Old 07-24-2008, 03:42 PM
akumar akumar is offline
Mein Auto: 2002 540i 6-Speed Sport
Climate Control Only Blows Cold Air
Hey everyone. First, thanks for all the great help on this forum. I've checked the forums and have not got any ideas about my car's problem.
I have a 2002 540i 6 speed that has the standard dual climate control. When I run the A/C, the up/down temp control for the left side works just fine. I raise or lower the temp with the buttons, the display reflects the change, and the air from the left side gets colder or warmer. However, with the right side controls, while the displayed temperature changes, only cold air blows out from the right side of the car (right center vent & right door vent). In other words, if I increase the temp. control from 65 to 75, the displayed temperature will change but the air on the right side still blows just cold air. The air from the right side does blow more or less with the fan control but the air is always the same temp...cold.
The blower controls work fine and I have replaced the FSU in the past (two years ago). It seems like all the digital controls on the Control Console work (the displayed temp changes) but the actual temp does not change for the right side.
Any ideas would be welcome and appreciated.
Old 07-24-2008, 06:43 PM
Waveho Waveho is offline
Mein Auto: '07 335xi 6MT 4door
From the description of the problem I would suggest that it is more likely a mechanical problem rather than electrical--there is a flap or "door" within the climate control system, behind the fire wall if you are in the engine compartment, and under the center of the dash if you are in the car, that regulates air temp mixture to either side of the car and to the rear. Sounds like a stuck-open regulator flap? Maybe someone here has had the problem and can tell you how to reach it.
'07 335xi 6-spd 4dr, Montego blue
'98 540i 6-spd Sport, Jet Black II(sold)
'92 325i 5-spd 4dr, burgundy(sold)
Old 07-24-2008, 08:11 PM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
are you useing the auto setting? if so turn it off and use the manual buttons. see what happens.
The more you complain, the longer God makes you live. SPHOBA #00002
Old 07-24-2008, 08:36 PM
VinZul's Avatar
VinZul VinZul is offline
Used and Abused
Mein Auto: 6.0 GMC Slow Mobile
2000 528i SPORT upgrades- Eibach Anti-Roll Kit-Hawk Performance Ceramic Pads- ATE PremiumOne Slotted Rotor - Goodridge G-Stop Brakeline Kit - M5 Power Fold mirrors - M5 Front Bumper (SOLD)
2009 G8 GXP (SOLD)
2005 G35 (SOLD)
2003 540I SPORT --- BLEW UP! Redlining is a lot worse then I thought.
2003 GMC Sierra Denali (SOLD BUT STILL USE IT)
ON THE HUNT FOR A...G8 GT MAYBE?
Old 07-27-2008, 04:15 PM
Thanks for the advice, especially Waveho. I'll have the local indy shop check if it is a climate control door or flap mechanical problem before spending the money on a new controller. To answer the question, I do not have the CC set to Auto but it is in manual mode.
If anyone else has any ideas, please post any theories. Thanks again.
Old 07-27-2008, 05:26 PM
branndon_b branndon_b is offline
Mein Auto: '99 540it
akumar, if you run the blue to red rotary knob towards the red on the side of the center vent, does the passenger side get warmer too, or just the driver's side? until you get it figured out, that may be the way to work it in the meantime.
