Old 07-19-2008, 09:18 AM
schneidz schneidz is offline
Mein Auto: 2001 530i
'abs' 'dsc' 'brake' dash board light/ indicator - 2001 530i
starting yesterday after i drive my car for about 20 minutes all three lights on my dash turn on (yellow).
i am handy enough to diy a ac/ heat fan control unit:
is this something within the average owners ability or will i need to go to the dealership to figure out ?
thanks for any clues you can give me...
Old 07-19-2008, 04:25 PM
bcsurege bcsurege is offline
Mein Auto: 2002 530i
Same thing happened to me recently but the lights when out and stayed off after shutting the car off. A month later they came back on and stayed on for 2 days. I cleaned the two front speed sensors/pulse generators today and they are out again. Give that a try.
Old 07-19-2008, 09:44 PM
oekundar's Avatar
oekundar oekundar is offline
Jedi Knight
Mein Auto: 5 Touring
Sounds like you've got the dreaded ABS module gremlin....I'm currently a member of that club...need to get that addressed, but other things are priority now....mine have been on for 3 weeks. They come and go, but I know I need to pull the module and send it to module masters for a rebuild. $330 if I remember correctly.
BMWCCA #389756
Old 07-20-2008, 06:54 AM
Waveho Waveho is offline
Mein Auto: '07 335xi 6MT 4door
Probably not the ABS module. Replace the front right speed sensor/ABS impulse generator, which is usually the culprit in cases like this. Do a search and read up on numerous discussions on the issue. If your speedo, tech, etc. also stopped working, it would more likely be the pricey module, but this sounds like a classic bad wheel sensor. If so, cheap, easy DIY fix.
'07 335xi 6-spd 4dr, Montego blue
'98 540i 6-spd Sport, Jet Black II(sold)
'92 325i 5-spd 4dr, burgundy(sold)
Old 07-20-2008, 11:08 AM
4dreuropean540i 4dreuropean540i is offline
Mein Auto: 99 540i/6
Waveho... where exactly can i find the sensor on the car? is it clearly visible once you have the wheel removed? Or will i have to take off the wheel liner to get to it? thanks
1999 540i/6
Dinan: intake/exhaust/chip
Bilstein B14 PSS
Old 07-20-2008, 12:25 PM
thanks for everyones opinion. i'll repost whether it is successful once i build up enough motivation to do the work.
^ waiting to hear a response about 4dreuropean540i question above; i too dont know what i would be looking for but hopefully after a few searches ill be able to find a description or a pic.
Old 07-20-2008, 01:30 PM
The sensors are located behind the hub, held by a 5 mm hex screw. They are magnetic, so just wipe them with a soft cloth to remove the debris and reinstall them.
Old 07-20-2008, 01:33 PM
schneidz....hopefully these will help, im just waiting to find out where i can find it then i can match which one i need.
http://www.oembimmerparts.com/catalo...47/4601972.htm
http://www.oembimmerparts.com/catalo...47/4601983.htm
EDIT: thanks bcsurege for the info ill go check mine out
1999 540i/6
Bilstein B14 PSS
Last edited by 4dreuropean540i; 07-20-2008 at 01:35 PM. Reason: needed to add more
Old 07-20-2008, 03:40 PM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is offline
Constantly Learning
Mein Auto: 2006 M3, 2002 M5
See this thread -- same problem here and I'm about to replace, aided by helpful info from Waveho. Note -- stealer wanted $138 for the sensor!
http://www.bimmerfest.com/forums/sho...d.php?t=268735
BLUE HEAVEN:
Interlagos Blue 06 M3, Autologic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here.
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Old 07-21-2008, 07:18 AM
kemosobe77's Avatar
kemosobe77 kemosobe77 is offline
Mein Auto: 04 745li
Originally Posted by waveho View Post
probably not the abs module. Replace the front right speed sensor/abs impulse generator, which is usually the culprit in cases like this. Do a search and read up on numerous discussions on the issue. If your speedo, tech, etc. Also stopped working, it would more likely be the pricey module, but this sounds like a classic bad wheel sensor. If so, cheap, easy diy fix.
+1
FS 02 530i sport 54k miles $17500
Painted BMW E65 E66 02'~05' AC type Trunk Spoiler $325
Old 07-21-2008, 10:03 AM
edirty9's Avatar
edirty9 edirty9 is offline
Mein Auto: 530i
t could be the wrong size tires... i had that issues when i put in tires that were too big off a 740i
Old 06-20-2010, 02:11 PM
Mrsox05 Mrsox05 is offline
Navy Chief's Wife
Mein Auto: 2001 530i- Metallic Blue
Hey, Is that the right fron driver or passenger side????
Old 06-20-2010, 10:54 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
A list of what each of the four wheel speed sensors controls is in this post.
