Old 07-23-2008, 05:13 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
BMW E39 Radio Adjustment for iPod FM transmitter or wire
Three questions all rolled up into one ...
1. Why does the BMW E39 radio have SOOOO much static on an "empty" radio station (is there a way to kill the static)?
2. In an attempt to avoid static, I can find "empty" even-numbered stations; but how do I get the BMW E39 "Corporate" radio, in "m" manual mode, to tune to an even-numbered station, e.g., 89.0 (vs 89.1 or 88.9).
3. In a further attempt to avoid pop hiss crackle FM radio static when transmitting from my iPod, is it easy to hook a WIRE to the radio instead of the Belken FM transmitter?
Old 07-23-2008, 05:18 PM
spydrz's Avatar
spydrz spydrz is offline
Sandlapper Chapter
Mein Auto: 2013 X1 xDrive35i
You have to set it to European mode...but if you listen to AM or have factory Sirius installed, they won't work with that setting.
Edit: the BMW AUX input is very easy to wire in.
1984 318i/man./Tornadorot*
1990 525i/man./Alpinweiß*
2001 525i/man./SP/PP/Cosmosschwarz/Sandbeige*
2002 X5 3.0i/man./SP/PP/Sirius/BT/Titansilber/Sandbeige*
2006 330i/man./SP/PP/CWP/Sirius/Blackline/Rear Fogs/Arktis/Grau*
2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige*
2012 VW Golf R/Rising Blue*
2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Premium/Tech/Dinan Stage 2
*retired
Old 07-23-2008, 06:44 PM
bluebee's Avatar
Where is the Aux input for a 2002 E39 (built in 11/2001)?
Oh? The Aux input? I didn't know anything about an "Aux input". ... ... ... Am searching ... ... searching ... Hmmm ... where might that Aux input be for a 2002 E39 with no navigation, no bluetooth, but it does have the "Corporate Radio" with steeering wheel control?
Are you intimating I can just wire my iPod nano into a connector sticking out somewhere and forever stop fiddling with the hissy Belken FM transmitter altogether?
Tell me it's that easy!
Old 07-23-2008, 08:32 PM
Bren517's Avatar
Bren517 Bren517 is offline
Mein Auto: 03 525i
or if you have a tape player above thats another cheap alternative to hook into.
03 525i - e60 M5 18" wheels | M5 front grill | HIDS | Front Strut | Koni adjustables with Eibach springs
Modified stock intake / CF Heat Shield | AUX IN | Focal coax | Focal power sub | Tinted Windows
Old 07-23-2008, 09:07 PM
bluebee's Avatar
Where is the Aux input on a 2002 E39 (built in 11/2001)?
It's a CD player on my E39 ... sans Nav.
I looked up where to find the "E39 Aux input" for my 2002 E39 which was apparently built in 11/2001.
Are these my options:
- FM transmitter (the Belken one I have stinks as there is too much static on any station)
- Auxiliary Audio Input Kit - P/N 82 11 0 149 390 (problem is the E39 must be built after 9/2002 plus there's no control of the iPod nor charging)
- DICE SILVERLINE iPod integration trunk kit (allows for steering wheel & radio control of iPod and charging)
The only problem is the DICE writeup assumes a CD changer in the trunk but I don't have one that I know of....
File Type: pdf BMW_E39_iPod_Aux_Port_Install_Instructions.pdf (350.2 KB, 839 views)
Old 07-23-2008, 11:37 PM
bluebee's Avatar
Still doing research, I found it matters which DICE kit to get, based, partly, on whether or not I have the CD changer.
I guess these are my choices:
DICE - SILVERLINE iPod Integration Kit for 5 Series 97-03 (Radio Interface)
http://www.europeanautosource.com/pr...oducts_id=1624
DICE - SILVERLINE iPod Integration Kit for 5 Series/M5 97-03 (Trunk Interface)
http://www.europeanautosource.com/pr...oducts_id=1625
BTW, is this normal to have a plastic button saying I have the 6 CD changer but to not actually have the BMW cd changer in the trunk?
I'm still trying to figure out if I have analog or digital DSP or neither so I know which DICE kit to order?
