Old 02-19-2009, 03:41 PM
mhughett mhughett is offline
Mein Auto: 2003 530i/2007 Z4 Coupe
While I'm not sure how you got 1.5 litre bottles (thought they were all gallon bottles), I would put in 2 bottles of the undiluted antifreeze followed by an equal amount of distilled water. Then pre-mix one bottle at a time of 50/50 mix and fill until full. In case you haven't see the thread, the best way to fill a 530i is by using the auxilary electric pump that is activated by putting the ignition in the II position (don't start it). This pumps the fluid throughout the engine and helps bleed the coolant and allows you to put more coolant into the system befores startup.
2003 530i 5-speed, SP, PP, CWP, Xenon
Bilstein Sports
UUC short shifter with DSSR and ZHP shift knob
Michelin Pilot Sport A/S
BSW IQ speakers, Sirius
CDV delete
Huper Optik tint
2007 X3 3.0si
6-speed manual, CWP, Xenon, Cft. Seats, Premium Pkg, Sirius, Privacy glass
Old 02-19-2009, 03:53 PM
John@AstigRacing John@AstigRacing is offline
Past Sponsor
Send a message via MSN to John@AstigRacing Send a message via Yahoo to John@AstigRacing
Mein Auto: 2000 528i Sport
Please do not drill a hole on your t-stat. It already has a built in bleeder valve with screw at the top. Unscrew bleeder screw and use that bleeder valve to fill coolant.
Old 02-21-2009, 07:22 PM
E39530i E39530i is offline
Mein Auto: 01 530i
I have already installed the t-stat, (I did not drill hole in t-stat) water pump, hoses, belts, etc. and I'm ready to fill up with anti-freeze. The blue coolant I found on eeuroparts.com seems to only come in 1.5 liter bottles.
I don't see any kind of screw at the top of the t-stat do you mean the screw on the hose that connects to the thermostat...that is where the write up in the beginning of the thread says to fill it up from.
also i didnt replace the water pump pully as its just a metal pully and i dont see how it could break....will this be a problem.
Old 02-22-2009, 02:05 PM
Mein Auto: 01 530i
bump
Old 03-30-2009, 02:09 PM
s-thetikz s-thetikz is offline
Mein Auto: 325is
he meant the bleeder screw on the radiator.
Old 01-05-2010, 06:40 PM
E46BMWplaya E46BMWplaya is offline
Mein Auto: 99 323i e46
99 e46 323i
hey i was wondering if anyone knows why my fan is so loud when my car is warmed up. it sounds like a 18 wheeler. is my fan clutch bad. when the car is cold the fan is quiet but when it warms up the fan roars? someone help me out please cause the noise is annoying. thanks
Old 01-05-2010, 09:39 PM
QuoteWarz Insurance QuoteWarz Insurance is offline
Past Sponsor
Mein Auto: BMW
Also I would say that at 90k it is definitely time for the DIY cooling system overhaul. It is a safe choice so you don't have bigger problems down the line.
E46, Your fan is probably working really hard when the car is fully warmed up so that it can stay within normal operating temps.
Old 03-21-2015, 11:47 AM
718bam 718bam is offline
Mein Auto: 528i
fan clutch brands
has anyone heard of the brands Koolman or Hamann? they say OEM Quality , is that the same as being a OEM part?
Old 09-09-2015, 02:22 PM
gmak2012's Avatar
gmak2012 gmak2012 is offline
Mein Auto: E60:M5 530xi E39:540 528
718bam: no. \I saw a good review of Hamann written by violinARC who hangs out at the the 'forum'. I PM'd ho=im to see if it was in fact him and that the fan clutch was good - but no response. I would avoid Koolmann. If you're looking for a decent fan clutch,that is good value, try Moog.
Old 09-09-2015, 03:51 PM
ca2014mp2 ca2014mp2 is offline
Mein Auto: E39 2000 528ITA
No to Moog.. I bought one overpriced part from them with a lifetime warranty and then years later when I tried to claim the warranty they gave me the run around and didn't pay or replace.. never again with them. Just one guys opinion..
Series E39 Vehicle code DP63 Model 528ITA Engine M52TU
Body type OTHER Catalog model USA Production date 1999 / 06
Transmission Automatic Steering Left Catalyzer YES
Production FROM : 1998/09/01 TO : 1999/08/31
Old 09-15-2015, 10:42 PM
Joelgk Joelgk is offline
Joel
Mein Auto: 2001 530i E39
Should we also replace the electric fan around the same time of leave it for later??
