in perfect condition at least from the outside. thanks alot Also im not sure what coolant to get when i drained it it cane out blue.Do i use this blue stuff? Last edited by E39530i; 01-22-2009 at 09:24 PM. Reason: forgot to write |
do the fan clutch. Isn't it worth the $100 to not worry about a dented hood, cut hoses, belts and all the other parts that get ruined if the fan explodes?
2003 530i 5sp Bilstein HD Powerflex UCA bushings CDV Delete M5 Rear Sway Rogue WSR & Short Shifter Rogue Tranny Mounts Euro Armrest Aspheric side mirrors Custom Dension iPod mount Bluetooth 2001 740i Short Sport Completely stock...for now |
I checked my 01 530 and it still has its original Behr 12/00 radiator at 146K miles. The thermostat is 03 though.
1Can you tell us more on electric fan fitmemt? 2Can shabbaman tell me where you obtained parts for euro armrest and prices? thanks |
The hole is there to allow trapped air to escape. Some tstats come from factory with holes some don't. IDK why! (Wahler tstat for my 98 Volvo V70 has a hole, the same Wahler tstat for my 98 BMW has no hole). The phenemenon of air lock has bothered mechanics for 30-50 years. So drilling a tiny hole in the tstat is on old trick! 2. Fan Blades may look perfect now, but when they go, they take the hood with them, Now you are talking $2-3K repair. Use ONLY Dealer Fan Blade. I tried to save money by using "MTC" Fan Blade. It broke after one year. Febi is also a good brand (eeuroparts.com) I am NOT a big fan on wasting money and replacing parts when NOT necessary, but knowing that these fan blades are made out of plastic and knowing that at 10y/120K, they go anytime (search the forums and you will alot of disasters happened to people w/ broken fan blades), but in this case I'd say replace it. You will be happy for another 80K or so. The option that Chivas mentioned is deleting the Fan Clutch/Fan Blade altogether and install electric fan. It is expensive though. This idea is identical to the setup in a FWD car (Toyota Camry etc.). The Camry has no fan clutch/fan balde b/c of transverse-mounted engine. So One Aux Fan in FRONT of the AC Condesnor as usual, and one fan behind the radiator. 3. Coolant, if it is blue, use blue, but be prepared to pay. Myself, I have been using Prestone Green on all by bimmers for 20 years, NOT a single problem FYI. |
Do not drill a hole in your stat, Yours is electronically controlled and already has a bleed hole cast into the plastic housing(this only applies to the electronic thermostat) |
For those of you that have not replaced your pulleys/tensioners and have done the cooling system, there is still hope without having to remove the fan shroud (I6, not sure about the V8). The air filter housing, undertray/splash shield were removed from the car. The fan/fan clutch were taken off and just laid against the radiator for clearance. The job will only take about 1-1/2 hours. Pics: Tensioner/Pulley pics without fan shroud removal |
The blue coolant is the BMW OEM one. This is a hybrid OAT (organic acid) coolant (Dexcool but improved hence the hybrid part).
If you don't want to shell out for the BMW stuff, the nearest high street stuff is Valvoline Zerex G-05, which is bright yellow. The colours are only dye, they don't matter. If your coolant is more than 2 years old replace the lot, again either with BMW or G-05. I paid $10 for 5 litres of G-05 but it's pre-diluted. I got the BMW stuff for $25, but it needs diluting 50/50. Therefore you are only saving $2-50 per 5 litres by going with G-05. |
americandan.com
#25
Ok so i decided to buy the blue coolant just to be safe but it comes in bottles that are 1.5 liters. So just to be clear i buy four of these and put in 3 bottles then like a little more than half of the other bottle then the rest distiled water right? does it have to be perfect?
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
