Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW News
BMW News
Get the latest BMW headlines, news, and rumors and discuss the future of BMW with other BMW enthusiasts!
Old 07-18-2008, 12:54 PM   #1
Blackstone Laboratories
tim330i's Avatar
tim330i
Bimmerfest.com Founder
Show Printable Version Email this Page
posted by tim330i
Established in Fort Wayne, Indiana, in 1985, Blackstone Laboratories strives to provide an easy-to-use, understandable, and accurate oil analysis program with the fastest turnaround in the industry. At the heart of our program is ICP (inductive coupled plasma) spectrometry, database averages for comparing wear, and a comments section on each report that explains - in plain English! - what your results mean.
To get started with our program, just fill out our kit request form for a free sampling kit. The cost of analysis is $22.50. We also have a discount analysis program in place, if you're interested in receiving a price break on your oil samples.
What is Oil Analysis?
Oil analysis is a quick, nondestructive way to gauge the health of an engine by looking at what's in the oil.
What does a standard analysis include?
In our standard oil analysis, we perform four tests:
Spectral exam: In the spectral exam, we take a portion of your oil sample and run it through a machine called a spectrometer. The spectrometer analyzes the oil and tells us the levels of the various metals and additives that are present in the oil. This gives us a gauge of how much your engine is wearing . To learn more about the elements we look at and where they come from in your oil, go to our Report Explanation page.
Insolubles test: The insolubles test measures the amount of solids that are present in the oil. The solids are formed in several ways: oil oxidation (when the oil breaks down due to the presence of oxygen, accelerated by heat), the effectiveness of the oil filter, and blow-by part the rings. When the insolubles get too high, the oil becomes abrasive. To learn more about insolubles, click here.
Viscosity test:* The viscosity measures the grade, or thickness, of the oil. Whether it's supposed to be a 5W/30, 15W/40, or some other grade, we will know (within a range) what the viscosity should be. If your viscosity falls outside that range, there's probably a reason: the oil could have been overheated or contaminated with fuel, moisture, or coolant. Want to learn more about viscosity? Check out this article.
Flash Point test: This test measures the temperature at which the oil burns. For any specific grade of oil, we know what temperature the oil should flash at. If it flashes at or above that level, the oil is not contaminated. If the oil flashes off lower than it should, then it's probably been contaminated with something. Fuel is the most common contaminant in oil.
We can perform our standard oil analysis on any sample of oil, whether it's engine oil, transmission oil, an oil-based additive, power steering fluid, lube oil, hydraulic oil, or another type of oil.
There are more specialized tests we can perform on an oil sample, depending on your needs. For a complete list of the tests we do and their cost, go to our Tests page.
416 East Pettit Avenue
Fort Wayne IN 46806
260/744-2380 (8-5 EST)
This article has been viewed 3990 times.
Old 08-05-2008, 10:51 AM
motokichi motokichi is offline
Mein Auto: 2005 545i
I have used them twice to determine whether the so called Long Life oil is really up to snuff at BMW's recommended intervals. While you can interpret the test in many ways, it led me to go out and do my own oil changes inbetween the 'free' maintenance intervals. The kit comes with everything you need and our BMW service tech had no problem getting the sample for us. There were no problems at the post office with sending the sample through the regular mail, either. Within days I got a report back first through e-mail, then through the USPS.
