Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Closed Thread
Old 04-22-2003, 08:56 PM
rost12's Avatar
rost12 rost12 is offline
round -n- shiney
Send a message via ICQ to rost12 Send a message via MSN to rost12
Mein Auto: m5, 911
Resource - FAQ for 745i/Li & 760Li (E65,E66)
-= Click for BMW 745i/Li & 760Li (E65,E66) FAQ =-
Any comments, suggestions, and contributions are always welcome! E-mail me at rost12@mac.com
Cheers.
Old 01-18-2006, 08:29 AM
djlfp's Avatar
djlfp djlfp is offline
Happy as a snapping clam
Mein Auto: 06 750Li
Originally Posted by teambarajas
My car did not have the owners manual, so this is a very slow learning process... big difference from my 1996 328ci ....Thanks.
Welcome. Get your VIN. Go to the BMW website, then Owner's Circle. Register with your VIN. You should then be able to download an owner's manual which you should read. Good luck.
djlfp
Semper Paratus
Old 05-23-2006, 02:59 AM
SilverSaloon SilverSaloon is offline
Mein Auto: 7 Series E65
try here:
www.geocities.com/e65faq
Old 08-29-2006, 01:21 PM
bimmerno1 bimmerno1 is offline
Mein Auto: BMW 745 LI
Thanks...!
Navigation displays "VEREINIGTE STAATEN" in the destination input menu?
To bring your car back to this side of the world follow these steps
1) Insert the ignition key
2) Turn on ignition = WITHOUT TOUCHING BRAKE PRESS STOP/START SWITCH, VARIOUS LIGHTS COMES ON INDICATING IGN ON ENGINE OFF
4) Select the main menu in the control display by pushing the controller one or two times in the same direction
5) Push the controller to the right to select Navigation
6) Select "Dest. input"
7) Select "ABC..."
8) Select "Country" (the field that shows "VEREINIGTE STAATEN")
9) Select the return arrow
10) Push the controller to the lower left to select "Settings"
11) Select country settings (the two flags)
12) Select "Francais"
13) Wait until the text on display has changed to French
14) Push the controller to the right to select "Navigation"
15) Select "Pays"
16) Select "ETATS UNIS"
17) Push the controller to the lower left to select "Reglages" (Settings)
18) Select "US English"
19) Wait until the text on display has changed to English
20) Push the controller to the right to select "Navigation"
21) Select "Country" (the field that shows "ETATS UNIS")
22) Select "UNITED STATES"
23) Select "Town/City"
24) Select any town
25) Select "AS DEST."
26) Select "Route Guide"
27) Wait for the display showing you the direction or for the spoken instructions
28) Remove the ignition key
29) Wait 16 minutes until vehicle changes to consumer cutoff mode
30) Turn the ignition on
31) Input a destination to confirm that the country is still "UNITEDSTATES"
If there were any previous entries with "VEREINIGTE STAATEN" delete all these destinations (ensure that all entries are deleted in Dest.List, Last Dest. and Addressbook)
Important: There have been reports that with later build models that Pays is not selectable (step 15). The solution is to wait 30 minutes after you change the language.
Old 08-29-2006, 01:49 PM
760Lifan's Avatar
760Lifan 760Lifan is offline
BMW-addicted
Mein Auto: Not worth mentioning
Just curious: Why is it necessary to change the language to French before switching to English? "Vereinigte Staaten" means "United States" so I guess the car is already set to the correct country and only requires switching it to the correct language (English)? Just curious...
Old 10-22-2006, 04:15 PM
pedro2u pedro2u is offline
Mein Auto: 745i
Thanks bimmerno1. Your post to get the United States working in the Nav worked great on my 2002 745i.
This is a great forum. Too bad it wasn't linked to the BMW site so that they could see the kind of things that are frustrating us. A phone that worked for example
Old 11-21-2006, 11:08 AM
bmwracer3 bmwracer3 is offline
Mein Auto: 2000 328i
here's an FAQ that I found...