ID:	154617   Click image for larger version
Old 07-24-2008, 12:35 AM
supark supark is offline
Mein Auto: Falcor
Ok here's the lowdown on the DICE stuff.
1) All E39s are wired for a CD Changer. They may not necessarily have a CD Changer installed, but the wiring is there regardless. These plugs are where you plug in the DICE unit - if you have DSP.
2) You can tell if you have DSP by simply looking at your radio. Looking at your radio face, you don't have DSP because you don't have a button that says "DSP" on your radio - it's as simple as that. You can order the non-DSP kit.
3) You only need to do the trunk interface version if you have DSP, so you're in luck. It's a significantly easier install doing it from the radio head unit. For DSP you have to wire up a Digital/Analog converter to the amp located in the trunk, so I think for ease of installation they just do all the connections in the trunk.
So yeah - get the radio interface one and you'll be golden. Probably want to confirm with Tom at EAS just to make sure though.
Old 07-24-2008, 04:01 AM
bluenosegaff bluenosegaff is offline
$AcFinEsTBluEs
Mein Auto: 330ci
i found a site that sells a kit that is the same as a dice kit but its just under a diff name because they make it them self.http://indashpc.org/new/ i will be ordering my kit from them soon
[SIGPIC]
at 6 month's
Old 07-24-2008, 05:09 AM
Fudman's Avatar
Fudman Fudman is offline
+1
The DICE Silverline is everything advertised and really is the only way to install an iPod in an e39. Works like a charm and eliminates all the FM transmitter hassles (e.g. powerline buzzing, etc.). I went with the trunk mount. A 30 min total install. Absolutely no interference. I hear the radio install is even quicker and everything sits in the glovebox. I routed the cable into my armrest console where the iPod sits. You will need occasional access as the iPod will occasionally end songs prematurely (twice in 6 weeks) or fail to engage (once in 6 wks). Seeing your songs' info come up on the display is way cool! Also Tom at EAS is extremely helpful and epitomizes customer support. His support alone is worth any premium you pay over a competitor's system.
Two thumb's up!
Old 07-24-2008, 06:26 AM
Est1974's Avatar
Est1974 Est1974 is offline
Mein Auto: 1999 E39 Touring
hey have you tried an FM modulator instead of the cradle you are using? it is a million times better for ipod reception. Shuts off the signal to anything other then your ipod frequency.
Old 07-24-2008, 12:38 PM
$AcFinEsTBluEs
Mein Auto: 330ci
with the site that i listed it has the full front control too like the dice system. the track name come up the track min and all its just a whole lot cheaper about 75 bucks
[SIGPIC]
at 6 month's
Old 09-02-2008, 11:13 PM
bluebee's Avatar
Hi guys,
Does anyone know if the DICE kits handle the new iPod Touch that Apple plans on releasing next week?
I've decided on the Dice kit, but I haven't yet decided on trunk vs radio mount (I'll do whichever is easier but I'm not really sure which is easier).
But, I may as well get the kit that works with the latest iPods (to be released next week).
Anyone know if the new iPods will have the same interface to the Dice cables?
Old 09-03-2008, 04:50 AM
Fudman's Avatar
I would bet that all new iPods are backward compatible to the old iPod interface. My daughters' new iPod Nanos are compatible with my Mini and my AC charger. Changing the interface would be dumb engineering. Internal electronics are another matter but output is output and charging inputs shouldn't change so I would GUESS nothing will be changed.
Old 09-03-2008, 09:29 AM
bluebee's Avatar
OK. Well, we'll find out next Tuesday. Until then, I'm gonna hold off on the Dice purchase.
Besides, as in the other thread (http://www.bimmerfest.com/forums/sho...d.php?t=290558) I have the paralysis between choosing the trunk mount vs the radio mount.
I'll bet the Dice boys lose more business over that quandary than anything else. My suggestion would be for them to design the kit "either way" so the user buys it first, and, after buying it, and at the job itself, the user decides which method to use. Sigh.
