E30 (1982 - 1993)
Old 08-04-2008, 07:47 AM
Pen318 Pen318 is offline
Mein Auto: 1984 318i
Valve clearance for M10 engine?
I've been searching to find the clearance for the M10 engine, all articles are for the M20's. Does anyone know the spec for the valve clearance on the M10 to do a valve adjustment? Cold spec would be preferable.
Old 08-04-2008, 10:41 PM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
If you can wait I will dig my e30 book out of my closet at the 'rents this weekend.
Old 08-05-2008, 07:21 AM
Well, considering I haven't been able to find the info anywhere else and you're the first responder, I can wait. Much appreciated. I need to order a new valve cover gasket before I do the task anyway.
Old 08-16-2008, 04:33 PM
On Top
0.010 of an inch cold, done intake to exhaust in firing order.
Old 08-18-2008, 08:23 AM
Thanks! Though, are you certain it's inches? I thought BMW listed specs in millimeters?
Old 08-22-2008, 12:48 AM
Rekcedbob Rekcedbob is offline
Mein Auto: 1985 Bmw 318i
I did mine using those specs and it clattered too much-the feeler moving easily under the rocker but with no play. Readjusted it tighter, where I had to pull and wiggle the feeler out after tightening. It's wicked smooth and quieter than ever. The actual specifications for the M10 are as follows:
0.20 mm
or
0.008 in.
Old 08-23-2008, 02:08 PM
On Top
0.20 mm
or
0.008 in.
It said 0.010 in the book. I liked mine a little tighter on the M20 myself personally also.
Old 08-23-2008, 04:01 PM
The original owners manual specifies the clearance to 0.008 in. for the 318i and 0.010 for the 325e; the original owners hit's on both models.
This is one error I found in Bentley. I used both specifications and found the original manuals specs to be quieter, no chatter at all, yet not tight. I think if you have chatter it's wrong, the valves won't open to the maximum.
