Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 08-04-2009, 07:00 AM
drklausmeyer drklausmeyer is offline
Mein Auto: 2002 525 i Sport Wagon
3M makes a kit for this now, really simple - they just have you tape off the area and not remove the entire headlight assembly, which I liked. I would give the product an 8 of 10. On Amazon for $12 http://www.amazon.com/3M-39008-Headl.../dp/B001AIZ5HY
Old 08-23-2009, 10:27 AM
UFANS UFANS is offline
Mein Auto: 2005 545i Sport SMG
I've read a lot of these posts over the past month and just did my headlights this weekend. I have to say that this is the best thread on the subject.
Here are a couple of lessons learned from my experience:
- Like the post did ... start with 400 grit paper. If you have a lot of grit-looking then you need to start aggressive (don't worry.. there's plenty of plastic left)
- The sandpaper is great, but definitely use a (rubbing) compound. The paper will always leave cut marks and the compound on a DA will smooth out everything
- After the compound.. .use a ScratchX type polishing compound to get the smoothness and get rid of any swirls for fine marks
- Don't forget the sealer!
2005 545i SMG // Grey on Black // 19" VMR HyperBlack
2008 335i Manual // Sapphire Black on Black
Old 10-05-2009, 06:24 AM
Buddly Buddly is offline
Mein Auto: 1999 528, 2001 530
This is an excellent post! I attacked my lights this weekend and had results similar to yours. I did the first one on the car and it’s unnecessarily difficult to do it that way. On the second one, I removed the assembly (5 min. max.) and used a Black & Decker Workmate to hold it. It’s a lot easier to work on it that way and you don’t have to worry about the surrounding surfaces.
Old 10-07-2009, 04:23 PM
returnofmike returnofmike is offline
King of Kool
Mein Auto: 2001 540i
I just finished polishing mine. and they look GREAT, removed all the rock chips and everything!
Get what you can, can all you get, guard the can
Old 10-11-2009, 08:49 PM
King of Kool
where can i get the sealer at?
Old 10-12-2009, 02:40 PM
http://superiorcarcare.net/
Search for Diamondite
Old 10-12-2009, 04:30 PM
xtremecruiser's Avatar
xtremecruiser xtremecruiser is offline
Mein Auto: 08 335I vert
Nice write up, thanks for taking the time to post it
Old 10-21-2009, 10:48 PM
boosted 528 boosted 528 is offline
Mein Auto: 98 528i/93 civic/06 525
Wow that incredible! This just gives me hope , and instead of buying new headlamps, iam gonna do this first
Old 11-15-2011, 04:57 PM
Bluehorse Bluehorse is offline
Mein Auto: Fremont, CA
Yellowing from inside the lens?
Thinking to polish my headlight lens too, but then when I looked at my 2004 525i, noticed that the spotty yellowing appear not to be on the outside surface of the lens, but instead more like from inside. Has anyone, esp. those who did the lens restoration, noticed about the same?
Old 02-23-2012, 07:05 AM
occupant occupant is offline
Send a message via ICQ to occupant Send a message via AIM to occupant Send a message via Yahoo to occupant Send a message via Skype™ to occupant
Mein Auto: 1976 Ford Gran Torino
The process is more important than the product. Take your time and do each step thoroughly and don't skip any steps. Most automotive headlights have a similar grade of plastic. I used a $8 bottle of Turtle Wax Headlight Restorer, two worn socks, and a garden hose to achieve these results on my wife's Durango. No power tools, just elbow grease and patience.
Product:
Before:
After:
But honestly, the next time I have heavily clouded lights to deal with I'm picking up a polishing pad I can put in my drill, proper sandpaper, and that PlastiX stuff. You can do it by hand with cheap stuff but the reality is it won't last as long.
Alan Moore - Wichita Falls, TX
00 Durango | 98 Silhouette | 95 Cutlass Ciera | 76 Gran Torino
shopping for an E34/E39 540 manual
Old 03-24-2012, 01:12 PM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 120k
FYI, that Turtle Wax product didn't do JACK on the E39 plastic lens.
I am going to try real sandpaper , like in this write up.
Old 03-26-2012, 05:05 PM
elias526 elias526 is offline
Mein Auto: 2008 BMW 535xi e60
This is an awesome write up, I tried to do restore my headlight on my e60 using the 3m headlight restore kit and it came out like crap. I know I didn't put it the adequate amount of time into it so I'm going to try your procedure and I hope it comes out as good as yours
Old 11-16-2012, 11:57 AM
530iAlpineWhite 530iAlpineWhite is offline
Mein Auto: 2006 530i
The best I have used is a Sylvania headlight restoring kit! Sold at Auto Zone. Did mine two days ago with side marker turn signal lights on my e60 and LOVE the clear brand new look. Took me a few hours and was worth the work.
Old 11-16-2012, 12:00 PM
Old 11-19-2012, 10:29 AM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator 5-Series
Mein Auto: Trek 6500 MTB
I see this is many years old and recently brought to the top.
If you really want to protect your headlights, I suggest adding some headlight protection in the form of clear plastic. Many are familiar with the "clear bra" paint protection kits available for the areas of our cars that suffer from chips. They have thicker plastic for headlights foglights. http://www.xpel.com/products/headlight_protection.asp is one example and what I put on my 2001 530i back in 2001. I guess I should try and post some pics of what they look like today.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (97k miles)
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred...no longer have)
Old 11-19-2012, 08:43 PM
Check my recent post
Old 11-22-2012, 05:04 AM
Sylvania Headlight Restoration kit....$22 and worth the time to make them look clear and new
ID:	350422   Click image for larger version
Old 02-07-2013, 09:13 AM
oldman12 oldman12 is offline
Mein Auto: 535i
Dude! You are a beast and anal as hell! You are the type of seller I recommend to people who want to buy a car, but of course, most are so stupid, they don't value a seller who takes extremely good care of the car. Makes the paying more, worth it! Excellent job!
Old 02-25-2013, 04:10 PM
batmbl's Avatar
batmbl batmbl is offline
Mein Auto: 2009 535i
I, for one, would be interested in pictures of your lights some time after your repair and installation of the protection pieces.
Old 03-04-2013, 05:49 AM
Anyone ever figure out what sort of clear coat once can use after buffing out the lights?
I'd like to seal mine lights with any canned product that is good enough. Any ideas?
The UV protectors either runs or simply hazes out with a month or two.
