E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
P0301 p0305
Just took my car to autozone and it threw these codes out. BRAND new spark plugs. I'm also not very familiar with the ignition coil packs. any ideas?
oh and the codes are for misfires in cylinder 1 and 5
Clear them and see if they come back. Could be anything from bad gas to bad coil packs, to a crack in your intake elbow, to the MAF. Without other codes you will have a hard time narrowing it down.
i am not sure how to completely clear the codes and its kind of been a recurring problem and i often loose torque and hp randomly at starts so something is definaltey wrong but what will make it give me more codes than i already have?
JUST misfire codes will be tough to diagnose because a LOT of stuff can cause that. I'd start with checking your plugs (free), checking your intake boot (free) and cleaning your MAF ($5 for MAF cleaner). See what that does for you..... |
I must've been completely out of it yesterday but the real codes on my autozone printout are P1353, P1351, P1345 and P1343 which it says it a misfire in cylinder with fuel cut off, does that change anything from me originally saying P0301??
uh oh....
P1351 IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage P1353 Ignition Coil B Primary Circuit Malfunction P1343 Misfire Cylinder 1 With Fuel Cut-off P1345 Misfire Cylinder 2 With Fuel Cut-off
2000 323i ZHP Suspension (shocks, springs, sways) Front Strut Bar 135m Wheels BMW CCA #407107 |
Isn't there a way to clear codes without a code reader?
...but i checked my intake tube, seems fine. I clean the MAF sensor and i checked out the coils and plugs, but to be honest i'm not really sure what i'm looking for in them, i mean the conections seemed fine and nothing looked out of the ordinary. I think i may go for a fuel filter change next. How does that sound
The cylinder closest to your radiator (or front of car) is #1 and the one in the back by the firewall is #6. Let me know.... |
thanks for the info!! this inspires me to do my own work as soon as i can borrow a code reader locally!
Had a bad miss number 5 coil was bad replaced all coils and plugs.Still ran bad pulled codes came up with P0102,P0113, P0305 and P0303.After checking all codes and looking for problems. found it.Do not rely on coil locks to install wires make sure all are pushed in all the wayby hand. All codes went away.
Sounds like a bad coil to me. Switch the coils, see if the code follows.
you can also check the resistance on the coils with a DVOM... primary circuit should be 0.5 ohms and the secondary circuit should be around or a little less than 6k ohms... but i would defiantly check the wire connections and try juggling the coils around on the engine like rccuda and smolck have instructed. BTW what plugs are you using? Any signs of cracked boots where the spark may be shorting?
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