Bluebee
Old 09-03-2008, 11:46 AM
Jmoto97 Jmoto97 is offline
Mein Auto: 2002 525i E39
http://www.peripheralelectronics.com...x?ProductID=16
These are the units they sell at Best Buy and Audio Express (AZ audio dealer).
I haven't installed it yet, but you should have control over your ipod through the radio. It is specific for BMW.
They wire it through the CD changer cables. You can have the plug for your ipod come out of the glove box and several other crafty locations.
Old 09-03-2008, 12:10 PM
jstover's Avatar
jstover jstover is offline
Realtor
Mein Auto: 2007 328i - Barbera Red
Disregard my comment. EAS seems to be the way to go if you want the track info to display on the MID.
When all else fails... get a bigger hammer!
2007 328i
2000 528i M-Tech 5spd
1987 325is
Last edited by jstover; 09-03-2008 at 12:24 PM. Reason: Found the answer I was looking for!
Old 09-03-2008, 01:22 PM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
Bluebee man, you are one mixed up dude. Are you British by any chance? I say head to Bavsound.com. They aren't losing sales trust me. There is the dice module itself and then there is the ash-tray mount kit as an add-on. The ONLY question is whether you want your dice mounted sitting in a dock or not. And it's a sweet option. Also, why don't you post in the DICE thread to see if they will support the new ipod touch instead of waiting and hoping? Show some initiative. Official EAS Dice Thread
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 09-04-2008, 06:52 AM
bluebee's Avatar
Collection of E39 references for Dice installation
OK, I placed into that Dice thread all the E39 references I knew of, including the actual PDFs of the E39 Dice installation & troubleshooting manuals, plus a couple of videos of complete E39 Dice installations.
http://www.bimmerfest.com/forums/sho...postcount=1735
ID:	159025   Click image for larger version
Old 09-04-2008, 11:16 AM
Chango Chango is offline
Mein Auto: 2002 530i
I have a e39 with a 02/2002 production date with a business CD, although I am considering satellite radio instead of ipod. I am curious if you considered the Intervee II option; it is more expensive then the Dice
Old 09-04-2008, 11:20 AM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
I have my sirius receiver hooked up to the AUX on my DICE unit so I have iPod AND satellite lovin', then in-dash CD and of course terrestrial radio. If you can't find something good to listen to with all those options then god help you! LOL. Seriously though it rocks. The Dice has it's quirks but I've def heard good things about the Intravee even with it's hefty pricetag.
Old 09-04-2008, 03:05 PM
bluebee's Avatar
Never heard of "Intervee II" before.
Seems to only be one thread on it here on Bimmerfest ...
http://www.bimmerfest.com/forums/sho...ht=intervee+ii
Wasn't much there by way of explanation.
What is Intervee II anyway?
Old 09-04-2008, 03:18 PM
rivercity's Avatar
rivercity rivercity is offline
Mein Auto: BMW 1998 528i
Just to give you a heads up Mack......Bluebee is a gal.
Old 09-04-2008, 04:35 PM
Well, I am learning about it too. but here is what I know. intervee II is made in the UK and is sold by bimmernav. It converts data from an alpine bus/format called AI-net to the BMW bus/format called I-BUS or something like that. Alpine has some devices that communicate with each other via the AI-net.
So for IPOD I quess you need to buy the intervee II device for the AI-net to Ibus conversion and also anther device (the KCA-420i ipod adapter) to convert from ipod data to the AI-net.
The appealing thing is the installation is easy. it can be all in the truck with the ipod info displayed on the MID and the ipod controlled from the steering wheel and MID buttons.
Same with satellite radio .
Google intervee II for more info
Please jump in if anyone has any experiences with this setup.
Old 09-05-2008, 12:30 PM
RichardP RichardP is offline
Mein Auto: BMW E39 M5
Do a search for just "Intravee" and you'll find plenty.
2003 M5, Carbon Black, Nav, Intravee II with Ipod + MP3 CD Changer + DAB + MD Changer, TV, Bluetooth Phone, the works.
2013 M6 Gran Coupe, Sakhir Orange, Competition Pack, Ceramic Brakes and lots of other options
Old 09-06-2008, 08:10 AM
oh yeah, Sorry for the wrong spelling.