Chris
Old 02-07-2007, 10:34 PM
paulmurphyhomes's Avatar
paulmurphyhomes paulmurphyhomes is offline
Mein Auto: M3, 745li, Speclzd FSR Pr
Owners Manuals for 7 series
Originally Posted by teambarajas View Post
I am new to this site and looking for info on programming the remote /smart key for my 2002 745LI. also, is it true the dealership needs to keep the car for 3-4 days to update software, etc? Any suggestions for a new 745li owner? My car did not have the owners manual, so this is a very slow learning process... big difference from my 1996 328ci ....Thanks.
You can download a manual here...http://www.analogstereo.com/bmw_7_owners_manual.htm
Old 02-07-2007, 10:57 PM
In case that link goes down again, here is another copy of the FAQ
http://www.huntington-beach-realestate.com/745i/bmw-e65-e66-frequently-asked-questions.htm
Old 06-19-2007, 03:36 AM
eyi760 eyi760 is offline
Mein Auto: 2004 BMW 760Li
Originally Posted by paulmurphyhomes View Post
try here:
Thanks for the manual!
Old 07-26-2007, 01:33 PM
jessicajiw10 jessicajiw10 is offline
Mein Auto: 2002 745li
Hey everyone, I have a question. I just recently traded in my 99 740i for a 2002 745li. I have noticed that the get up seems really different, then a couple of days ago I noticed that when I am driving up or down hills the transmission seems really wierd. For example, going up, it seems really slow to gear, and coming down a hill it is almost stopping itself rather than gaining momentum. Does anyone know what this might be? Also, when I got in this morning, it said I have a flat tire in the right rear, but I dont. If anyone can help I would really appreciate it!
Old 03-24-2008, 10:20 AM
diznik007's Avatar
diznik007 diznik007 is offline
Mein Auto: Kubota on 48's
these transmissions are known to be problematic. hopefully, you have warranty remaining on the car. the transmission reset may help you for a week or two but it definitely sounds like you need the dealer to look at it.
here are instructions for the tranny reset.
Insert the Key to into the key fob (DON’T HOLD THE BRAKE).
Press the Start Button ONCE, just so the car electronics start and show the Engine light is on. (Again, Don’t START the Engine).
Press and HOLD the GAS PEDAL all the way to the force down click on the gas pedal for 25 seconds.
After those 25 Seconds, proceed to Starting the Engine and drive your car.
E66 SAPPHIRE BLACK
Old 06-16-2008, 03:35 PM
aziza714 aziza714 is offline
Mein Auto: 745li
Angry 02/03 745li
Hello bimmer owners!Anybody have the anwser to this Question,745li dont want to go in reverse or drive on occasion i have 2 shut the car off restart it then the tranny will go into gear ! What a freakn mess
Old 06-16-2008, 03:41 PM
sunny_j's Avatar
sunny_j sunny_j is online now
Mein Auto: X5d
welcome to the forum. it sounds like your tranny is about to die. is your car a 02? do you have warranty?
2012 X5d | White on Black | Fully Loaded | JB Diesel Tuner - 525+ Pounds of Torque
-2009 E320 Diesel | White on Black | H&R Springs | Clear Side-Markers | Kleemann KD-Box 270hp & 450tq
20" Monarch Hamburg Rims | Black Roof | E63 Rear Lip | Hood Emblem Delete | Foglight Chrome Trim Delete
Tinted Tail Lights Gone
-2003 760LI Titanium Gray Metallic | Every option | H&R Springs upfront , via computer in rear
OEM Style 128 21" wheels | 40% tint | AIB Angel Eye's with matching foglights Gone
Old 09-18-2008, 12:01 AM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
Thread cleaned up.
Please feel free to add: links to resources, buyer's guides, FAQs or FAQ pages, etc.
New technical question? Try searching first. Then, please start a new thread with a detailed subject line and always provide your year and model. Consider giving as much information as possible, such as mileage, related options, recent related service, etc.
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Closed Thread
HTML code is Off
