X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
Back from service, sunroof malfunctioning
My 2006 X3 3.0i (sport/manual/premium/xenons) had a dead battery on Friday. My friend with his 1997 323is jumped me and I took it to the dealer. Saturday I got it back with a new battery and the 15k mile service performed all covered under warranty. Great. BMW Seattle took me with no appointment, returned the car in <24 hours, and didn't charge a thing.
Now the problem, the sunshade on the panoramic sunroof doesn't work. When I go to close it, it closes 1/2 inch and then stops. If I'm really persistent I can close it by pushing the button 40+ times and closing it an inch at a time. Short of taking it back in for service again, is there anything I can do to fix/adjust this? Also, the cause of the dead battery was inconclusive. They said it's possible I left a door partly ajar with a light on, or leaving my iPod plugged in 100% of the time may have finally drained the battery. Does the iPod explanation make sense? I would have thought that with the BMW iPod kit, it would not charge the iPod unless the car was running. Is that right? Thanks everyone! -james
Hey James: other people are having battery drain issues right now as well. look around just a few posts below this one.
My sunroof ALSO did that odd close behavior and it had to be reset. there is a procedure floating around here somewhere on how to do that. kev Quote:
Kevin ----- 2009 MINI Cooper Clubman - "Oxley" Nightfire Red/NFR, Tuscan Leather, CP, PP, CW, Roof Rails & Aero Kit, 16" Bridge Spokes, Xenon, Auto, English Oak Trim & Wood Wheel, Alarm, Hi-Fi ------- 2007 Volvo S60 2.5T 2007 X3.0si PlatBronze/Beige 2006 X3 3.0i, Flamenco Red/Beige 1997 528iA, Oxford/Tan 1994 318iS, Black/Gray 1979 528iA, RubyRed, Tan 1971 2002, Sahara, Saddle |
Typically a USB port delivers about 5volts at 100ma max.
If BMW's iPod unit is drawing power while the vehicle is off then it's a design flaw or it's broken. I have my iPod hooked up 24/7 on my previous X3. However, it was connected via my head unit which only drew power while the vehicle was on. The new Alpine's that are designed for iPods do the same thing. |
I know that there is a sunroof reset procedure which you can find by performing a search here. It involves holding the button and letting the thing cycle through. Maybe a call to service can get you the needed info as well. I'm sure they would rather have you 'fix' it, than have to come in again.
Have you tried opening the window all the way? I think that may calibrate the position sensor.
Sunroof Reset
Push the button UP and HOLD. The sunroof will cycle through all positions and when it's finished let go of the button. Do not release the button until it's gone through the whole cycle.
'05 X3 3.0i Alpine White/Gray Leather/Alum. Trim Sport/Steptronic/Servotronic/Panoramic Premium Sound/Staggered Style 114 18"ers |
Yeah, it's a really simple procedure and will probably fix his issue. I had to do it one day when the roof just went haywire. First I freaked out
-J |
I'm having a problem with mine today. I'm going to try to reset it, when you mean up like to vent it?
yes
That did not help mine. I hope it is covered under the CPO.
Did you push it up and hold it there? It takes a while for it to cycle through all the positions.
Glad James' problem appears to have resolved with the recycle.
I had symptoms quite similar to those James describes two months ago, tried the recycle and while I was getting some changes on just where the various components might stall or hang up, end result was a sunroof that was not entirely closed at all points. Took it in and, after failed attempt to repair, dealer ended up ordering entire cassette replacement. Dianosis: bent guide not able to be replaced (my bet is all the guides were suffering at that point). Good luck!
Relating to my 2006 E83 I also had a battery issue. The vehicle has about 30K on it. Last year the battery failed. BMW replaced it but did not do diagnostics on why it failed. This year again the battery failed. Only this time BMW wanted to charge me for a new battery. They didn't do diagnostics again this time saying it was my phone charger. If you have a look at the manual its very non descriptive relating to battery problems. Relating to "odd" things which could drain the battery the BT module came up with the most hits. The BT module would "stay on" draining the battery. Many times a reset of the BT module would fix it. Other times the BT module would just be replaced. What's funny about this whole thing is I believe that BMW has trained its service managers to state that the "defect" is related to you as a consumer and not them as a provider of the vehicle. My sun roof has rattled since day one. There is a fix posted out there relating to the rattle. The dealers answer to the sunroof rattle was that "they all do that". My quick fix was just to crack one window, keep the shade closed (so I wouldn't hear it) and worry that the dealer could cause more harm than good "trying" to fix it.
E83 2006 Mods installed: Homelink mirror. CIS-IBUS Nav video module, AUX, Rear DR release, NAV SoftW-Mods, Mud Flaps, sun room Visor, Atom based CarPC. Purchased & pending - BMW CD Changer (NOT Installed). Pending: remote start & LED Angel eyes. E46 2001 - 18.5 wheels/tires (summer), 17 stock (winter), Homelink, NAV software upgrade, 16:9 display, BMW video module, Radio to V53, AUX, USB IBUS interface,OEM alarm install, Mini ITX computer, tank battery(removed) & remote starter. |
I have two cars with sunroofs and don't use either one. They are a source of problems in virtually every car I have owned that had one, either leaks or rattles.
+1 (although I use the "sun roof" on the Z!
+1, press and hold till it finishes the whole cycle, i.e. opening and then closing back entirely. FYI, CPO warranty doesn't cover sunroof. How do I know? My sunroof visor (shade) broke and got stuck inside, I took it in and the SA initially thought I was out of new car warranty and quoted me upwards of 3k to replace the whole cassette, I reminded her that even though I have CPO the new car warranty hasn't expired yet. Thankfully it was replaced under the new car warranty, to top it up, their technician left some smudges in the interior so they replaced the roof liner as well. Be very careful with those sun roof though.
(OO \ (|||) (|||) / OO) |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
