power antenna for Z4M C??? - Bimmerfest - BMW Forums
Old 08-10-2008, 12:21 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Question power antenna for Z4M C???
Although my car is waiting for a train to Southern California, I've been looking at a few things I'd like to order when the car arrives. One of which is a car cover, probably one of the heavier Kimberly Clark versions. The only issue I see is the dreaded antenna hole, so I thought, instead of unscrewing the thing every time, I wanted to know if it was possible, or if anyone has done a power antenna modification. I've never done something like that myself, but with a car cover coming on and off (while at work), it would be really convenient to have an option like that.
Thanks in advance for any information.
Old 08-10-2008, 02:43 PM
03BeastCharmer's Avatar
03BeastCharmer 03BeastCharmer is offline
Mein Auto: 03 M5; 97 M3
Most people just buy the stubby antenna's that are like an inch high off of e-bay. search stubby antenna, and you'll find links to some of the stores. A short antenna should make make car cover on/off a non-event.
I've never heard of a power antenna option, and it would be a lot of effort to get something rigged up.
The Beast: E39 Dinan M5 (Gone)
Beast 2.0: E92 M3
"Control, Vision, Determination" These are the three fundamental components of the new generation race car driver!! SPEED is a by-product! -Memphis Raines
Old 08-10-2008, 03:57 PM
thekurgan's Avatar
Bad Lieutenant
Thanks for the reply, I haven't found anything in the way of power antennas, but did find some retractable stubby type antennas, so I may go with that. I don't want any less radio reception. I found a 4" at Bimmian as well, that may work if it has good reception.
Old 08-10-2008, 08:08 PM
My 1 inch statement was a little exaggerated. The 4 inch one is what people are getting. Most people say there is little to no signal lose. I haven't used my FM radio ever (and I don't have the stubby), so ratio reception isn't an issue for me.
Beast 2.0: E92 M3
Old 08-10-2008, 08:37 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
The issue is whether or not there's room for it. If there is, it's easy. If there isn't, it's not doable without placing it somewhere else. On the Z3, there isn't room under the fender for a power antenna. I have no idea for the Z4 but I suspect it doesn't have room. Minimum is about 8.5" for one with a remote motor, and about 13" for one with a direct motor.
Daniel
2002 M roadster
Old 08-10-2008, 09:18 PM
thekurgan's Avatar
Bad Lieutenant
I saw a few extractable short antennas, but I figure that's just begging for someone to come by, extend it and bust it ... I think I'll order the 4" from bimmian as soon as I hear the car is on a train.
antenna, power
